Question about Vacuums
There is a black round, rubber (o-ring?) looking piece where the stem (where the container sits) meets the base. This rubber piece has melted partially away from its original position. Is there any fix (or do I need to) for this or do I need a new machine? The food processor works; I just did'nt know if it is on its last leg...if it is safe to use it. It is the DLC-8M, aand I have had it for many years. Thanks. Angie
    Master:
  • 403 Answers
Not sure what size the o-ring is, but. Do you have a home depot nearby, and do you like the store. If so, bring the unit in, and go to the plumbing repair section. there you will find a wide varity of o-rings, assorted drain seals, even a make your own gasket mat. good luck to ya
Posted on Mar 12, 2011
Why does soot and debris come from the bottom of my Vacuum?
The "soot" is probably pieces of melted rubber from your belt. Replace it at least twice per year.
Jul 29, 2014 | Panasonic MC-V5217 Vacuum
It won't suction the dirty water up to the container. I have ck'd the lid for the dirty water several times. Any other suggestions?
Assure the ring gasket is in place under the hood. A round rubber gasket must be in place on the round tube under the hood where the recovery tank sits to connect the vacuum from the motor to the round tube on the bottom of the tank.
Mar 10, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Brand-new machine, worked perfectly yesterday. Today, will Not **** up solution from carpet.
(1) Make sure the lid is sealed to the recovery tank.
(2) Look under the corner of the tank, where the round pipe meets the base. Is the black rubber ring gasket on the pipe on the base, or did it fall off under the hood? This seals the tank to the motor vacuum.
Feb 04, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hoover spin brush model f5914-900 wont draw water back out of carpet
Please remove the recovery tank and check and see there is a black rubber ring seal on the large vacuum tube that rises from the base to meet the bottom corner of the recovery tank. This rubber seal may have fallen off the tube and be found laying under the hood. It seals the vacuum source to the recovery tank.
Oct 28, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My stem vac won't **** up the water.
Sep 21, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Suction stops steamvac
Sep 18, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My Hoover steamvac w/spin scrub F5914-900 will not **** up water. I can not find my manual. How can I fix it?
Aug 30, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I used my new proheat 2x steam cleaner the first
You may have mislaid a piece when you took your Bissell apart to clean it after using it the first time.
I experimented with mine to try and reproduce your issue. On the bottom of the water tank, there are two pieces that can be removed from it. One of them looks like a black plug at one end, with a red rubber flange piece on the other end. If you push your finger inside the red rubber piece, you can feel a spring move up and down. This is the first piece you place on the bottom of the water tank. I suspect you have this piece, because if you didn't, water would gush out of the water tank as soon as you turned it over after filling it.
The other piece, which is the one I think you may have have mislaid, is a larger black, plastic ring with screw threads. This piece goes over the top of the first plug piece, screws onto the water tank, and holds the plug in place. The words "RECLOSE TIGHTLY" appear on mine. If this piece is missing, the water tank does not sit flat on the base of the Bissell, but kind of flops around, out-of-place, and the unit will not dispense water properly, though it may leak it.
If ithat piece is gone, it should be possible to reorder it. Start here:
http://www.bissell.com/Customer_Service.aspx
If that's not the problem, if you have all the water tank pieces, I wonder if perhaps you unscrewed one black screw to remove the clear front plastic piece from the base of the unit-- the piece through which water is drawn up off the carpet-- to clean it, and didn't get it back into place properly. Make sure the two hooks at the bottom of this piece are inserted, one per side, into the clear plastic side pieces at the bottom. If the hooks are not secured properly, before trying to reinsert them, unscrew the black plastic screw so you don't break the tab. It's easy to miss getting these one of those hooks back in right, but it's important to do that before trying to screw the clear front plastic piece into place.
Jun 11, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Filter Queen Assembly
On the rubber piece, there is a groove on the inside edge for the screen first, then the filter. Just have to work them into that slot. Then put over the bottom housing. The round paper filter is put on over the tank, then the top unit sits on that. These filters will keep dust out of the motor and head asm.
Mar 18, 2008 | Vacuums
Vacuums Logo
37 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
