Question about Casio FX-9750GPlus Calculator
How to find T critical value - Casio FX-9750GPlus Calculator
I want the timing belt marks?
Buy cheap shop manual for full instructions, including torque values. No one can help you when you don't tell us what you are working on, and even then, please don't trust strangers for this CRITICAL information.
Jun 12, 2015 | Cars & Trucks
How to find the critical value on a fx-115es plus?
Critical value for what? In what context? Nuclear physics? Optics? Mathematics?
Apr 16, 2014 | Casio FX-115ES Scientific Calculator
Set timing install timing chain 3.3 eng.
This procedure is so critical I would advise you not attempt this without a shop manual, available cheap at most parts stores. You must remove many parts which must be reinstalled using the correct torque values.
Apr 09, 2014 | Dodge Caravan Cars & Trucks
How do you set a resistor to 2200 ohm
Connect two resistors in serial eg 1kOhm +1.2 kOhm. You may not need exact 2200 assumung that standard resistors tolerance is 5% - check with Ohmmeter if it's between 2,11 and 2,32 kOhm. But if it's special and value is critical then get trimmer (small adjustable resistor) and adjust value to Ohmmeter indication. Watch out required power.
Mar 01, 2014 | Gardner Bender GB GMT-312 12 Range Pocket...
What is the code reading u1000 traction
Hi there:
DTC U1000 Class 2 Data Link
These DTCs set when the control module does not receive a message that it was expecting from another control module, and does not know which control module did not send that message.
Modules connected to the class 2 serial data circuit monitor for serial data communications during normal vehicle operation. Operating information and commands are exchanged among the modules. When a module receives a message for a critical operating parameter, the module records the identification number of the module which sent the message for State of Health monitoring. A critical operating parameter is one which, when not received, requires that the module use a default value for that parameter. When a module does not associate an identification number with at least one critical parameter within 5 seconds of beginning serial data communication, DTC U1000 is set. When more than one critical parameter does not have an identification number associated with it, the DTC will only be reported once.
Hope helps.
Sep 27, 2012 | 2005 Chevrolet Equinox
What size fuse would i need to replace in a emerson microwavw mw#8992rd
It is critical to use exactly the same fuse type and value that was taken out.
Mar 04, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
Explain 1 divided by 0
In mathematics, a division is called a division by zero if the divisor is zero. Such a division can be formally expressed as a / 0 where a is the dividend. Whether this expression can be assigned a well-defined value depends upon the mathematical setting. In ordinary (real number) arithmetic, the expression has no meaning, as there is no number which, multiplied by 0, gives a (a?0).
In computer programming, an attempt to divide by zero may, depending on the programming language, generate an error message or may result in a special not-a-number value (see below).
Historically, one of the earliest recorded references to the mathematical impossibility of assigning a value to a / 0 is contained in George Berkeley's criticism of infinitesimal calculus in The Analyst; see Ghosts of departed quantities.
Sep 03, 2010 | Computers & Internet
Need value of capacitor on the first USB port missing from computer
that is likely just a bypass capacitor across the 5 volt line .. its value is not critical .. a 0.1 microfarad ceramic should be fine ..
Mar 01, 2010 | Acer Aspire 5335-2257 Notebook
Philips 28inch tv problems getting it to turn on!!!!!!!
In your set there are some more caps that have become thermo sensitive. You can find these with Freeze Spray and a heat gun by using the technique of heating and cooling to provoke the fault. Since your set works hot, freeze the suspect caps, and then turn on the set. While the set is running, carefuly heat them one at a time until you get the failure.
Any electronic device should reliably work from turn on, through to shut down for any period of time. If there is a characteristic change, then there is a fault. The exception is for critical instruments where the instructions indicate that there is a warm up period.
The main areas of consern in your set for this type of fault would be the horizontal output stage, vertical deflection stage, pin amp area, and especialy the power supply area.
As for capacitor specs, you can use a higher rated voltage. In fact a higher voltage rated cap is better for its lifespan. As for the uF of the cap, for bypass applications and for common ripple filtering this is not critical. Only in circuits that use the cap value for pulse width or in resononance for an application the value will be critical. In the case where the cap is in series with a device that is dependent on the accuracy of the cap value, then the proper value is best to use. The cap voltage is not critical in these cases.
What is also better with caps is to use the high temp rated ones. We use 105 Deg Cels rated caps with all replacements. We try to us higher rated voltage as long as the cap will mechanicaly fit in to the required position.
With experiance, time, and patients your set is easily fixable.
Jerry G.
Nov 01, 2007 | Philips 28PW6506 28" TV
Casio FX-9750GPlus Calculator Logo
761 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
