Question about Health & Beauty
What recommended plug gap and air gap for coil on goped sport
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 346 Answers
WWW.ALLDATASHEET.COM. HAVE A NICE DAY COLIN.
Posted on Mar 14, 2011
What is the air gap on the toro 20005 serial 250067677
you mean coil air gap ??? spark plug gap ??? should of included the engine numbers because that's not made by Toro !!!
.011 is the coil gap
.028 is the spark plug gap
Oct 12, 2014 | Garden
My goped sport engine shut off and wont start again, what I can do?
Try the steps on this website. http://goped.8m.com/racingpages/troubleshooting.html
May 30, 2014 | Go Ped GSR Sport Gas Powered City Scooter
My 5 hp briggs stopped running. No spark. took recoil off to reveal a rotten coil with wires rotted off. cleaned off the flywheel and replaced the coil with one from Napa. The engine does not have points...
Did you set the Air Gap correctly, it should be .020 inch. If the Air Gap is correct and you cleaned the pickup magnets, you should be getting spark. I have different color coded plastic sheets of the correct thickness to set the Air Gap on different engines. You could use a use a side panel from a plastic soda bottle (Mt Dew, Pepsi, ect) Place it between the Flywheel and the Armature/Ign Coil. Allow the magnets on the Flywheel to pull the Armature/Ign Coil together and then tighten the Armature/Ign Coil bolts. Carefully turn the Engine while pulling the plastic from between the Armature/Ign Coil Pickups. The Armature/Ign Coil is now properly set.
Generall speaking for a gasoline engine to run you need 3 things. (1) Spark, (2) Gas and (3) Air.
I hope this is helpful. UAW 974
Jun 25, 2011 | Sport & Outdoor - Others
No fire to spark plug
You will need to check the magneto air gap. That is the distance between the magnets on the flywheel and the legs on the ignition coil. A standard setting is about .010"-.012". That is about the thickness of a standard business card. You will have to remove the cover(s) to access this. The two items cannot be rubbing each other. The smaller the gap, the stronger the spark. Coil failure is rare but it does occur. Also, check the wiring on the On/Off switch and the subsequent wiring going from the switch to a terminal on the ignition coil. The problem is either in the air-gap, the coil, the associated wiring, or the plug.Process of elimination will get you there. Make absolutely sure you aren't getting any spark. A spark-tester is recommended for this purpose.
Dec 02, 2010 | Echo Garden
My scooter starts runs good then dies
Replace the battery, after sometime the battery starts to lose it's initial capacity.
For battery replacement go to Goped.com, select your scooter model, then click replacement parts and find the batteries on the part list.
Aug 02, 2010 | Go Ped Know Ped Goped Push Scooter
My mo ped stutters at high speeds
Take off Air filter, look inside the carb and pull throttle all the way, the circle should be fully open, if not it may not be getting the full amount of gas it could be, Clean the carb as well, take it apart and clean the mesh filter, To check your plug, just unscrew it from engine, put the cap on the plug, place the tip of the plug on something metal and pull start the engine to see if its sparking. I think you have a carb problem though, clean it and clean your filter and you should be good. If its a stock engine on a goped sport than you should mix 3.2 ounces of oil per gallon. Hope this helps
Apr 10, 2010 | Go Ped GSR Sport Gas Powered City Scooter
CONTACT BREAKER GAP FOR HONDA ES3500 GENERATOR SPARK PLUG GAP.
Recommended spark plug is BPR5ES (NGK) W16EPR-U(Denso)
Spark plug gap is 0.7-0.8mm (.028-.031in.)
Air Gap for your ignition coil is .4+-,02 mm(0.016+-0.008in.)
Nov 16, 2009 | Electrical Supplies
I need coil and spark plug gap settings for echo hc 1500 type E2 hedge trimmer.
0.026 inch, or 6-8 mm is the plug gap.
The ignition coil air gap range is 0.012 - .016"" or .3 - .4 mm. This is the gap between the flywheel and the ignition coil.
An easy way to gap your coil is use a normal business card between the coil and flywheel, tighten the screws and remove the card.
Oct 23, 2009 | Echo Garden
How do I change spark plugs on a 2002 Mitsubishi Montero, and how long should they last? Thanks.
You have to remove the upper intake manifold to get at the wires and plugs. Mitsubishi recommends 60,000 miles for spark plug replacement, if you look in your owners manual they also want you to replacet the spark plug wires also. Timing belt also at 60K
Jul 13, 2009 | 2002 Mitsubishi Montero Sport
Once i Turn the throttle my goped turns off
it may be over fueling if you have turned the jet id sugest hold at full throttle and adjust jet whilst running it on full power
Jan 25, 2009 | Go Ped Know Ped Goped Push Scooter
Health & Beauty Logo
87 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
