Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
I can't get my hitachi ultrvision to turn on - Hitachi UltraVision CineForm 55VG825 55" HDTV
  • Hitachi Master
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.....
Posted on Mar 12, 2011
50 inch hitachi ultrvision tv with a thin black line going across..and 2 red,1 green thin lines going vertically tv is 7-8 years old...is this a cheap fix or just get a new tv?
screen connections, not a job for the amiture as it relates to the screen connections on the ribbon, you need to remove screen, then with a large area to work with thats flat remove the screen casing and then remove the boards and then the screen ( paper thin) this is the dangerous part as you can brake the screen or even cut yourself. you need to remove screen and place down on a large flat area (padded flat) and you will see the ribbons on the side of the screen. you need a heat gun or soldering heat gun and heat them up and without moving the alignment push down on them so they stick back down, a roller helps as keeps the air from getting stuck in the seal, after put some heat tape over the connection/s each line relates to a connection on the screen. when refitting put pads that are the right size and shape over the connections before fitting the case, then the problem will not happen again with the screen but like i say its not for the amiture to do as it takes patients to remove screen and you have to keep it level at all times or it will crack.
Nov 28, 2017 | Hitachi Televison & Video
What is the program code for ultrvision tv
0269,0216. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Jan 04, 2016 | Televison & Video
Hitachi TV 51 "
Tv is not turning on....you can hear it click....model # 51zx24k Hitachi...
Jun 19, 2011 | Hitachi 53UDX10B 53" Rear Projection...
My Hitachi UltraVision HDTV won't turn on. The
Convergence has failed. $250 - 300 let a trained tech. do it for you.
Mar 16, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi tv no picture or sound.
my hitachi projection tv 53uwx10b screen is black with no sound or picture when the power button is on
Dec 29, 2009 | Hitachi 53UWX10B 53" Rear Projection...
TV: Hitachi UltraVision no Picture.
Hitachi Ultravision power light on but on picture
Nov 18, 2009 | Hitachi 57SWX20B 57" Rear Projection...
My hitachi tv does not turn on the lamp and temp
Try replacing the lamp. Look in your manual to see what the lamp number is and search the net to find a replacement. lamps are not hard to replace, you can evern go to youtube.com type in how to replace a hitachi lamp and see a video. Hope this is helpful.
Oct 26, 2009 | Hitachi Televison & Video
I have an older Hitachi 36'' Ultrvision TV. It has worked fine for years up until resently. The problem that I am having is I can not get the direct TV signal to come in. The out from the Direct TV box...
Sounds like you have something in the wrong setting that won't allow the signal to get through. If the video 1 line works OK but regular input will not work, that is almost certainly the problem. I would try just unplugging it (turning it off is not the same thing), let it reset for a few minutes; then plug it back up and see if it will reset by itself. hope this helps.
Jun 11, 2009 | Hitachi Ultravision P50S601 50 in. Plasma...
Hitachi 50V500 50 inch
you need to contact hitachi because its a manufacturer defect...its called the light engine if im not mistaken that makes it turn funny colors...about 300 or better to get it fixed or call hitachi and whine and complain till they fix it...
your welcome
Mar 04, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
605 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
