Question about Dell Computers & Internet
Not yet. I just need to know how to get the casing to lift off so I can Replace the battery
  • DominoMaque Mar 12, 2011
    Most Dell desktops are easy to open, but they do vary, if you can specify the model or series we should be able to help you.
  • Kbiscu1t Mar 12, 2011
    What is the desktop's model?
    Novelist:
  • 175 Answers
PC desktops typically do not have a battery. Are you using a laptop?
Posted on Mar 13, 2011
Replace battery in Acumen heart monitor watch
Important: remember the position of removed items.
Remove the four small screws on the back of the watch. I used a screwdriver designed for replacing screws in eye glasses.
Observe the position then lift the cover and take care to carefully remove the O-ring.
Observe the position then lift the case holding the battery.
Remove the battery again observe the position.
Replace battery, case holding battery, O-ring, cover and screws.
Your watch should how have power. Best wishes.
Feb 09, 2013 | Acumen Ergo Basix Heart Rate Monitor Watch
Remove touch pad on vgn-cs100
It might be easier to just replace the whole Palmrest that comes with the touch pad.
You'll need to take the laptop apart.
Ok, on a laptop you need to get some cups and label them to put the screws in so you will know where they came from. Remove the Power Cord, Remove the Battery then start removing all the screws from the bottom of the laptop. Then remove all the devices from the bottom of the laptop such as the hard drive, the memory, dvd/cd drive, wireless card, etc. Take note of how the wires are on the wireless card, those are the antennas.
Look inside the battery case, hard drive case, memory case and dvd drive slot for screw. Some screws on the bottom case in inside of some of the device cases might have the icon of a keyboard next to it. Those screws hold the keyboard in place.
Turn the laptop over, remove the strip that is just above the keyboard but be careful because a cable might be attached to it. Then remove the screws that hold the keyboard in place that are under where the strip was and gently lift the keyboard out because there is definitely a cable under it.
Next you can remove the screws from the lcd hinges at the corners and lift the lcd screen off, also note that you will have to pull the antennas cable and the lcd cable when you remove the lcd.
Next start removing any screws that hold the palmrest in place. Take note of any cables that are attached to the palmrest and remove them then lift the palmrest off.
Next start removing any screws you see that hold the motherboard to the bottom case, then lift the motherboard out an start replacing the fan.
A digital camera to take pictures will be most helpful to refresh you memory of where things were.
Jun 06, 2012 | Sony VAIO Computers & Internet
How to Replace the HP Pavilion dv7-4270us Fan
You will have to take the laptop apart to get to the fan.
Ok, on a laptop you need to get some cups and label them toput the screws in so you will know where they came from. Remove the PowerCord, Remove the Battery then start removing all thescrews from the bottom of the laptop. Then remove all the devices fromthe bottom of the laptop such as the hard drive, the memory, dvd/cd drive,wireless card, etc. Take note of how the wires are on the wireless card,those are the antennas.
Look inside the battery case, hard drive case, memory case and dvd drive slotfor screw. Some screws on the bottom case in inside of some of the devicecases might have the icon of a keyboard next to it. Those screws hold thekeyboard in place.
Turn the laptop over, remove the strip that is just above the keyboard but becareful because a cable might be attached to it. Then remove the screwsthat hold the keyboard in place that are under where the strip was and gentlylift the keyboard out because there is definitely a cable under it.
Next you can remove the screws from the lcd hinges at the corners and lift thelcd screen off, also note that you will have to pull the antennas cable and thelcd cable when you remove the lcd.
Next start removing any screws that hold the palmrest in place. Take note ofany cables that are attached to the palmrest and remove them then lift thepalmrest off.
Next start removing any screws you see that hold the motherboard to the bottomcase, then lift the motherboard out an start replacing the fan.
A digital camera to take pictures will be most helpful to refresh you memory ofwhere things were.
May 10, 2012 | HP Computers & Internet
May 10, 2012 | HEWLETT-PACKARD Pavilion dv7-4270us...
Change a fxdb battery
You have to remove the seat to access the battery.
There is a bolt at the rear of the seat, remove it and pull the seat toward the rear while lifting.
Disconnect the negative cable first, then the positive. Wrap one with a rag so it can't bend back and touch the battery.
There are two bolts at the rear of the battery case. A lower and an upper. Remove those and the battery case will drop down giving you clearance to pull the battery out.
I got ten years from the factory battery that came with my 2000 FXDWG so I have faith in the factory batteries. But note that I keep a battery tender on mine all the time. Summer and winter, my battery tender is plugged in. I use a "cigar lighter" type socket that I wired to the battery. So it is easy on and off.
To replace the battery, put it in the case, lift the battery case up and install the two bolts at the rear of the case. Connect the positive cable first and then the negative. Try starting it before you replace the seat. It if starts and everything works. Shut it off, install the seat making sure you the front of the seat catches the retaining bracket. Lift up on the front of the seat. If it stays tight, you are ready to ride.
Apr 06, 2012 | 2009 Harley Davidson FXDB Dyna Street Bob
Need to know how to remove the case to replace the batteries on the braun 5441 electric shaver
First, remove the foil and cutter. Then remove the swivel frame by removing the two tine screws, Next, remove the two scew covers on the bottom. These are found on either side of the plug recepticle and look like part of the trim. You can pry them off with a small flat jewelers screwdriver or similar. Remove the screws underneath. You can then gently pry the front of the case off from th bottom. Once case is removed, you can lift out the circuit board to access the battery. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
You will find compatible battery type at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Jan 13, 2011 | Braun Flex Integral 5441 Electric Shaver
My TUF4D1 flashlight does not have a twistoff cap opposiite the light. Unless I have to take out screws?? I still can not find out how to get into the battery compartment of this flashlight?? any body...
The front outer rubber cover is removeable. Once you take it off with your fingers, the front unscrews revealing a two piece battery case. Squeeze the top flanges together and lift out, then the battery case shown in the box just lifts out.
Oct 02, 2010 | Energizer Eveready TUF4D1E 4D Cell Lantern
I need to know how to remove the battery from a norelco mod #
To get to the batteries, you will need to flip up the lotion packet cover on the back and remove the lotion packet if there is one. You will see four screws on the back. Remove these to take off the back of the shaver case. Once this back case is removed, you will be able to see the battery pack. The circuit board can be lifted up slightly for better access to the batteries.
To replace the batteries, you will need to do a little soldering. For easy replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather that removing them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can them solder the tabs from the new batteries to the old existing tabs.
Batteries for this shaver can be found at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
Feb 22, 2010 | Norelco Advantage 6735 X Electric Shaver
How to change the batteries on the TUF4D1
Feb 08, 2010 | Energizer Camping, Backpacking & Hiking
Electric Shaver will not charge
There are 4 small philips head screws deeply recessed on the rear of the razor. Unscrew these and the back half of the case just lifts off. Unsolder the battery leads and fit new battery pack.
Feb 12, 2009 | Philips Philishave HQ7780 Electric Shaver
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
