Question about HP DeskJet F380 All-In-One Printer
I have set up my deskjet F380 (i think) it will photo copy scan but when i go to print a page from my pc it prints out blank
    Novelist:
  • 175 Answers
Can you successfully print a test page? Have you checked to see if you have removed the protective tape from the ink cartridges?
Posted on Mar 13, 2011
The printer, will scan, and the printer will print test copies, showing that it has colour in the cartridges, however when printing text off microsoft word, the page goes through the printer and comes out...
Go to the printer specifications from the word program print window, check the "colour" settings, if colour printing is not marked, then mark it and your problem may be solved ...
Mar 23, 2009 | HP DeskJet F380 All-In-One Printer
I have a hp deskjet f380 all in one printer. The print is so small, how do I increase it?
try to make a copy and check if it is copying successfully or not..if it copies then no issues with the printer..
try printing a test page and check what happens
Mar 08, 2009 | HP DeskJet F380 All-In-One Printer
Deskjet F380 is normaly printing but it will print blank
If the printer is printing blank pages, make sure you are using the correct printer driver and make sure the paper size is correctly selected in the driver. If the printer is printing black only, the Ink option in the printer driver may be set to Black instead of Color or a setting in the software may be set to print black only. Also, the print head nozzles may be clogged. From the Utility section found in the printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Performing up to 6 cleaning cycles is not uncommon if the print heads are severly clogged.
Feb 04, 2009 | HP DeskJet F380 All-In-One Printer
Problems with HP deskjet f380. Will not print... scans and copies
the system for vista and xp is near to similar. so just click the following links 1 by 1 and go through the instructions as you r missing any minor step to be followed in loading your printer How to load a printer on a pc step by step instructions
http://freepctech.com/pc/xp/xp00168.shtml
http://kb.iu.edu/data/aksl.html
Installing a printer on a Windows 95/98 network
INSTALL THE PRINTER on a PC
ENABLE PRINTER SHARING
MARK the NEW PRINTER as a "Sharable" Printer
INSTALL THE PRINTER ON THE OTHER PCs
Troubleshooting Windows 95/98 networking problems
http://www.mcgill.ca/ncs/products/soho/networking/printer/
How to install a printer driver locally for a remote printer in Windows XP/ Windows 2000-
http://support.microsoft.com/kb/282842
Jan 06, 2009 | HP DeskJet F380 All-In-One Printer
F380
With windows Vista my product will print & copy but will not scan and the drivers cd does not work with vista
Nov 14, 2008 | HP DeskJet F380 All-In-One Printer
F380 deskjet - error - refuses to pront
I have this printer with the same problem , worked fine for 1 year, printed over 1600 pages total ( according to the built in HP program that records how many pages I printed and how many times I used the printer) then it stopped printing. The ink cartridges are new, the software is fine, and it says ink levels are good. It physically goes through the motions of printing, loads the paper, makes all the normal sounds it used to and pushes out the paper when it's done - but the page is blank. I did some surfing and read some info that some HP printers are pre-programmed to stop certain functions so you buy a new printer. I know that might sound crazy. How long have you had the printer and how many pages do you think you printed?
Nov 09, 2008 | HP DeskJet F380 All-In-One Printer
HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
Sep 14, 2008 | HP DeskJet F380 All-In-One Printer
HP DeskJet F380 won't copy
If you can't get it to scan an image then you might have to have it brought to a repair center. How often do you use the copy function? Scanning function?
Mar 27, 2008 | HP DeskJet F380 All-In-One Printer
HP DeskJet F380 All-In-One Printer Logo
194 people viewed this question
Seeker5211
Seeker5211
