I couldnt find the wifi swithc on my laptop - Computers & Internet
  • Oss279 Mar 12, 2011
    WHAT is exactly the MODEL of your LAPTOP
    You can see it at the back of your laptop with a sticker on it. mentioning part no and Model no.
  • 2,229 Answers
You may not have a physical switch.
Your laptop could just use the Fn + special function key combo.
Press the Fn key (lower left on the keyboard) and the special function key that has a little icon that looks like an antenna. That should turn it on and off.
also, be sure that, in device manager, the wireless adapter is enabled.
Posted on Mar 12, 2011
Tip
GET better wifi signals
I live in the country it is hard to get a signal with my laptop or desk top which is wireless. I have found a solutiom an outdoor panel antenna witha 45db gain adapter booster. i can now pick signals up from almost two miles away from my friends. its very good and works flawless i couldnt get a signal before no matter what i did. Please do not connect to some one you dont have permission to always get permission its to use them to gain access to some one else but not to use or have. FCC rules. please dont do this.in most states. , they are inexpensive and sure do boost performance. great buy..
on Jan 09, 2015 | Alfa Network Alfa APA-L2414 14 dBi gain...
How to add extra wireless devices
Are you referring to adding another wifi router? if so, the easiest thing is to get a switch. Hook the modem to the swithc, then both wirelss routers to the switch.. you can give them the same passphrase so that your laptop or smartphone can swithc from one to the other without an issue. However, if you hook up a router to another router, then the second router needs a static address and the gateway would be the ip of first router. Little more complicated but doable.
Aug 27, 2013 | Computers & Internet
How do i switch wifi on on acer 5750 z laptop
Try going to: start>control panel>network and internet>network sharing center. In the left pane click; change adapter settings. You should see your wireless adapter here. Right click and click enable.
Mar 20, 2012 | Acer Computers & Internet
It was working and suddenly when I press togather the key Fn and F1 on my laptop Fujitsu Siemens Amilo Li 2727 ms2228 with windows Vista it does'nt swith on The WIFI. Thanks to answer me at the adress...
I had that problem, i couldnt switch on my wifi with the fn/f1 keys. The cause was i think a vista update, though im not sure which one it was because the laptop was given to me, and id not been privy to the update history... so i reinstalled vista from the image on the harddrive, pressed fn and f1 and the wifi was activated fine.. a million updates latter i tried it and>> nothing...I tried everything and still nothing lol...I then reinstalled vista (again lol), and then tried it, and>> bingo :) bottom line, find out what update is causing this and uninstall it (if that's possable) or just reinstall vista...now here's the key, there's a new bios update for the amilo ms2228 which rememebers the state of your last wifi comand, and maintanes it, in other words, update the bios, then activate the wifi, and it should stay on, (it did on mine) then go to windows update and reinstall all your updates (assuming you have just reinstalled vista or located and removed the offeding update) a final note, after i had updated the bios, reinstalled vista, , switched on wifi, and then completly updated vista, i could no longer switch off the wifi, which is suppose is better than not being able to switch it on in the first place lol :P
Nov 07, 2010 | Computers & Internet
Hi my Lenovo 3000 wireless switch is in ON position yet the computer, on dignosis, shows 'Turn on the swithc'......unable to use WiFI. Please help
You can also turn on the Wireless switch by pressing FN + F5 to enable the wireless card
For further assistance you can also call LENOVO Technical Support Dept 1-877-4536686
Thanks for using Fixya.
Jul 28, 2010 | Computers & Internet
My daughter has an aspire one and cannot get wi fi
Is the WI FI light on?
There is a manual swithc for the Wi Fi in the front.
Are the driver installed? (Check if you see the wireless adapter in Control Panel > Network Connections)
Jul 25, 2010 | Acer Aspire One Netbook 8.9" Notebook
Wifi problems (iPod G1)
i had experienced that problem with my PSP at the same case,just set your internet connection again and delete all of you history,cache and some data in you iPOD.HOPE I HAD HELP
Jun 20, 2009 | Apple iPod touch
Acer Aspire 5570 wireless
Guys if you are having this issue you should open up the back panel and locate the wireless card and try to reseat it maybe it could be loose and goes on and off with movement. Secondy while youre at it make sure there are no burn marks or damaged saughter however you spell it damages on the wifi board. Third you can try to get a USB adapter from like best buy and since they give you 30 days return policy you can try it and see if you get internet access through it that way .If you do then you can pin point it could be your wireless card or the motherboards controller where it connects to. Also make sure the BIOS wifi option is enabled and working some people have uinstalled the wifi utility from acer and just use the windows built in wireless utility and have had success connection that way . You have acouple solutions and trials to do so get at it and hope this helped lead you on the right track.
Jun 06, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
David Payne
David Payne
