Question about Initial 5820 Portable DVD Player with Screen
I have just the player, the battery say rechargeable but i do not have a battery charger i do have the cig lighter charger but do not want to go that route in charging where can I purchase one
How many and what colour wires are in the wires leading to the cig lighter end of this FM transmitter?
don't cut it, use something like this: http://www.carid.com/dorman/lighter-extension-cord-mpn-56479.html Check your local auto parts store
Aug 19, 2015 | Griffin Technology iTrip Auto Universal...
Black decker dustbuster pivot is not recharging
Black and Decker Auto Pivot Vac #PAV1200W is only for vehicles as this operates off your battery via cig lighter. You have to remove the cig lighter. Also, it will not use A/C outlet even if you have cig socket version in A/C outlet. Did not even vac or have power. I thought that I could use it for inside house and in cars, but it's only for cars. Haven't tried it in my car yet. Thought this would of been good for deep down in couches and stairs, but I guess not. Just saying. It's now off the market I see.
Apr 11, 2012 | Vacuums
Bought the rechargeable light new a couple years ago, used one time for about 90 seconds. Went to use it again, it was dead. plugged in the battery charger into the cig lighter and it worked after 5 min....
First, ensure the charger is delivering voltage using a volt meter. If it is, the battery is probably bad. If you have soldering skills, the light can probably be disassembled and a replacement battery can be purchased from Radio Shack or online.
Jun 29, 2011 | Camping, Backpacking & Hiking
Cig lighter works 4 cigs but wont charge satnav however much i twiddle about with it, help!!
Try checking the fuse inside the charger. Ths may be blown. Have you tried another charger in its place ex. cell phone or radar detector? If works for the cig lighter should charge.
Nov 05, 2009 | 2001 Ford Focus
1989 toyota corolla cigarette lighter doesn't work
The fuse should be beside the accellerator pedal behind a black cover. Should be a yellow 20amp in the middle row, at the end, closest to the front of the car.
Apr 10, 2009 | 1989 Toyota Corolla 2 Door
Can't seem to get my dvd player to charge.
I have this model dvd player and it has worked very well for over a year. Lately it has not had a picture but has had sound when fully charged. When the green light is on, it is charging. When the light goes off, it is fully charged (or should be). I plugged the wall charger directly into the dvd player and it works fine with pic and sound. I think maybe the rechargable battery is on it last legs. I am looking for a longer cig lighter charger cord to reach the headrest so kids can watch from backseat. I will be able to keep it plugged in to charger at all times. Hope this helps!
Apr 06, 2009 | Spectroniq PDV-70X
1991 s10 pickup radio and cig. lighter shrts out
You need to replace the lighter socket. Both of my 1988 S10's had the same problem after a few years of using my cell phone battery charger in the lighter plug. I replaced it 10 years ago and it has been fine ever since. Something in the original socket wears out and causes it to short out when something is plugged in. Good luck!
Apr 01, 2009 | 1991 Chevrolet S-10
Recharging with out computer
yes there are car chargers for apple check out walmart.com
Feb 26, 2009 | GPX MW3837 MP3 Player
Where do I change the fuse for the cig lighter?
You are correct. The fuse is the 15 Amp CIG fuse.
Oct 17, 2008 | 2007 Toyota Yaris
Initial 5820 Portable DVD Player with Screen Logo
18 people viewed this question
Top Initial Televison & Video Experts
mega_mind
Are you an Initial Televison and Video Expert? Answer questions, earn points and help others
