Question about Whirlpool Dishwashers
I NEED TO get information on 2 of your older dishwashers. DU945PWKTo and DU945PWKTo. The information I'd like is: which one is quieter, how old are they? I am in need of a trmporary dishwasher while I am doing a remodel and either of these is available for me now. I just need to know something about each one so I can make a choice. Thank you. Ande
  • 3 more comments
  • ande8 Mar 12, 2011
    ONE IS MODEL NUMBER DU945PWKTo
    SECOND ONE IS A DU943PWKTo (quiet partner II)
    thank you for information. ande
    sorry, I thought your wanted model number,
    #1 FL5105821
    #2 FU0202169
    DID YOU GET SERIAL NUMBERS I SENT?
    THERE WAS A SECOND PART TO MY ORIGIONAL QUESTION. WHICH ONE IS SUPPOSED TO BE QUIETER?
  • ande8 Mar 13, 2011
    THANK YOU FOR YOUR ANSWERS.
  • 4,323 Answers
Hi
Great that you require the information however, as both models are same so please post back with the serial no for both of them respectively for further assistance.
Daniel
Posted on Mar 12, 2011
  • 2 more comments
  • Daniel Scott
    Daniel Scott Mar 12, 2011
    Thanks Ande....still I want the serial nos so that I can tell you exact age for both of them
  • Daniel Scott
    Thanks
    Ande...
    #1 FL5105821:-- This product appears to have been
    manufactured in the week of December
    17, 2001
    #2 FU0202169:-- This product appears to have been
    manufactured in the week of January
    8, 2007
    Hope this helps...please
    post back for further assistance.
    Daniel
    Thanks Ande...
    #1 FL5105821:-- This product appears to have been manufactured in the week of December 17, 2001.
    #2 FU0202169:-- This product appears to have been manufactured in the week of January 8, 2007.
    Hope this helps...please post back for further assistance.
    Daniel
  • Daniel Scott
    Daniel Scott Mar 13, 2011
    Yeah sorry...missed that...the second one though there is not much difference as usually DU series are all quite same
  • Daniel Scott
    You are welcome....
Not cleaning properly was making noise now quieter kitchen aid kud101flss2
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried in vainto clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if the heating element goesbad then that also can mess things up bad... So I would buy new spray arms, and also check out theheating element to make sure it is working... Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 21, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Small amount of water now left in drain - it was never there prior to a replacment of pump that failed. Is this normal? White powedery residue has now appeared for the first time.
Welcome to FixYa.
This is a common complaint following a drain pump change out, particularly when one has an older Bosch and installing the new style/revised outlet pumps.
If you still have your old pump or if you recall observing it, that design usually only had 4 vanes on the impeller to pump the water.
Since then however, Bosch has re-designed their drain pumps to allow them to be "quieter" hence they now have either a 6 or 9 vane ( depending on model ) on the pump impeller, so yes they are much quieter but as a result pump less water in the time allowed.
example...
...So to answer your question it likely is normal and should be of little consequence. but if you`d like you can still get the other style, you just need to know what to ask for but is quite often "special order". Part # 184178.
NOTE - If you live in the Northwest region of the states ( Especially Washington ) often installation for dishwashers include what is know as a "Johnson Tee" air gaps in the wall.
**Johnson Tees were designed for older dishwashers with 1/2” drain
tubing and work better with stronger 4-vane drain pumps (# 184178) instead of
the current quieter 6-vane pumps (# 167082). In homes with Johnson Tees, use
only 4-vane drain pumps (# 184178).**
Hope that helps, let me know if I can assist you further and good luck.
Thank you for choosing FixYa. Please take a moment to rate the info provided for you here today.
macmarkus :)
Aug 26, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
I have a GE Nautilus dishwasher. I recently started hearing a clicking noise during my dishwasher cycle. It seems to becoming from behind the access panel on the left hand side of the machine. There are...
The pump/motor assembly on these dishwashers have a soft food cutter that helps to cut up smal soft food particles. This may be your problem.
These cutter blades can sometimes get loose or something can get hung up in them like a broken piece of glass or some other pieces of trash that they can not handle.
You can access these blades by removing the sump cover near the rear of the bottom of the inside of the dishwasher. remove the bottom rack and take a couple of screws out of the sump cover. you can feel down in the sump and see if there is any trash caught up here or in the blades.
If this is not the problem and you have an older dishwasher - you could have a problem with a loose fan blade in the motor. If this is the case I would run it til it dies. The motor/pump assembly is about $125+. The newer motors are a lot quieter.
If everything is working ok. I wouldn't worry too much about it.
Aug 06, 2010 | GE Nautilus 24" Built-in Dishwasher
Purchase help
My personal choice would be Maytag. They are well built (as are many other brands) but they surpass the other brands in two key areas. They fit more dishes in than other brands (the racks are designed to be far more versatile for loading) and they are much quieter. That said, to install one with the shielding that causes it to be quieter will take a bit longer than a standard install (maybe 1/2 hour more mostly spent reading directions if it's your first) but well worth it for how quiet it is. Good luck and enjoy.
Mar 19, 2010 | Dishwashers
Had the power go out in our house. When power
hello. thanks for choosing fixya. honestly I do recommend that you get a new one. By the time you get your current one repaired you will have almost as much money in it as a new one and you will miss out on lots of things the new ones offer now such as: much more efficient use of power, much more efficient use of water, much quieter. and a much better wash. Regards, J.
Nov 05, 2009 | GE Profile PDW8400J Built-in Dishwasher
We have a Hotpoint Dishwasher HDA3400Go2WW in our two year old home. It has been very loud from the start. We are thinking of replacing it because it is so loud. Is there anything we can do to it to make...
Dishwasher noise is such a pain, especially in a new kitchen that you need to leave just to have a conversation.
There is nothing to be done to make the dishwasher quieter. Upgrading is the way to go. I now own the amazingly quiet LG LDF8812ST which works well for me and is EnergyStar rated. I really did not know the dishwasher was running, and visitors often comment on how quiet it is as we chat around the kitchen table.
But it takes time to get used to a water and energy conserving dishwasher. You need to make sure the arms are not blocked with each load and not use ultra-cheap detergent powder. Also, the plastic items will not dry like the older dishwasher.
Good Luck!
Apr 11, 2009 | Hotpoint 24 in. HDA3400G Built-in...
No water coming in - soap is dry
Check for power at fill valve when it is supposed to fill. If power, check filter in valve. If not clogged replace valve. This is about the only repair I would make on a machine this old. They are really not designed to last more than 10 years. The new ones are much quieter, efficient and clean better. The fill valve should cost around $25 and you can easily replace it yourself.
Jul 05, 2008 | Dishwashers
Dishwashers Logo
47 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
