Question about Epson Stylus Photo R1800 InkJet Printer
After cleaning the printhead, when asked to print, the carriage moves to the left and the printer turns off.
  • 6 more comments
  • Laura Boetto Mar 13, 2011
    I have an Epson R1800 with severly clogged nozzles. Using a tutorial we found on this site, we removed the unit and cleaned the nozzles, reassembled the printer taking great care to get everything correct. The printer turns on, when I send a print job to the printer, the carriages goes all the way to the left and the printer turns itself off. I found many references to this occuring in the epson after cleaning on the internet but have yet to find the solution. Can you help us?
    Thank you for your help, but I don't believe this would work on my printer. My printer is an Epson R1800, it doesn't have a ribbon cartridge nor a pause button. Please help!
    I'll give this a try and get back to you. We haven't tried turning the computer on without the cartridges. It's late here so will be a few hours til we can try, but I will let you know. I hope this works!
    That didn't work. There must be something that resets the machine??? Do you have any other suggestions? Please.
    No luck, let me give you a little more information that may allow you to help me.
    After replacing the printhead and powering up the printer, before or after it is connected to the computer, when asked to print the internal printer test page (or any page from the computer), the carriage moves all the way to the left and the printer powers off. We have tried cartridges in, restarts, all of the ideas you have sent us. Please help.
    I appreciate your help, but it appears this is not working either. The carriage does not appear to be jammed, it moves freely. The problem is that the computer carriages moves when you send a print job to the printer, carriage moves to the left, computer turns itself off. There must be some way of resetting the printer. Have you dealt with this problem before?
  • Laura Boetto Mar 14, 2011
    That didn't work, have a new USB cable I tried and several other ones, no luck. Thanks for trying so hard. I wish I could get this fixed.
    I have tried all of the above to no avail. There must be some sort of reset button installed by Epson that needs to be reset or something like that. Any more ideas?
    Genius:
  • 1,570 Answers
Hi
Go to START MENU
Choose Commamd prompt, right click mouse and run as administrator ( For Window vista and windows 7)
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C: drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer and must also turn off your printer and then switch it on.
It will work fine right now
I hope it helps you
Please let me know it you need more help. Regards
Posted on Mar 13, 2011
  • 3 more comments
  • Benjamin Jr Singson Mar 13, 2011
    Also try to clean the print head manually by removing the cartridge and rub the print head into a plain paper with rubbing alcohol until ink flow. Then try the print nozzle for 2-3 times.
    If not, dip the print head into a hot water for 3-5 minutes and then run the prin nozzle for 2-3 times
    A hard reset of the printer may clear the error. Here is how to perform the hard reset:
    1.Shut down the computer. 2
    .Open the top cover of the printer and remove the print cartridges.
    3.Close the top cover of the printer.
    4.Press the power button on the printer to turn the printer off.
    5.Disconnect the communications, (USB or Parallel), cable from the back of the printer. 6.Disconnect the power cord from the back of the printer for one minute.
    7.Reconnect the communications cable to the printer.
    8.Reconnect the power cable to the printer.
    9.Press the printer power button to turn the printer on.
    10.Open the top cover and reinsert the print cartridges.
    11.Close the top cover and print the calibration page.
    12.Restart the computer.
    If not, I suggest you replace the power cord also and change the power supply.
    If not, the carriage of the printer gets jammed, Open the cartridge door and turn off the printer, Now move the print head using your hand froom left to right and from right to left gfot 3 times. Return is to original position and then close the cartridge door and turn on the printer. If should work fine right now.
    If still not working, use a grease oil or WD40 sprayer to clean the carriage. Use you hand again to move the print head from left to right and vice versa
  • Benjamin Jr Singson Mar 14, 2011
    I had experience this long time before and oly now I remember that you try to replace or use USB cable connection and then re-add the printer again. After then it prints fine
    Try to borrow from a friend other USB cable and power cord to check if there are the problems. Usually when printer stops and turn off. It is cause by communication error.
    Try uninstalling the printer driver and reinstall it again and then re add again the printer.
    Try also this printer diagnostic utility that might help solve your problem. http://www.out-of-warranty.com/print-dia...
    Click on blue name PRINT DIAGNOSTIC UTILITY to start downloading
    President:
  • 2,185 Answers
Try to disconnect the printer from the computer and shutdown both (printer and computer) for a minute. Then plug everything back and try to printer again. If this does not work, try to turn on printer, take out the cartridges and restart the printer without them. If the printer ask for the cartridges, put them back and restart the printer. After it initialize, try printing again.
    Brigadier General:
  • 3,513 Answers
Hi
Head cleaning is mechanical process, printing is electrical process. If nothing at all ink out/spray from head in printing process, problem with electricity. Damage board or short circuit at head cable. Check board first, may be some component "burn". It is suggested to contacted Epson customer support before further damage occurs.
Please check this bellow tutorial for more details of print head cleaning:-
http://www.hardwaresecrets.com/article/How-to-Unclog-Epson-Print-Heads/178/1
http://ftp.epson.com/htmldocs/sc880_/sc880_u1/MAINT_2.HTM
However check the link bellow for the user guide to your printer, kindly go through it where it gives detailed instructions of various problems along with cleaning of printhead,may be you have performed something wrong to assemble/install the printer after cleaning the print head or some connection problem.
http://files.support.epson.com/pdf/r1800_/r1800_ug.pdf
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Mar 12, 2011
  • Aparajita Batabyal
    Aparajita Batabyal Mar 13, 2011
    Hi
    Turn the printer off and remove the ribbon cartridge. Once the cartridge is removed, slide the print head all the way to the right side of the printer carriage. Look into the printer, on the bottom left side you should see a small white lever. Push down on the lever to make sure it is still connected, then gently move the lever from side to side a few times. Next, take a hold of the print head and move it all the way to the left, then back to the right. Move the print head left to right five times, then position the printhead into the middle of the printer. Hold down the ALT + PAUSE on the front of the printer. Keep holding these buttons down as you power-on the printer. Release the buttons after the printer emits one long beep. The printer should initialize properly. If you are still having problems, repeat the above steps. If the problem still persists, have the printer taken in to be serviced.
    Hi
    Hi
    Hi
My printer not printing out all the words from a letter I have drafted
You are not very clear in saying what you mean.
Are the words completely missing from the printed doc?
Is it the same for all docs? Are the words there but not very clear? First run printhead cleaning. Its in your driver, probably under maintenance. Pixels in the printhead can become blocked especially if using compatable inks. The wiper on the ink station may have muck on it. To clean it first remove the battery if connected. Ask the printer to print something and as soon as the carriage moves pull out the mains adaptor so it stops in mid travel. Open the cover and slide the carriage fully to the left side. Shine a torch to the right side and you will see the ink station (purge unit). Use a dry cotton bud to gently wipe the small wiper rubber clean of debris. Replug and turn on and see if clear now. If still poor then a new purge unit is required. Basically that's the end of the printer as almost impossible to change the purge on its own (although available). Its best to change the whole print unit as one.That will cure ALL ills. Of course the printhead can be changed on its own. Remove it to see if anything stuck on the base of the head. Don't use chemicals to clean it ,just water and kitchen roll.
Apr 09, 2016 | Canon iP100 Portable Printer
Error 0x 19a0027
Hi Norman,
The Error message usually relates to Printer Failure. However you can try few steps to fix it. ( Hopefully )
Turn off the Printer.
1. Open the Carriage access door.
2. Remove the Cartridges and Printhead ( Printhead is the part on which you install the cartridges )
3. Lift the latch to remove the Printhead.
4. Move the carriage from left to right 6 times and it should move freely
5. Clean the contacts on the printhead with lint free cloth. ( Golden dots at back of Printhead )
6. Turn on the printer and it should say " Printhead missing or not installed/Damaged "
7. Install the Printhead and Cartridges and close the latch and close the Carriage door
8. the printer should go through alignment process
If this step does not fix, You may try calling HP customer support to check for better options/solutions
HP Customer Care : 1-800-474-6836
Regards,
Sean
Feb 10, 2013 | HP PhotoSmart Office Equipment & Supplies
Will not print black despite full ink cartridges have cleaned etc etc
It sounds like a blocked print head. You would need to try another one but before you do. Ask the machine to print something. when you hear the carriage moving kill the power. You can now move the carriage to the left side of the machine. Look into the right side with a torch and you will see two squares with rubber edging. these are the filters to the purge until. The left one is for black and right for colours. You can prise out the left filter and wash it. refit and run cleaning again. If it works great if it does not then a new printhead is the answer.
May 28, 2011 | Canon PIXMA MP540 All-In-One InkJet...
Canon Pixma Mp258 B200 Error
My printer is canon mp258 there was an error B200 . how t fix this?
Apr 07, 2011 | Computers & Internet
My HP Officejet Pro K8600 won't print black. I have changed the printhead, the cartridge. I have soaked the printhead, I have shaken head. I am getting yellow ink out but no black. I have run every...
Materials needed: New empty syringe (big one) Gloves (to protect your hands fromink) Alcohol Paper tissue (to clean the excessink) Empty Plastic bottle (Here you putthe ink from the syringe) Important: Ensure that you have put new blackink cartridge to K8600. Ensure that the printhead arerecognized by the printer or no light alarms. Instruction: Press the Power button to turn onthe printer. Test print in microsoft excel with4 color black/yellow and cyan/magenta. If black only is missing means youhave clogged problem from the host. Wear your globes, prepare thematerials needed. Open the top cover. Press and hold the Resume buttonuntil the carriage moves to the left. CAUTION: Be careful not to proceed until the carriage is on the left sideof the printer. If the carriage does not move to the left automatically, turnthe printer off and back on and then try holding down the Resume button again.The printhead can be damaged if the carriage is not all the way to the left forinstallation. Lift the printhead latch. Lift the handle of a printhead anduse it to pull the printhead black/yellow out of its slot. Put printhead in thepaper tissue upward. Your printer are still ON becarefull not to touch the flex copper circuit. Get your syringe, use this to pullthe ink from the nozzle cap ( see link picture) After the done the syringe method,Insert the printhead black/yellow into its color-coded slot. Press down firmly on the printheaduntil it snaps into place. Pull the printhead latch all theway forward, and then press down until the latch engages. Close the cover. The printer should align theprintheads automatically in a few minutes, printing an alignment page. Print a test with black color only,If it does not print, try to change the Printhead. This is the only solution I foundin my HP k8600 black ink problem._579.jpg
Jan 24, 2011 | HP OfficeJet Pro K8600 Printer
Hi, the magenta ink won't work on my printer hp office jet pro k8600. I have replaced it with a new one and even though is shows that it's full on the ink levels it won't print it at all, I have tried all...
Materials needed: New empty syringe (big one) Gloves (to protect your hands fromink) Alcohol Paper tissue (to clean the excessink) Empty Plastic bottle (Here you putthe ink from the syringe) Important: Ensure that you have put new Magentaink cartridge to HP K8600. Ensure that the printhead arerecognized by the printer or no light alarms. Instruction: Press the Power button to turn onthe printer. Test print in microsoft excel with4 color black/yellow and cyan/magenta. If magenta only is missing means youhave clogged problem from the host. Wear your globes, prepare thematerials needed. Open the top cover. Press and hold the Resume buttonuntil the carriage moves to the left. CAUTION: Be careful not to proceed until the carriage is on the left sideof the printer. If the carriage does not move to the left automatically, turnthe printer off and back on and then try holding down the Resume button again.The printhead can be damaged if the carriage is not all the way to the left forinstallation. Lift the printhead latch. Lift the handle of a printhead anduse it to pull the printhead magenta/cyan out of its slot. Put printhead in thepaper tissue upward. Your printer are still ON becarefull not to touch the flex copper circuit. Get your syringe, use this to pullthe ink from the nozzle cap ( see link picture) After the done the syringe method,Insert the printhead magenta/cyan into its color-coded slot. Press down firmly on the printheaduntil it snaps into place. Pull the printhead latch all theway forward, and then press down until the latch engages. Close the cover. The printer should align theprintheads automatically in a few minutes, printing an alignment page. Print a test with magenta coloronly, If it does not print, try to change the Printhead. This is the only solution I foundin my HP k8600 printing problem.christan_11_1.jpg
Jan 14, 2011 | HP OfficeJet Pro K8600 Printer
Replace print heads. How?
REPLACING HP PRINTER, PRINTHEADS
Follow these steps to replace the printheads in your printer.
  1. Press the Power button (c00636182.gif ) to turn on the printer.
  2. Open the top cover.
  3. Press and hold the Resume button (c01219285.bmp ) until the carriage moves to the left. CAUTION: Be careful not to proceed until the carriage is on the left side of the printer. If the carriage does not move to the left automatically, turn the printer off and back on and then try holding down the Resume button (c01219285.bmp ) again. The printhead can be damaged if the carriage is not all the way to the left for installation.
  4. Lift the printhead latch. Figure 3: Lifting the printhead latchc01290070.gif
  5. Lift the handle of a printhead and use it to pull the printhead out of its slot. Figure 4: Removing the old printheadc01295543.gif
  6. Shake the new printhead at least six times while the printhead is still in its packaging. Figure 5: Shaking the new printheadc01134519.gif
  7. Remove the new printhead from its package, and then remove its orange protective caps. Figure 6: Removing the protective capsc01134520.gif CAUTION: Do not shake the printheads after removing the orange protective caps.
  8. Insert the printhead into its color-coded slot (the label on the printhead must match the label on the printhead latch). Press down firmly on the printhead until it snaps into place. Figure 7: Inserting the new printheadc01290071.gif
  9. Pull the printhead latch all the way forward, and then press down until the latch engages. Figure 8: Closing the printhead latchc01290072.gif
  10. Close the cover. Figure 9: Closing the coverc01290073.gif
  11. The printer should align the printheads automatically in a few minutes, printing an alignment page. If it does not, go to the next section to align manually.
Align the printheadsIf you installed the HP software, use the instructions in the left column below. If you installed a Plug and Play driver or other driver, use the instructions in the right column.
Mar 05, 2010 | HP Office Equipment & Supplies
I have a HP Photosmart C5180 printer. It is not printing purple-instead what comes out is blue. I have done a print test report and it showed the Light magenta and magenta with missing bars and streaks. I...
If your color improved slightly when running the printhead option then doing more should help get better results. Sometime the printheads get really dirty/clogged and running the cleaning option more then once is needed.
If you get a slight line running across the page (from left to right) usually the indicates dust build up on the printhead or ink carriage. The dust acts as a paint brush being dragged across your paper as the carriage moves across the page during printing. You can clean the bottom of the carriage with a Q-tip or purchase some cleaning paper for your printer.
Apr 16, 2009 | HP Photosmart C3180 All-In-One InkJet...
Was printing ok, then the printer stopped and the two KY & MC icons are lit up alongside the lit up 'paper' icon. I have changed 3 cartridges just now and the lights still come up and the printer stops....
Is the print head moving at all?
Turn power off and see if you can gently move the printhead carriage or turn the carriage belt pulley on the left. If it moves freely without the carriage moving. Thats your problem.
There is a rubber mounted belt connector under the printhead carriage that often breaks when the slide is too dry from lack of lubrication.
I called hp to get the part. No part available. so I repaired the part with epoxy. Not an easy fix.
Jan 13, 2009 | HP OfficeJet Pro k550 Printer
Okidata 320/420 printhead not printing aligned.
Clean the large silver rod that runs through the carriage. It is dirty and not allowing the carriage to move as freely as it should. Ideally it should be left dry. Also change the ribbon. The same motor drives the carriage and the ribbon. If it has a bind, the same thing can happen. Hope it helps Ed
May 18, 2007 | OKI MICROLINE 520 Matrix Printer
Epson Stylus Photo R1800 InkJet Printer Logo
90 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
