Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Is not sucking the water back up - Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
It wont suck the water back up
You are not suppose to suck water with an ordinary vacuum. If its a shop vac yes. Otherwise you will ruin it.
Jan 06, 2017 | Vacuums
My son accidentally sucked up some water with my dyson animal and now it has stopped working. Is this permanent or will it come back ?
It depends how much water and how long the motor was run after sucking up water. If it was just a little water, most of the water should have been caught in the dust compartment. If there was enough water that it was able to suck it past the filter and into the motor it could cause motor failure.
Nov 30, 2016 | Dyson Vacuums
Can not get my steam vac to suck up water everything else works.done half floor empty water to do other half of floor and it just stopped sucking up water
  • There a twist lever on the side to change from floor to tools. If "everything else works" then you have it on tools. Twist it back to floor and it will work.
Sep 11, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
My steam vac stopped sucking the water up
make sure the lid on the dirty water container is on tight and the tank itself is locked into place, also check to make sure the clear window in the front of the machine is tightened down firmly
Oct 20, 2009 | Hoover F5858-910 SteamVac Vacuum
It is not sucking the water back up.
there is a handle u hold down when u push the vac forward and thbat sucks up the water
Aug 15, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Shop vac sucks water for a few seconds then it spits it back out
Don't use the paper filter for sucking water. It can ruin it. It will still be usable if you just set it out to dry but there is no reason to use it for water in my experience. I have a sears shop vac and it will fill up more than half full without ejecting the water.
Dec 22, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Water will not suck back up
try vacuming the water up w/out adding water our anything else to the machine
Mar 17, 2008 | Bissell 1699 ProHeat Clear View Upright...
Either the tank isn't sitting square, or there is a oblong seal that should be on the top of the clear window, it seals the top to the edge of the tank. If missing, it won't suck up water. Also sound like it nees to be cleaned out, run a solution of water and vinegar thru it to clean out the lines.
Mar 02, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
267 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
