Question about 3M Post-it Digital Notes
I have Post-it(R) Digital Notes Version 4.8.0.310, and I am using the 64 bit version of Windows 7. I have tried several times to upgrade to 5.0 but it will not install. It always stops and it says that it is not responding. I decided to live with the older version, but now, it has a conflict with Ad Muncher, another program that I like. After installing Ad Muncher, when I try to do nearly anything with Post-It notes, I get a message saying that something labeled as 120 is absent from a dll file ( I think that it was iertutil.dll). When I unistalled Ad Muncher, the problem disappeared. It would be nice if I could solve the problem by replacing Post-it Notes 4.8 with 5.0, but it will not install. I do not want to eradicate all of 4.8 in order to install 5.0, because I have way too much information on 4.8. Do you have any suggestions? Thanks, Dean Geuras
3 Suggested Answers
  • 120 Answers
SOURCE: want to remove post-it notes from my pc
Microsoft has those things, well I want it.
If you don't want it, just switch it off from the Taskbar's Notification Area. Then disable it from Startup Programs. Or just uninstall using the Uninstall Shortcut in the program folder in start menu, or through Add or Remove Programs.
Posted on Dec 19, 2008
  • 40 Answers
SOURCE: how do you refill after
The bottom of the purse snaps open for refilling. You do not have to use post it brand but you do have to use the same type of sticky notes, the papers in these dispensers open like an acordian.
Posted on Jan 29, 2011
Can Vista Home Premium be upgraded to window's 7?
      If you're running a 32-bit version of Windows Vista, you can only upgrade to a 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only upgrade to a 64-bit version ofWindows 7. Otherwise, you'll need to use the Custom option to install Windows 7.
      Upgrading from Windows Vista to Windows 7 - Windows Help
      windows.microsoft.com/.../windows7/.../upgrading-fro... Microsoft Windows
    Feedback
    windows.microsoft.com/.../windows7/.../upgrading-f...
    Microsoft WindowsIf you're running a 32-bit version of Windows Vista, you can only upgrade to a 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only upgrade to a 64-bit version of Windows 7. Otherwise, you'll need to use the Custom option to install Windows 7.
    How To Upgrade from Vista to Windows 7 Home Premium ...
Feb 08, 2016 | Computers & Internet
Upgrading windows vista 64bit
Did you download your Win7 upgrade or did you buy a boxed copy? If you have a boxed version, check in the box. My Win7 upgrade came with both the 32-bit and the 64-bit DVDs in the box. Try using the other optical disk in the upgrade package. If only one disc is in the package, contact the source where you got the upgrade. Only the package for installing a new OS (OEM or full version) comes with just the one disc included. For those, you need to specify the type of system on ordering.
If you downloaded the upgrade, you will need to get a different upgrade file and burn it to disc or make a USB installer for that version of Windows 7.
To confirm your current version of Windows, click Start and choose the Control Panel. Click on System and Security and then on System. This page will display the Windows version and append x64 if you have the 64-bit version.
Alternatively, download the Windows 7 Upgrade Advisor, http://windows.microsoft.com/en-us/windows/downloads/upgrade-advisor , and it will confirm if your system is compatible with Windows 7 and which version you need.
I hope this helps.
(even the Windows 8 upgrade came with both the 32-bit and 64-bit DVDs in the box.)
Jan 05, 2014 | Toshiba Satellite Computers & Internet
What is the procedure to install a 32-bit softwares in to my laptop(windows 7,home premium,64-bit) ?
Most programs designed for the 32-bit version of Windows will work on the 64-bit version of Windows. Notable exceptions are many antivirus programs.
Device drivers designed for 32-bit versions of Windows won't work on computers running a 64-bit version of Windows. If you're trying to install a printer or other device that only has 32-bit drivers available, it won't work correctly on a 64-bit version of Windows.
Windows 7 64bit does run programs that will run on windows 7 32bit, see here
How Windows 7 / Vista 64 Support 32 bit Applications
BUT not ALL 32bit programs will run on Windows 7!!! There are many programs that will run on Windows XP and before that will not run on Windows 7. IF you had Windows 7 Pro version (or upgrade) there is a program you can download from Microsoft that will simulate an XP environment to allow programs to run called "XP MODE".
Try to install the 32bit software first. If installation not succeed, it would be better if you first look into a newer version of the program you want to run.You have to consider that a newer version of your program might not be that much more expensive than upgrading to pro, and with the newer version, usually comes newer features.
Hope this help and if helpful RATE please.
Feb 17, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Is it possible to upgrade windows xp professional x64 to windows 7 professional x64
Hello
Yes it is.
Just make sure you download or purchase Win 7 x 64.
If your doing the upgrade you need to have winxp x 64 installed on your pc first.
Jun 10, 2010 | Microsoft Windows XP Professional for PC
Can i convert a 32 bit to a 64 bit
You can use the Upgrade option during Windows 7 installation, which preserves your files, settings, and programs, only if you're currently running a 32-bit version of Windows Vista and you want to upgrade to the 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only perform an upgrade to a 64-bit version of Windows 7. For more information, go to Upgrading to Windows 7: frequently asked questions on the Windows website.
If you want to move from a 32-bit version of Windows to a 64-bit version of Windows 7 or vice versa, you'll need to back up your files and choose the Custom option during Windows 7 installation. Then, you'll need to restore your files and reinstall your programs. For more information about performing a custom installation, see Installing and reinstalling Windows 7‍.
gl_ico.png Notes
  • To install a 64-bit version of Windows 7 on a computer running a 32-bit version of Windows, you'll need to start, or boot, your computer using a 64-bit Windows 7 installation disc or files.
  • If you start your computer using a 64-bit Windows 7 installation disc or files, but your computer isn't capable of running a 64-bit version of Windows, you'll see a Windows Boot Manager error. You'll need to use a 32-bit Windows 7 installation disc or files instead.
  • Windows Easy Transfer can't transfer files from a 64-bit version of Windows to a 32-bit version of Windows. If you're running a 64-bit version of Windows Vista but you plan to install a 32-bit version of Windows 7, you can move your files to an external location manually or use Backup and Restore in Windows Vista. For more information, go to Back up your files and
Apr 08, 2010 | Dell Precision Workstation 490 - MT -...
I'm trying to upgrade from 64-bit Vista to 64 bit Windows 7. When I run the installation disk, I'm getting the following error message, which appears to be contradictory in my opinion:...
I have seen this type of problem before, the only real way around it is to install a fresh copy of windows 7 not to upgrade, you will receive a message that asks you if you want to keep the previous windows in a folder called old windows, from there you will be able to access all your old files and programs, be aware though some programs may not work on windows 7, and you may need to have updated drivers for the systems peripherals. So when you run the windows 7 disk choose clean install and go from there. i hope this helps
Feb 04, 2010 | Microsoft Computers & Internet
Computers & Internet Logo
214 people viewed this question
Top 3M Computers & Internet Experts
Raj Patel
Tom Chichester
james laughton
james laughton
Are you a 3M Computer and Internet Expert? Answer questions, earn points and help others
