Question about Gaggia Coffee Makers & Espresso Machines
I tried 3 packets of Cleancaf to descale my Gaggia espresso maker. It still only trickles/drips out. Is there any thing else to try before throwing it away? Thanks, Jim
    President:
  • 1,618 Answers
I don't know what model you have but you can remove the screen and screw in the head ( I am assuming that the problem is at the grouphead), and make sure the screen is clean, if the screen is clean then remove the diffuser and clean it as well. Use the drawing below, it might be different from the model you have, but the head is usually the same.I tried 3 packets of - esworld_1.jpg
Posted on Mar 14, 2011
Replace mother board on gaggia titanium
To replace the mother board, the top cover of the machine has to be removed. I can email the illustrated steps for taking the top cover off as an attachment.
However I am curious to know the following:
1- why this is the only expensive option to fix the machine
2- Is the person who diagnosed replacement of this part qualified to do so.
3- Has the part been taken out of the machine to inspect any visible damage on it like a burn mark or shorted circuits.
4- Is the brew drive system that operates the Brew group is functioning or not.
5- How long the machine was used.
6- Whether the machine was descaled at all and the descaling product used was authentic product (CleanCaf, Brew Rite, Pulycaff or similar product which are sold as descalers but the same are not).
7- I do not support, recommend or sell parts unless I know it is the correct solution to fix the machine..
Jun 25, 2015 | Gaggia Titanium Espresso Machine
No water comes out on ventilate. At first, the water was coming out very slowly, in drips. The doser or grind were not the problem, because even when I switched to Hot Water, it was still dripping. ...
Hi
It should take about 45 minutes to an hour to properly descale the machine. If it only took a couple of minutes you really didn't descale your machine. If you used the powder it has to disolve completly before descaling. The best way to descale is with the descaler in the tank. Turn on the machine and run about 8 ozs of water-descaler through the wand and then turn off the machine. Wait 10 minutes and repeatthe last procedure. Do this until the tank is empty. When done with the descaler, rinse out the tank and put fresh water in the tank and run the whole tank through the wand. Then fill the tank and your ready to go.
Nov 13, 2010 | Gaggia Syncrony Compact Coffee...
Is vinegar OK to descale a gaggia classic?
If you use citric acid on the Classics aluminum boiler you are risking
serious corrosion. To descale an aluminum boiler you need tartaric acid
based descaler.
  • but it is safe to use CleanCaf as a Descaler--Dissolve in water reservoir, run pump.
  • also it is safe to BAckflush the machine with Cafiza/Joe Glo/PulyCaff. NO detergent gets in the boiler. it is impossible.
  • dont use vinegar.
This will help. Thanks please keep updated.please please do rate the solution positively .thank you for using fixya
Mar 20, 2010 | Gaggia Classic Espresso Machine
Water trickle from the portafilter but not the wand?
Check the end of the steam wand clear with paperclip, then descale machine.
Mar 06, 2010 | Gaggia Espresso De Luxe Espresso Machine
Would like to descale I have the packet needed
No need to unscrew anything
Add the descaler sloution to water and pour it into the water tank.
Follow the instructions on the descaler packet for dosage.
Dec 21, 2009 | Gaggia Classic Espresso Machine
De-scaling
Try doing descaling with a descaling product , like the ones below:
Urnex Cleancaf Coffee Maker Espresso Machine ...
$9.99 - DBROTH
Miele Coffee Machine & Steam Oven Descaling ... $20.55 - Totalvac.com
Apr 19, 2009 | Keurig B60 Coffee Maker
Steam blowing out of group head
Were you using cleancaf to descale? If so, it is not a strong enough descaler. Use Dezcal. or a Dezcal cleancaf mixture. The two work great together.
Make sure you get some descaler in the solenoid area by turning on and off the coffee button.
Hope it works out for you.
Espresso Parts and Cleaning Supplies
www.CeriniCoffee.com
Nov 12, 2007 | Rancilio Silvia Espresso Machine
Little pressure
Have you been descaling your machine? If not, there you go, the calcium buildup is clogging your group head. It might be too late depending on how much buildup there is. Try descaling first and see how that works out. Then descale one a month for three months then go on to the normal cleaning schedule of every 2-3 months.
Espresso machines information and cleaning supplies
www.cerinicoffee.com
Nov 07, 2007 | Gaggia Espresso De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
138 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
