Question about LG WM-2277HW Front Load Washer
Machine will not turn on, light up, etc - LG WM-2277HW Front Load Washer
  • LG Master
  • 8,220 Answers
Check this puppy out. It might be the culprit.
WM2277 service manual
And some notes
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 12, 2011
Why are lights flashing but machine not working?
It can be a number of things. The buttons need cleaning, a bad solder joint or broken wire, a faulty IC on the control circuit board, the circuit board with the buttons could be loose and not making correct contact, etc.
Only way to know is take it apart. You will need a good flashlight and a long straight screwdriver to get to some of the clips. It is NOT an easy task. Look for tutorials on youtube, etc.
May 06, 2014 | Keurig Elite B40 Coffee Maker
I have a BEKO 61631 S nothing comes on ,no lights etc
The main power supply regulator board [SMPS] is faulty. Contact any service technician. Gopakumar Gopalan Google
Mar 02, 2014 | Televison & Video
I have a miele w526 wash machine .water leaked out under neath machine and 2 lights on side came on .check inlet and check drain .i turned it off removed clothes and tilted it forward and more water was...
In the bottom of your machine the is a tray in the tray the is a float, if the machine leaks the float lifts and hits a switch activating the two light on the facia. The is a leak either in the machine (sump hose) or around the machine drain etc. By tipping the machine you are emptying the tray thus allow it to work. You will need to find the cause of the leak. My best guess is the sump hose has been damaged by hair clip or pin. You may need to remove front panel to check hose etc.
Apr 09, 2011 | Miele W526 Front Load Washer
When machine is first turned on it will run till bin is filled and it cuts off, but will not restart after ice is removed from the bin.This os a hoshizaki commercial ice machine
Remove front panel, look at controler,(where the blinking lights are) there should be a sticker on the back of the panel that tells you what the problem is by how the light flashes. IE- if light flashes 2 times, stps, flashes 2 times,etc, etc
Oct 08, 2010 | Microwave Ovens
My washer did not drain and start to beep every second
Hi just read your posting.If your machine is beeping then a series of lights will be lit and these lights will be in a row of 8 lights.Starting from the left to right on the row which lights are lit when the machine is beeping,Is it the 2nd and 4th or the 1st and 7th ---etc---?Try this also if your machine is not draining.Bail some water out by hand from the machine ,enough to lean the machine back so you can look under the machine.Now when you can see under the machine ,look to the front right and you will see a black fan.This is your pump.Now turn the fan a few times to loosen the pump.The fan should turn freely.Now put the machine back on its feet and select a spin cycle and push start.The machine should start to drain.Please reply on how you got on and with the information on the lights that are lit.Looking forward to your reply.
Oct 03, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel WL80T65D washing machine won't fill or spin
Hi just read your posting.Now when the red spanner light was flashing were there any other lights that were on.If there was then they will be in your cycle selection row.This row has 8 lights on it.Starting from left to right what lights were lit?Is it the 1st and 4th or the 3rd and 7th ---etc---?Please reply with additional information on the questions and I can help you rectify this problem.
Jul 10, 2010 | Fisher and Paykel Washing Machines
WD440 drying high heat and 0n/off light flashing
Just had the exact same problem and think I may have solved it. even turning power off didn't solve it. I think what happened was that the programme had been interupted while drying. I tried everything to get machine to work afterwards but only the following worked - while lights are flashing put back to the same time I had set to dry (60) in my case and turned the dial to M for dry high heat light goes off after a short while - leave for 5 mins then press off. machine will make a noise for a short while then stop.
If this happens then machine should be back to normal.
this is same for both posts I guess.
Feb 03, 2008 | Hotpoint Aquarius WD640 Front Load...
LG WM-2277HW Front Load Washer Logo
53 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
