Question about RCA RCR350 Remote Control
RCA RCR350 Remote Control Problem - light just keeps blinking
I have tried to reset and reprogram my remote control and the light just keeps on blinking with no programming functionality. Tried yaking the batteries out and pressing the "1" key to reset the chip and no can do.
Any tips?
5 Suggested Answers
  • 8 Answers
SOURCE: RCA RCR312W remaote control
Manual Code Search and Entry 1. Manually turn on the TV
2. Press and hold the TV button The illuminated ON•OFF key turns on and remains on.
3. While holding the component key down, press and hold the ON•OFF key. The illuminated ON•OFF key turns off.
4. After holding down both keys for three seconds, the illuminated ON•OFF key turns back on.
5. Release both keys. The illuminated ON•OFF key remains on. TIP: Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control.
6. Press and release the ON•OFF key repeatedly until your component turns off. Each time you press the ON•OFF key, the illuminated ON•OFF key blinks, and the next
code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component turns off, you have found the correct code.
TIP: Because there are so many codes, you may have to press the ON•OFF key many times-possibly up to 200 times.
7. Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON•OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored!
8. To confirm that the component key is programmed with the correct code for maximum functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your components do not work, try programming the remote with a different code in the list until you find the code that allows the remote to control the majority of your component's functions. Different codes can provide different levels of functionality
Posted on Jul 17, 2008
SOURCE: Codes to program an RCA remote control
my remote will only work the volume. i need to program the remote to use menu to adjust the picture.
Posted on Oct 08, 2008
SOURCE: how reprogram my universal rca remote control
hold the tv button down and keep it down and then press and hold the power button down and hold them both until the power button stays red then let go of both buttons then keep pressing the power button until the tv turns off and as soon as it turns off press the stop button and it should work.
Posted on Sep 30, 2009
  • 125 Answers
SOURCE: My rca universal remote stopped working and it
You may just need to buy new one Dollar store has RCA 4 in 1 Remote with code book for $6.00
Mats has them for $3.95 and up orginal handunits too.1-800-628-1118
Posted on Mar 25, 2010
Forgot how to program their is no code button should give you your answer. Access to code lists and product manual are also provided at the bottom of the web page.
Feb 22, 2011 | RCA RCR350 Remote Control
Won't change channels. Batteries are fine.
The remote does not operate your component?
  • You must put the remote in the correct mode by pressing the corresponding component key (TV, VCR•DVD, SAT·CBL) so the remote knows which
    component you want to operate.
  • Remove any obstacles between the remote and the component. Make sure to aim the remote at the IR sensor on the component.
  • Make sure the batteries are fresh and are properly installed. (See Battery Installation on page 3 of the User Manual). Replace the batteries with two new AAA batteries, if necessary. Reprogramming may be required.
  • Reset the remote. Remove the batteries, then press and hold the number 1 key on the remote for several seconds to reset the microprocessor inside the remote. Release the number 1 key, reinstall the batteries, and press the ON·OFF key. If the LED indicator light turns on, reprogram the remote and try again. If it doesn't light up, replace the batteries with new ones.
This and other details can find in the troubleshooting-the-rca-rcr350-universal-remote-control
I hope this help to solve it (remember to rate this answer) Good luck,
Oct 02, 2010 | RCA RCR350 Remote Control
How to program for panasonic tv?
Code For Model RCR350
Code 1003 for Panasonic TV
Code 1054 for Panasonic TV
Code 1062 for Panasonic TV
Code 1109 for Panasonic TV
Code 1170 for Panasonic TV
Code 1248 for Panasonic TV
RCA Universal Remote Control Programming Codes
Good Luck!
Apr 13, 2010 | RCA RCR350 Remote Control
Haw to input code in remote contol RCA model RCR350 instruction
what's the problem with your remote control?
Take care.
Mar 13, 2010 | RCA RCR350 Remote Control
I have a rca universal remote control and I need a code for a panasonic tv
Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV
Aug 05, 2009 | RCA RCR350 Remote Control
Remote Code for Panasonic LCD TC26LX60C
Try these one should work:
1003, 1054, 1062, 1109, 1170, 1248
# NOTE - If this info was helpful to anyone please click on yes!
Jun 18, 2009 | RCA RCR350 Remote Control
Need codes
Try these codes
RCA 000,006,011,019,027,034,038,044
May 29, 2008 | RCA RCR350 Remote Control
Rca remote
reset this remote
Apr 29, 2008 | RCA RCR350 Remote Control
RCA RCR350 Remote Control Logo
1,458 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
