Question about Sew Pro ZZ401 Sewing Machine
How to thread a bobbin on a SEW PRO ZZ 401? - Sew Pro ZZ401 Sewing Machine
kent581
  • 87 Answers
SOURCE: Upper thread knots up with bobbin thread when sewing a stich
Thread test
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test, then let me know, we can go to step 2. If not, try different spool of thread, same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Thread knotting on the bobbin can be a lot of things but here's some guidance:
Tension:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on toip and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Jamming bobbin case:
If it is damaged from turning out of place once, it could have rough spots on it that makes the thread hang on it, and keeps making it turn over and over. Use a finger nail board (fine sanding) and smoothall rough spots. Then reset the bobbin case taking care to put the notch in the bobbin case in alignment with the proper spot in the machine (basically 5 o’clock) when looking at the round area where the bobbin case goes.
Posted on Mar 18, 2009
  • 22 Answers
SOURCE: I just purchased the sew pro portable zig zag
Maybe the drive wheel is disengaged. Some machines have you pull out the wheel on the right to wind a bobbin and yours might be pulled out. Try pushing the wheel back in to engage the machine.
Posted on Nov 10, 2009
  • 980 Answers
SOURCE: Touch & Sew zig-zag model 758 - bobbin thread
email me for retiming instructions and remind me of your make, drivewithken@blueyonder.co.uk
Posted on Jan 09, 2010
  • 108 Answers
SOURCE: I need the Manual for Sew Pro ZZ-401 Zig Zag
try at www.ifixmachines.com
Posted on Feb 15, 2010
  • 3 Answers
SOURCE: I need threading instructions and threading bobbin
Go here http://www.topinnovations.com/sewpro/archived/SP-402/pdf/SP-402_Manual.pdf
Posted on Jun 10, 2010
How do you thread the needle for the Sew Pro ZZ-401
have answerd this on another question befor you should look it up on here
Sep 05, 2012 | Sew Pro ZZ401 Sewing Machine
Euro-Pro # 361
try a new needle
try adjusting the top thread tension
make sure the bobbin is inserted correcty in the bobbin case
also possible that the machine could be out of time & would need to be serviced
Mar 16, 2012 | Euro-Pro Sewing Machines
I have a euro- pro model 385x. Every time I try to sew, the needle jams and the bobbin is surrounded by thread. I have tried loosening the bobbin as well as tightening it but to no avail. I get a big...
The problem is likely the threading. Double check the threading, look twice or three times at the diagram. Even me, a tech sometimes threads a machine or serger wrong.
Derek
Jan 17, 2011 | Euro-Pro 473
Hi...i have been having trouble with my bobbin thread bunching up really bad underneath and causing the machine to seize up when i try to sew...it starts to do this just after a few stitches...i make sure...
Always remember that it is the opposite of what you think, it is your upper thread that is not threaded right, not your bobbin. Once you thread it right, you should be okay. You can buy a manual at sew4less.com for about $14.95
Jul 22, 2010 | Euro-Pro Sewing Machines
I'm a newbie trying to learn how to sew on a 401 singer. My first problem is thread tension. Can't seem to get it right and the second problem is the bobbin won't sit right. I'm sure the problems are...
Are following these instructions? http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_401_threading_diagram.htm
Note: always thread a sewing machine with the presser foot up and make sure the bobbin thread is feeding from the bobbin as indicated in the manual.
Tension is usually around 4.
You need the right bobbin for this model: Class 66.
Mar 06, 2010 | Singer Sewing Machines
I just purchased the sew pro portable zig zag sewing machine model zz 401 and it won?t work, the pedal makes this funny sound and the machine isn?t working. What do i do? I tried everything and tried...
Nov 09, 2009 | Steam Fast ZZ-401 Mechanical Sewing...
Machine won't sew
Change the needle and be sure the flat side is to the back. Rethread the machine. Remove and reinsert the bobbin. Hold the top thread and turn the handwheel to see it the top thread will pick up the bobbin. If yes, it should sew ; if not, it is probably out of time and needs to be seen by a technician.
sewman7
Jul 15, 2008 | Euro-Pro Shark 60 - 384
Sew Pro ZZ401 Sewing Machine Logo
537 people viewed this question
Top Sew Pro Sewing Machines Experts
Steve
Jamie Sewell
Level 1 Expert
ray gallant
Are you a Sew Pro Sewing Machine Expert? Answer questions, earn points and help others
