Question about RCA Televison & Video
Rca tv modle #27v414tyx8. wont turn on. the red light next to the power botton comes on but no pic
  • RCA Master
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Mar 12, 2011
61"RCA Scenium modle number d61w136d When turning
You are on the right track, if the lamp is not lighting bright enough it could do this exact thing, the three tries is standard on RCA products, called the 3 strikes and your out---set will try 3 times to make it on and then shut down.
The color wheel while possible usually makes a high pitched fan like sound and with lamp out you should be able to see it to know if missing parts of the wheel or shattered.
12_18_2012_8_04_57_pm.jpgtypical color wheel.
Dec 18, 2012 | Televison & Video
My tv wont turn on when u push the power button no pic or volume comes on and the power button just blinks
Different possibilities:
1. Bad hv circuit (flyback)
2. Bad connections on flyback & the little fuse next to it
3. Bad fuse near tuner
4. Bad picture tube
This tv is known to have any of these problems.
Apr 28, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power comes on but no pic tv modle is lg 32lbyd the light on the frount flashes 5times green then one red
Power supply board is dead.Replaced the power supply board.Tries Shopjimmy.com,Ebay.com for the power supply board part.
Feb 15, 2010 | LG 32LB9D TV
We have an RCA TV. We have a One for All remote
switch tv on / point remote to tv /hold down red button at top till light comes on press corrispondin tv button / then red continues till set switch off
press tv button then any number set should work
most all in one codes to corrispond with ur set are on the internet/just type set such as sony /modle number and ask for code
good luck
Aug 25, 2009 | RCA Televison & Video
RCA 32V434T Flashing Red Light
Flashing led..in protect mode..internal shorted component.
Aug 14, 2008 | RCA F32450 32" TV
Sony bravia tv
Solution is simple....
First, unplug power cable from the back of your TV. You will notice the flashing light is still flashing. Don't worry, go to the Second step.
Second, keep pressing on the POWER button, located on the panel at the top of your TV, to shut off your TV. This will stop the flashing light from appearing.
Third, Plug the power cable back onto your TV
Fourth, press the POWER botton ONCE, using the same button used in the Second step to turn your TV back on.
Fifth, you will see the POWER light comes on, as normal.
Sixth, using your remote control, press the green button to turn on. Your TV should work as normal.
Jun 08, 2008 | Televison & Video
MY RCA TVE WONT TURN ON
Open up the front and check for fluid under the CRT circuit boards. The one on the right (as you face your TV) is the blue one. For some reason, the diaphram for the glycerin in the blue optic is on the back side and leans down. It tends to leak and spill on to the circuit board below.
Tell tale sign is the pool of fluid when you access the front chassis. Pull off the speaker grill and shine a flashlight on the inside underneath the CRT circuit boards and look for the fluid. Glycerin doesn't dry. TV is powering off most likely to protect itself from the shorts.
Dec 28, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
RCA 32v434t
Has anyone confirmed what the problem is? Mine wont turn on. The red light next to the power button just stays lit when pressed.
Oct 22, 2007 | RCA 32V420T 32" TV
Televison & Video Logo
204 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
