Question about Health & Beauty
WHAT IS THE MEAN DEVIATION FOR 121 122 123 124 125 126?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 66 Answers
Hello Dear
Mean deviation is calculated by the following steps:
1. Add all the numbers and then divide by total number of values. That is take a mean.
2. Then subtract the mean from each values and ADD them all
3. then the added answer must be divided by the total number of values. and you get the Mean devaition.
I solved your problem here in steps:
Step 1:
(121+122+123+124+125+126) / 6 Equals to 102.6
Step 2:
(121-102.6) + (122-102.6) ...... +(126-102.6)
=125.4
Step 3:
125.4/6 = 20.9 is the MEAN DEVIATION
Hope so this will help you.
Please dont forget to rate the solution.
regards
Posted on Mar 13, 2011
How can I find the mean absolute deviation?
Mean absolute deviation.
Let's break it down into its components.
Mean - Average
Absolute - absolute value - sign doesn't matter - if negative, make positive
Deviation - difference from the mean
Let's do an example. Population 3 7 4 2. Total 16. Mean (Average) 16/4 = 4.
Deviations
3 - 4 = -1 absolute value 1
7 - 4 = 3
4 - 4 = 0
2 - 4 = -2 absolute value 2
Sum of these deviations 1 + 3 + 0 + 2 = 6
Mean (average) of these deviations is 6 / 4 = 1.5.
Good luck,
Paul
Apr 05, 2016 | Texas Instruments TI-30Xa Scientific...
How do you find themean absolute deviation?
The mean is the arithmetic average, so add up all the numbers and divide by the number of numbers.
The standard deviation is a little more involved. The formula and example are explained here:
Standard Deviation Formulas
Good luck.
Paul
May 07, 2015 | Office Equipment & Supplies
What is deviation standard
The standard deviation is a measure of how "tight" the samples are distributed around your mean.
In layman's terms, a small standard deviation indicates that most of your measurements are in the vicinity of the means; a large standard deviation corresponds to readings that are all over the place.
You could also say that the smaller the SD, the more your mean is representative of the data set.
For a better explanation, just look up Standard deviation on Wikipedia!
May 03, 2014 | Audio Players & Recorders
Where is s on the ti-30xa calculator
If you mean the standard deviation, there are two shifted keys on the third row marked with a lower-case Greek sigma. sigma_xn is the population standard deviation and sigma_xn-1 is the sample standard deviation.
Nov 12, 2013 | Texas Instruments TI-30XA Calculator
As the name says, it's the mean of the absolute deviations. See http://en.wikipedia.org/wiki/Absolute_deviation
May 06, 2013 | Office Equipment & Supplies
I have 50 data points for which i need to find standard deviation on a classpad 330 , is there any quicker way to calculate than minusing the mean from every data point?
Here is one technique I used on the TI84Plus.
Create two lists list1(50) and list2(50) of equal dimension (same length)
You will have to find how to do it on ClassPad.
Fill list2 with zeros
Fill list1 with your data.
Sort the list in ascending order (if it is not sorted)
Do standard deviation calculation on list1 (or calculate the average)
The mean of the data is in a special variable (xbar)
From the command line using the list syntax calculate abs(list1-xbar) and store results in list2, overwiting the zeros.
Perform standard deviation on the new list2. You will get the mean deviation from the mean in the variable xbar.
A simple request from you. Can you please not use MINUS as a verb? By doing so you are propagating incorrect usage. There is a short and correct way to express the operation: to add.
May 05, 2012 | Casio ClassPad 300 Calculator
Question no. 2 For the 50 observation given below. Prepare Frequency Distribution for the the class interval is 10 (lower limit starting is 0) and upper limit is 80. Also plot in graphing. 64 62 52 50 70...
64 62 52 50 70 60 55 20 25 48 35 55 55 47 64 42 36 50 30 53 51 63 58 50 60 54 33 48 40 76 61 46 65 65 15 45 58 40 64 18 33 40 64 18 33 40 48 9 38 41
Highest value observed: 76
Lowest Value: 9
Standard deviation from the ungrouped data: 15.25
Frequency:
Mean: 46.94
Standard deviation from grouped data: 15.40
Oct 23, 2009 | Microsoft Excel for PC
Standard deviation
standard deviation
calculate mean of a data set:
1. Turn calc. on or press MODE SeTUP
2.Press 3 for STAT
3. Press 1 for VAR
4.Enter values for X column
5. WHen done entering press SHIFT 1
6.Press 5
7.Press 2 to calculate the mean
8.Press =
Oct 05, 2008 | Casio FX-115ES Scientific Calculator
Standard Deviation
Texas Instruments TI-86 Statistics How-To Information The following instructions should allow you to calculate the mean and standard deviation using a TI-86 calculator.
  1. Press STAT
  2. Select EDIT
  3. Enter data into a list: [2.32 ENTER 2.43 ENTER 2.39 ENTER, etc.] Continue until all data have been entered. (use arrows keys to go to the y value, if any)
  4. EXIT until you reach the main ("blank") screen. (If you try to calculate while you're in the data menu, it thinks you're still trying to enter data!)
  5. Press STAT
  6. Select CALC
  7. Select OneVa
  8. Select LIST, NAMES, xStat(F2), Press ENTER
  9. The calculator provides Max, Min, Mean, Standard Deviation, Sum, Sigma, etc. You will be primarily interested in the Mean and Standard Deviation (sx).
Nov 15, 2007 | Texas Instruments TI-86 Calculator
Health & Beauty Logo
234 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
