Question about Panasonic SC-PT660 Theater System
How do I resynchronize my 5 trays in the DVD player portion of a Panasonic SA-PT660.
  • donner908 Mar 26, 2011
    If there was a manual available I would not have posted here.The only manual I have seen a clue to exists in Argentina.
    Brigadier General:
  • 3,513 Answers
Hi
Sounds like the timing for the drawer has been knocked out of alignment.You can take top off to remove the discs...the timing can be realigned( assuming there are no broken parts). The trays can skip gears and sometimes be returned to their alignment but usually the plastic breaks easily and some important tab gets broken off unplug the unit for a minute, that is a "reset" or sometimes there is a tiny hold with a button inside, but its usually got "reset" written somewhere next to it If all else fails, look for the SAMS photofacts or the service manual, one of the authorized service centers will have one. Panasonic makes excellent equipment usually made to be fixed .The best way to re-align the timing is top obtain the service manual. Here, it will give you detailed instructions on what marks to line up....you may be able to get a service manual from UED.net...They are a Panasonic parts dist.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Mar 13, 2011
I had to replug things in for my dish and unit sat sidewards to get to plugs. It now says locked and can eject disc, select source. Help
Try this:
Press and hold [?] (Stop) on the main unit and [>10] on the remote control until "INITIALIZED" disappears from the TV. Turn the unit off and on again.
All settings should return to the default values.
Not saying it will work though!
Not
Dec 31, 2015 | Panasonic...
How to connect a blue ray player with the sc pt760 sound system with dvd?
According to the models you provided it looks like the DVD player has only HDMI out and the sound system you have does not directly support that. I would suggest purchasing a HDMI audio extractor so that you can covert the digital signal from your blu-ray to an analog signal. However, there are other ways of doing this. If you provide me with your TV that you use I might be able to advise another work around.
Go on google and look for "hdmi audio converter" or "hdmi audio Extractor".
Make sure to look at review to determine the quality of the product and decide what device fits your budget.
Nov 23, 2015 | Panasonic...
Panasonic sa-pt770 will not power on
When power is applied do you get any LED light or display that shows?
Dec 27, 2014 | Panasonic Sa-pt770 Receiver
Dvd drawer stuck in player
Most CD\DVD devices have a manual "eject" pin hole near the front of the door that a paper clip would fit into.
Be sure the device is unplugged before attempting....
Jun 09, 2011 | Panasonic Home Theater System System
How and where can i get a new panasonic dvd for my home theather system. model number sc-pt660. the disk changer does not open and close.
Considering that this unit comes as a bundle it wouldnt be profitable for stores to carry the parts seperatly. The best bet here would be if it still is within the 30 return policy then to take it back to the store you purchased it from to swap out for another. Since Im sure this isnt the case or you would have already done this you can try to save a dime by searching ebay for part systems and repairing or replacing the problem part in your tray (specifically being the tray motor). Theres plenty of tutorials for similar products found on DIY.com. Heres a link...
http://cgi.ebay.com/Panasonic-SA-PT660-5-disc-DVD-player-SC-PT660-AS-IS-/370503039935
May 05, 2011 | Panasonic Televison & Video
Resubmitted: How do I resynchronize my 5 trays in the DVD player portion of a Panasonic SA-PT660. A manual seems unavailable or I would not have posted here.The only manual I have seen a clue to exists in...
  • Here is a manual that will server your purpose. It is not the exact same model manual to a 'T' but I looked it over real well and it is for your unit too. Your gonna go down to page 16. This is for a model SC-PT660. same unit really.
http://static.highspeedbackbone.net/pdf/Panasonic-SC-PT660-Manual.pdf
Regards, Tony
Apr 27, 2011 | Panasonic Televison & Video
I start up my panasonic sa-pt660 and it makes a lot of ticking noises and give me a chgr err. I tried restarting it. I also tried switching it to the radio and dvd player from the remote and the console...
OK I fixed it. One of the CD's had gotten stuck between trays in the loader. I pulled out a few CD's by forcing open the trays gently. However even after removing as many cd's as possible one was still stuck. 1. Remove screws holding cover plate on in back and sides. 2. Remove cover. 3. Lift face plate latches and lift over top of unit. Remove serial cables from face plate and place aside. Remove screws from back of CD tray unit and bend back metal tab with flathead screwdriver. Lift CD unit up on one side so you can get your fingers up inside underneath and push stuck cd towards tray openings. You can gently force top few trays out. You may need to shake unit so that stuck cd reaches open end. Pull out CD. 4. Replace faceplate and connect serial cables. Plug in power cord, power on unit and make sure trays will eject normally. 5. Put it all back together!
Oct 29, 2010 | Panasonic SC-PT660 Theater System
Inadvertly put a 6th cd in a 5 cd panasonic sa-pt660. the error message says chgr error and can't get the extra cd out...thoughts
take the cover off. couple screws on back and 6 or so on the bottom.pay close attetion to the screw length and do not mix them up.you should be able to see and remove the disc by mechanically moving it and the mechanism around.be careful not to force anything.they are very fragile. cheers
ed
Jul 03, 2009 | Televison & Video
Panasonic SC-PT660 Theater System Logo
225 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
