Question about Minolta EP1031/1031F CS/PRO Copier
I have a ep1031 minolta copier which started to leave blank marks all over my copies. while looking at the drum i could see the ink all over it so i took it all appart and cleaned the drum and the blades. copied about 10 sheets and the first 2-3 sheets were great but started to smear everywhere again and got worse. my drum is all dirty again ??
    Scholar:
  • 177 Answers
The issue you have is that the cleaning blade is worn and you will need to replace the cleaning blade This will fix your issue also make sure the fuser rollers are clean
Posted on Mar 13, 2011
  • aroostookdis Mar 19, 2011
    Are there steps somewhere that indicate how to remove this blade ?
Black marks in copies
Do they move across the page as differtent copies come out?
Feb 13, 2014 | Minolta EP1031/1031F CS/PRO Copier
COPIES HAVE BLACK INK ALL OVER PAGE
Pull out the image unit. have the drum removed check the cleaning blade is it yellow replace it. IF you can fine run ! Clean the drum off be careful no liquids USE a clean brush. NO vacuum cleaner the static electricity from the vacuum cleaner can destroy the Developer sensor (Unless you know how to do it). Remove the Transfer assy. located below the drum (Push down and out From the rear also) clean also
Jan 09, 2014 | Minolta EP1031/1031F CS/PRO Copier
How to change minolta ep1031 drum cleaning blade
It is not hard to do... The question is are you a service tech or just want to do it your self. If you are not a tech, it is best to leave it to someone who knows how to do it. It can & will get ugly fast if your not sure on how to do it......
Nov 16, 2012 | Minolta EP1031/1031F CS/PRO Copier
When I make a copy, I get a blank strip running from top to bottom near the middle of the page?
Do the lines show up when you make copies with the adf and the copyboard glass?If it shows up on both you may need a new OPC drum & cleaning blade.
Sep 02, 2011 | Minolta EP1031/1031F CS/PRO Copier
I have a Minolta CS Pro EP 1031 Printer that makes streak marks
Drum cleaning blade has gone bad. Especially true if the streaks seem to get progressively worse as you run multiple copies. In other words run 10 copies. If the last one out is worse than the first one out it is the drum cleaning blade. Cheap part...around $25
Oct 12, 2009 | Minolta EP1031/1031F CS/PRO Copier
Black marks on pages
Can you stop the copy before the page gets to the fuser section? If you can and the doubling image is there you need to replace the drum cleaning blade and possible the drum as well. If the marks are there after the fuser section the problem is in the fuser. You will have to replace the Upper fixing roller. Good Luck... You may have a hard time finding the parts, this model is old and not a very popular copier..
May 16, 2009 | Minolta EP1031/1031F CS/PRO Copier
My copies are blank. I replaced tonor, but still no ink.
Hello sir; I believe it is time for PM service, that means you need to replace drum, blade, developer, etc.
May 14, 2009 | Minolta Office Equipment & Supplies
Minolta Di3510f
probably your drum is dirty and machine needs cleaning.
Feb 04, 2008 | Minolta EP1031/1031F CS/PRO Copier
Why do I get a line of faint or no copying on the page?
Does this blank line run top-to-bottom or side-to-side, and which direction is the paper traveling through the machine, portrait or landscape?
Jun 03, 2007 | Minolta EP1031/1031F CS/PRO Copier
174 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
