Question about Pegasus Technologies Two-Piece Round Toilet by Pegasus - 15 3/4 Inch Bowl Rim Height
Handle broke on toliet model#840-565 looks like I need to replace the plastic piece in side the tank where the handle attaches to. where can I get these parts
For Pegasus toilet parts, try the parent company Niagra at 1-800-831-8383
Posted on Aug 20, 2012
    Genius:
  • 1,739 Answers
You can go to your nearest Home Depot or other retailer that carries plumbing supplies. You may not find a Pegasus bran trip lever but there are a number of universal or fit-all makes on the market.
Here is a link to Home Depot's on-line selection:
http://www.homedepot.com/undefined-Decorative-Toilet-Trip-Levers/h_d1/N-5yc1vZ1xg1Zbahx/h_d2/Navigation?langId=-1&storeId=10051&catalogId=10053
If you choose to visit a retailer it will be easiest to remove your trip lever and take with you to assist in finding a suitable replacement.
Posted on Mar 12, 2011
  • lindamccarle
    lindamccarle Aug 20, 2012
    I did not find any Pegasus toilet trip lever parts on the Home Depot web site. And a trip to the store was also unsuccessful.
  • James Ferrer
    James Ferrer Sep 18, 2012
    A call to 1-800-831-8383 Niagra Conservation was the way to go. Chris at the company will mail me a handle and pivot pin for free. Thanks for the tip Linda!
Replace door handle
You must be talking about the door handle itself. The rod connects the door handle to the door latch. The plastic clip when snapped onto the rod will keep the rod from coming out of the hole in the door handle where it attaches. Is it the handle that is broke or the clip?
May 23, 2013 | Chrysler 300M Cars & Trucks
Where can I find replacement parts?
home depot etc, most hardware stores.
Mar 30, 2012 | Home
98 Pontiac Trans am automatic trans...
The front of the handle has a large "U" clip. Use a screw drive and pry the clip out. It's a lot easier to do when the shifter is pulled all the way back to "1" or "2" but is doable in park still. The handle will then pull up. There will be a plastic piece in it that pushes down to release the lock in the shifter assembly. If when you push the plastic piece down it doesn't release the lock you will have to remove the shifter cover and take a look inside, to see what broke. It may require replacing the whole shifter assembly. You should be able to find the complete assembly used for fairly cheap.
Jan 02, 2010 | 1999 Pontiac Firebird
Passenger side door handle inop will operate from inside
I had this happen to me on the drivers side. I had to replace the entire door handle assembly. Getting the door panel off and removing the window glass was relatively easy. The biggest problem I had was working in such a confined space once I had access, the handle is up in a tight corner. After I had the handle off I saw what the problem was.. just a tiny piece of plastic that had broke. I super glued the piece back on, which worked for a week and then broke. So I looked into ordering a new handle, which was way expensive and would need to be painted, so instead I went to the junk yard and got luck with an intact hand that was my Buick's silver color. I installed the handle in the Park Ave and I haven't had a problem since. Good Luck sir.
Aug 15, 2009 | 1999 Buick Park Avenue
The outside door handle doesn't work but the inside one does what do I need to replace on an 96 f 250?
You should open the door first...take the interior trim panel off, access the "innards" of your door. It could be as simple as a clip that needs to be reattached or replaced or it could be the handle itself. Open up your door and move the handle and watch the attaching points to make sure it's all attached and in the correct number of pieces...
If you need help removing the door panel we can help you with that as well. (usually the screws are around the inside latch and behind the door courtesy lights.... let us know how it goes!
K
Jul 30, 2009 | 1996 Ford F250 Crew Cab
2000 dodge intrepid driver door latch broken. When we take the door apart, there is a plastic piece that broke that attaches the handle to the rod that pulls the latch. It does not look like there is an...
We purchased a door latch to replace ours from Dodge. It came with instructions as follows:
Instruction Sheet
Front Door Handle/Bezel Replacement for LH
1. Remove the front door trim panel using the procedures outlined in Section 23 of the appropriate service manual.
2. Place door trim panel on a clean work surface. Drill the mounting bosses' heat stakes, which attach the existing door handle/bezel to the panel, with a 21/64-drill bit. Take extra care to only drill in the center of each heat stake.
3. Remove existing handle/bezel from trim panel.
4. Clean the back of the trim panel of plastic fillings.
5. Seat the new handle/bezel into location.
6. Place the push nuts onto the handle/bezel bosses.
7. Use a 10 mm socket to install the push nuts all the way down on the mounting bosses to secure the handle/bezel onto the door trim panel. Using a wiggling side-to-side motion may be helpful.
8. Install the lock switch from the original handle/bezel to the new door handle/bezel.
9. Reinstall the door trim panel using the procedures outlined in Section 23 of the appropriate service manual.
Hope this helps.
Jul 02, 2009 | 2000 Dodge Intrepid
Need plastic handle on Rival Crockpot lid.
easy fix go down to your hardware store and buy a big wooden knob (like you would put on a cabnet to open it) it will even come with its own screw for .99 ! . you will have to snap off with a plyers and a screwdriver whats left of the old knob from the lid . but this fix works great and looks good too !
Mar 25, 2009 | Rival 5070 7-Quart
For what it's worth, when the handle on my mother-in-law's crockpot broke, I went to Home Depot and bought a cheap wooden drawer knob (about $1 as I recall). I put a plastic washer between the knob and the glass and another under the screw head from the bottom (to prevent cracking the lid), tightened the screw and good as new.
Feb 20, 2009 | Rival 38601 Smart Pot 6-Quart
Door handle
the inside handle and otside both work the release seperate.
what you need to do is take the door panel off the inside by a couple screws (usually in the arm rest) and several plastic clips
around the perimiter which will pull out when you pry out on the panel. You can do this carefully with a screw driver but the proper
fork tool from parts store will be easier. look inside door at latch
and see if your piece is broke or possibly the rod may have just come out and need to be put back in place. If your handle piece is broke it is easy to replace once your inside the door.
Sep 04, 2008 | 1991 Buick LeSabre
Pegasus Technologies Two-Piece Round Toilet by Pegasus - 15 3/4 Inch Bowl Rim Height Logo
1,106 people viewed this question
Top Pegasus Technologies Home Experts
john h
Jim Goldsmith
Jim Goldsmith
Paul Carew
Are you a Pegasus Technologies Home Expert? Answer questions, earn points and help others
