Question about INOi HD350 USB 2.0 Hard Drive
In the setup I defined the Video to 720, and now I cant see anything on the TV, can you help me restoring the settings?
  • 961 Answers
One way to do it is shut the system down by the button on your tower and bring it back in safe mode. Do a system restore back to when it was working.
Dave
Posted on Mar 12, 2011
My tv has gone some orange colour
Try unplugging your tv and anything connected to it - you might want to take a picture first so you have a reference. I would also unplug everything connected to the tv: cable, stereo, etc. Wait a few minutes, then plug in and re-connect everything.
You can also go into your TV's setup menu and adjust the picture settings - try restoring the default settings first.
Mar 22, 2013 | Televison & Video
Cant get 1080 HD picture
Doug Stanton,
I hope this has been resolved by now, but if not then I would be more than happy to assist.
There is a setting where you can change the HDTV Format to display in 1080i. 1080p is available only on select PPV/VoD's. To check or change that, access the Main Menu. From there select System Setup, then HDTV Setup. Go to TV Type and change it to the resolution you want, and make sure Aspect Ratio is 16x9.
If you have any other questions or need further assistance, just let me know!
Tommy Faust
DISH Social Media Representative
Aug 05, 2012 | DISH Network ViP722 DTV Receiver /...
Cant get the tv to go from 720 to 1080
Changing the resolution of 720 to 1080 is dependent of the input television. Make sure the HDMI cable connection or a PC cable connected properly.
If you uses a PC input, you should set the resolution with 720 to 1024 first. then set to higher resolution. If there is a problem when doing settings dark picture or not support, it means that the TV does not support the resolution.
Perform way above the HDMI connection too.
Hope this helped solve your problem.
Mar 12, 2011 | Samsung Televison & Video
What is the problem with the wii displaying black and white on a Sanyo 42 in. HDTV with 720 resolution? I have checked connection in back and it is plugged in correctly. Thank you.
If you are sure the cables are hooked up correctly it may be a setup issue. Go into your wii video settings and make sure the resolutions and settings match that of your tv. If nothing changes, go into your tv settings menu and look for an A/V setting, probably in video settings, which may need to be changed. It will most likely be NTSC or PAL, and once switched may fix the problem. Hope this helps.
Dec 10, 2010 | Nintendo Wii Console
New ps3,new 40in. samsung 3d led, new monster hdmis yet when i play god of war3 which is capable of 1080i it automatically gives me 720 not even 720p. so i unchecked 720p in setup and it gave me 1080 not...
To change this setting, you must exit the application and change your Video Output Settings from the display settings option in the Settings menu. Make sure the tv is not set on 720p/i and that it is set to 1080i. There has been issues with games that are 1080 downscaling the resolution. this can be confirmed by reading this article. if you provide me with the model of the tv. I can help assist you in ensuring its on 1080p. If you need further assistance please let me know after you try the following above. Thanks, Midwest-tek
Aug 28, 2010 | Sony Playstation 3 (PS3) Console
Can't see anything on the tv screen when i turn on my argosi
When connected to the TV, press the "Setup" key on the remote and go to "Preferences".
Now select the option "Factory Default Setting" and press OK. This will solve all the issues.
May 28, 2010 | Argosy HV358T Audio/Video MP4/MP3/...
PS3 unable to switch from 720 to 1080 PS3 does not
if u go to system settings down to restore defualt settings you can reconect the controllers and reset the system to ur tv
Feb 16, 2010 | Sony Playstation 3 (PS3) Console
Sony rdr vx410 dvd player playing some dvds in black and white
  • DVD's are standard definition video sources. Number of lines output is 576 lines, whereas your HD TV set has 720 or 1080 lines. This difference may result in a poorer image. However some DVD players are able to “upscale” picture to obtain a very good picture. Check if your DVD player has the following connectors: YUV, DVI or HDMI. For more information, refer to the instruction manual of your DVD player.
  • Some HDMI or DVI featured DVD players also have an internal processor that can upscale pictures from a DVD to 720 or 1080 lines to provide an excellent picture from a standard definition disc to your HD TV set. Those settings are available from the setup menu of your DVD player. Please refer to the instruction manual of your DVD player.
  • If your DVD player does not have those connectors and only has a SCART connector, or S-VIDEO, or composite, there is not much to do to improve the picture quality. Just make sure that you are not using the cheapest cables and that the picture settings of your TV set are correctly adjusted.
  • Some high end TV sets have a picture improvement engine that can soften a noisy image. Make sure that it is activated from the setup menu of your TV set. Please refer to the instruction manual of your TV set.
  • If people and objects have weird white outlines around them. This may suggest that your TV sharpness is set too high. Make the correct sharpness adjustments from the setup menu of your TV set.
  • Make sure you use good quality cables and that your cables are not too long (less than 5 meters long).
Jun 15, 2009 | Sony RDR-VX420 DVD Recorder/VCR
Screen is blank after (accidently) setting HD Res from 480 to 720
Followed the manual to return to the Default settings, using the remote "in the blind" pressing the arrow and Enter buttons, hoping I hit the right menu button. I did. Case solved. Thanks
Mar 18, 2009 | Televison & Video
Denon 3801.cant display setup on tv
Hello gerrydav, What might be happenening is the refresh rate for your blu-ray is offsync for your preferred display. You should be able to change it by plugging it into another TV and playing around with the settings. If you have further problems please feel free to post again.
Please post what you do and how you did it. I look forward to your posts.
Nov 11, 2008 | Denon AVR-3801 Receiver
INOi HD350 USB 2.0 Hard Drive Logo
118 people viewed this question
Top INOi Computers & Internet Experts
David Payne
David Payne
Are you an INOi Computer and Internet Expert? Answer questions, earn points and help others
