posted by lmedina74 on Aug 01, 2008
How do you undo the control lock button. It came on by itself and I cannot start the machine?
Thanks
Solution #1
posted on Aug 02, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Press an hold the Drain/Spin button for 3 seconds- the light will go out and you can use your machine.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 01, 2008
There is either a button or a pin that goes into a hole when the door is shut. If the pin gets broken or the button gets damaged the control thinks the door is open. If everything looks ok you can have a service tech bypass the switch. If it works, the switch needs replaced. The part is fairly cheap but the labor can be trouble.
Suggest a new solution for this problem
Post a New problem for Kenmore Elite 45986 Front Load Washer
Email this problem
Email this problem
Can you Help with these Washing Machines problems?
Extraction cycle sounds like a...
Ok, found the rattle after... Answer This...
kenmore elite front load
f 11 code showed up this... Answer This...
tommy walkabout digital.!
how do i disable the... Answer This...
Front Load Washer Kenmore Elite
The clothes are still soaking... Answer This...
kenmore tumble action washing...
when the water empties out of... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
Find Parts
