Do I always need a computer to charge my mp3 620 player battery
  • 6,993 Answers
The answer is yes.
Take care...
Posted on Mar 12, 2011
LCD screen displays always "LOADING" when connected to PC USB
This is a Battery Issue as the Player is only Turning On when its Connected to the Computer!
Dec 29, 2011 | Audio Players & Recorders
Does not charge or play,read on computor
In order for the Coby to charge while connected to the computer or other charger, the Coby must be OFF before being connected to the computer. Check the following questions....
QUESTION ONE:
Can you see it in "My Computer"? It will show under "Removable Drive/Storage"
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and photo folders?
QUESTION THREE:
Can you see the player in Coby Manager - under the "DEVICE" tab?
QUESTION FOUR:
When disconnected from the computer, how long can you listen to the Coby player before it goes off?
If not present in My Computer or in Coby Manager, then it is not plugged in correctly.
a. Disconnect the player from the computer.
b. Wait for it to cycle through "Please Wait" and "Updating Library" screens.
c. Make sure the player is TURNED OFF
d. With player TURNED OFF, reconnect wire to the player then to the computer.
e. You will see a USB connector icon on the player screen and the player charging in the battery area - upper right hand corner.
It will appear to be charging all the while it is connected to the computer. After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8 hour charge with the player OFF.
f. Use the Coby Manager to disconnect the player (Found HERE CobyMedia Manager fix for MP822 (Windows XP/2000/Vista)
1. Go to the DEVICE TAB
2. CLICK on EJECT Button in lower right hand corner.
3. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
4. The second pop-up screen will tell you "The device can now be safely removed from the system."
5. The Coby will now show "Please Wait..."
6. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
You should now have enough battery power to use it. To check the battery level,
1. Turn on the player
2. The battery icon is in the upper right hand corner of the screen - it is ALWAYS RED until it starts to go down... I've not had mine down very far, but believe the red line gets shorter as the battery is wearing down.
Let it run on music until it turns itself off. Recharge as above.
Hope this helps.
Apr 07, 2010 | Coby MP-610 MP3 Player
Not sure if player is charging
QUESTION ONE:
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and movie folders?
QUESTION THREE:
QUESTION FOUR:
If not present in My Computer or in Coby Manager/Device Tab, then it is not plugged in correctly.
e. You will see a USB connector icon on the player screen and the player charging.
After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8 hour charge - with the coby player OFF - through the computer. (This one got me when I first got my player!)
1. Open Coby Manager
2. Go to the DEVICE TAB
3. CLICK on EJECT Button in lower right hand corner.
4. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
5. The second pop-up screen will tell you "The device can now be safely removed from the system."
6. Disconnect the player from the computer.
7. The Coby will now show "Please Wait..."
8. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
Hope this helps.
My sansa fuze i plug it in to the computer and it doesn't recognize the device and i have tried all usb options on the device. What do i do it wont charge at all.????
When the Fuze can be switched on:
1. slide the power on switch shortly upwards to put the player on
2. hold the power on switch upwards for 15-20 seconds
3. release the power switch
Next try to switch the player on and see if it reacts normally.
Switch the player off again and try charging again, making connection to a computer.
When charging still doesn't start, disconnect the player from the computer:
4. slide the power switch downwards into the lock position,
forcing MSC mode
5. connect the player to the computer for charging in MSC mode
for a about 3 hours.
6. while charging use the Sansa Firmware Updater to check for
updates. When not installed already download the Sansa Updater
and run this execute file.
Updates for the player can only be performed in MSC mode.
The updater only works when you're logged in to the computer having administrator's rights and running Windows operating system.
MSC mode means that the computer sees the player as a removable disk. When in MSC mode, always disconnect through the icon "safely remove hardware" in the right corner below of the computer screen.
When the display of the player doesn't react at all after the reset and charging procedure, the battery of the player can:
a. be too far empty or
b. have a fast power loss.
The load of the power supply from the USB ports might be to weak to get the player charged.
When point a. is the case, an extra power adapter connected to a wall socket, providing more power, could help.
When the battery has had many loads it can be at its end of duty cycle. Then battery replacement will be required.
Need more help ? Just post a comment.
Dec 27, 2009 | SanDisk Sansa Fuze MP3 Player
My Ipod 80 mg ipod won't charge - on my dock, or computer. I paid a lot of money for this and now THIS?
the batterys in those ipods always give trouble i fix them on a regular basis, it needs a new battery, computer repair stores would gladly fix it for you
Nov 18, 2009 | Apple iPod MA446LL/A MP3 Player
How do I recharge Coby MP3 player? I plugged into USB port for over an hour but it stopped playing after about 20 minutes. Do I need to replace the battery or charge it longer or both? Thanks. Claudia
Coby MPC7085 requires a 12 hours charge when used for the first time.
Always use a direct connection to the computer when charging with the USB cable: a hub or cardreader should be self-powered.
See page 12 of the manual:
http://www.cobyusa.com/files/manuals/MPC7085_MN.pdf
Sep 28, 2009 | Coby MP-C7085 MP3 Player
How can I charge my centon 4gb mp3 player?
I have the same player. You can use a rechargable battery. But you cannot charge the battery by connecting it to the USB. You must charge the battery with a AAA battery charger - they sell them at walmart for like $15. The rechargable battery really works excellent in this player - I listen to my player all day long and rechargeable batteries are the only way to go for me! Make sure you have four batteries though so you can always have a backup charged as the charger takes 8 hours to charge the batteries.
Jan 04, 2009 | Centon Electronics 001 MP3 Player
Frozen screen
you should hit the reset button and that should do the trick and always make sure it's charged
Sep 13, 2008 | Sony NWZ-S616FRED Digital Media Player
IPOD Video 30gm
Hold down on the center button while hold down on the menu button. The apple logo will appear. Your Ipod is now rebooted.
Is the new battery fully charged? Usually it takes 6 hours on a new battery.
Jun 08, 2008 | Apple iPod MA446LL/A MP3 Player
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
