Question about Air Tools & Compressors
I would like to change a Century Electric Motor Type CS, part number 8-135886-02 2hp, 12 amp, 230 volts to 120 volts outlet. This is on a Sears compressor.
erpaalai
  • 999 Answers
SOURCE: i need to rewire a 239 volt motor to 120 volts.
There should be a wire diagram on the motor tag or under the coverplate. Eric
Posted on Aug 11, 2009
c7121
  • 160 Answers
SOURCE: how do i change my century 2hp electric motor on
ASSUMING U HAVE 4 WIRES; 2-110V, 1-GROUND, 1-NEUTRAL. REMOVE AND OR DISCONNECT 1 OF THE 110V WIRES. IT STILL MAY NOT WORK PROPERLY BECAUSE U NOW JUST HALVED ALL THE VALUES; AMPS, OHMS, ETC.....CONSULT AN ELECTRICIAN 1ST.
Posted on Dec 13, 2009
SOURCE: I wish to take my 220 volt wiring and come off of
Um NO, It's only single phase. You need to get a suitable Amperage 220v - 120v step down transformer.
Posted on Feb 15, 2010
  • 313 Answers
SOURCE: too change rotation of a 5hp 230 volt
HAVE A LOOK INSIDE THE MOTOR CONNECTION BOX. SOMETIMES ON THE LID ARE INSTRUCTIONS OF HOW TO DO THIS. YOU DID NOT SAY IF THIS WAS A CAPACITOR START UNIT OR NOT. IF THERE IS A CAPACITOR ON THERE IT COULD BE NO GOOD WHICH WILL MAKE THE MOTOR GO WHERE IT WANTS. A GOOD CAPACITOR KICKS IT IN THE RIGHT DIRECTION ON SWITCH ON.
Posted on Jul 25, 2010
al_kupchella
  • 843 Answers
SOURCE: have a magnum air compressor
Yes. There should be a label on the motor indicating how to wire it for either voltage, something like the one shown here (which is also reversible - if yours is reversible, be sure you get the correct direction if you are going to change the wiring.) http://www.pirate4x4.com/forum/showthread.php?t=681437 The label is sometimes under the cover where you connect the wires. If not, you should be able to find a wiring diagram for it on-line once you determine the model number of the motor. Good luck, Al K
Posted on May 19, 2011
Won't start
power 120 volt cannot to supply to 230 volt, maximum correction factor for voltage is 15%
Apr 04, 2014 | AO Smith 5 HP 3450rpm R56Y Frame 208-230...
Century single phase 2 hp 3450 rpm type cs motor Frame f56
the motor is on 220 volts ,i like hook that up on 120 volts ,,thanks
May 10, 2012 | Air Tools & Compressors
I have a marathon 3hp motor wired for 220 on a campbell hausfield air compressor. It has a white, black, and green wire coming out of the motor. I am using a no. 12 wire with ground. how do i wire it up to...
Hi! sims146
The Green wire from the electric motor is ground. Check the compressor motor, make sure it is wired for 220-230 Volts. If it has a white wire it could be wired 120 Volts. There should be voltage and current ratings on the motor plate. I always double check these connections. At 230 Volts this motor should be 17 Amps full Load. A 25-30 amp fuses are required to protect this motor circuit. Otherwise up to a 42.5 Amp Inverse Time Delay Breaker could be used.
The welder circuit should have 230 Volts between the Red and Black wires. The white wire is Nutral / Ground. Hopefully this is a 30 to 40 Amp circuit. The Four prong air compressor outlet, White is Neutral, Black and Red 230 Volts, Gray should be ground. Please check with Voltmeter, as some times people swap colors.
InMrFixIt
Jun 25, 2011 | Garden
I want to convert my compressor from 115 V to 220volt? There is nothing in the owners manual on how to do this. Can you help me?
Your garage mate unit was made to operate on 120 volts. That one reason there is nothing in the owners manual. To convert it my be costly.First your electric motor must be able to handle 220 volts. you will need to look on the motor tag and see if it has 120v/230v. if not you will have to purchase a new motor that will handle 220/230 volts.If your motor will handle 220/230/volts you need to look at the the wiring diagram attached to the motor. you then will need to purchase a 220 v plug and outlet and correct wire size to install.
Jun 21, 2011 | Ingersoll Rand - Rand 2 - hp 24 - gallon...
Installing an 24,000btu air conditioner. The original wiring at that outlet has an double pole 20amp circuit breaker. The old air conditioner that was their was plug into an outlet box that sat on the face...
yes your ok if they say the unit doesn't need to be changed in the incomimg power from 208 up to 230 volts or vice-versa,normally they classify motors as120/208/ 230 /460 volts, instead of 120/240/480 volts,but all line voltage varies in this voltage range between 230 to 255 volts a.c. with a +10/-10 percent tolerance either way,and as long as the instructions dont say anything about changing motor connections your good to go, just look on the motor body if possible and make sure theres no wiring diagrams to change voltage,but i would say no in a package A/C like that, and as far as the current goes your good with the 20 amp tandem pole breaker,let me know if i can further assist you. thanks
Jul 17, 2010 | ACE -Air 24,000BTU Heat Pump A/C Free DVD...
Well it is not an AO Smith, but I have an older Eneregair compressor with an Energair America motor 2 HP, 230v 12 amp. It says on the compressor that it is a 115/230, so I am wondering if it is possible...
Thank you for posting your question here on Fixya.com.
A 2 HP motor is usually only going to connect to 230V 1~ because of the high amp draw if ran on 115V. The motor itself should say 115/230 V and then would also read 24/12 Amp. It seems based upon your post it is not a dual voltage motor, likely for the reason I stated. You can not reconnect the motor from series to parallel because the winding connections to the leads are not brought out for you to do so. Otherwise it would be labeled for 115/230. You can of course try to get a 2 HP 115 volt rated motor or try to reconnect a circuit where you wish to use the compressor to bring the 230 V to it. In the long run, you would be better off running the motor on 230V.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Mar 05, 2010 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
I want to re wire an electric motor for low volt
Look on the name plate. If it says under 'volts' 120/240 that means it's dual voltage and you can use either voltage to run.
Sep 25, 2009 | Electric 1hp 1800RPM 56C Frame 12 Volts Dc...
Rewiring mootor from 230v down to 115v
Diagram for aosmith motor b381 is here: http://www.electricmotorwarehouse.com/IMAGES/B381_connection.htm
However, I believe that this motor will be more efficient at 230v depending on load conditions. At 115v this motor will draw more amps and tend to run hot, but situation rules. Enjoy
Dec 13, 2008 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Air Tools & Compressors Logo
143 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
