Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
I have a Sony Wega 55 inch for about 6 years. I have replaced the bulb twice before. I just got another bulb in the unit. It now works for awhile. It occasionally is shutting down with the 5 blink code. I have read that could be the power supply. I often swap these in desktop computers, but am not sure about a TV? How much would a ballpark pricing be to have someone replace it? How much is the power supply? If this is costly, I have to wonder if a new unit would not be smarter way to go?? Thanks in advance!!
    President:
  • 1,654 Answers
5 blinks, pause, 5 blinks, etc. means "Lamp driver error" and the probable cause listed is "Lamp driver defect".This is the starting point for a qualified service technician.Even so, the actual problem may be the lamp. Did you install a genuine Sony lamp assembly? These sets are bad for the lamp driver and optical block, which Sony has extended a warranty on these sets due to the mass problems that they have had with them. If you haven't contacted them yet please do so and talk to them about a warranty on your set. Sony tells me that while they extended the warranty through 3/2011, so please hurry on this.
The parts you need run between $225.00 and $315.00 depending on what boards you need. IF Sony won't honor the warranty or at least work with you, you may consider a new set, these will only get more costly to keep repairing. I Believe in Sony, its not all their fault, there were a lot of bad electrical supplies sold to the electronics industry a few years ago and they simply don't last.
Posted on Mar 12, 2011
Sony Projection Wega TV
It was better to replace the light engine as a unit to such an old PTV.
Electro help
Jul 27, 2014 | Sony Grand Wega Kdf-50we655 50-inch Lcd...
I have a 2006 Sony KDF-55-E2000, just replaced the lamp and housing and now I have a green stripe at the top and a red stripe at the bottom. Is it worth having this set repaired if I do not have an ex
We had the same problem. Let it be and now the tv won't turn on. If I understand correctly from what I've read it's the optical block and they seem to be just as much as a new tv.
Jun 23, 2012 | Sony Grand WEGA KDF55E2000 55" Projection...
55 inch sony wega rainbow issue
Your convegence has gone out. You can get complete kits with instructions from sites such as www.TvRepairKits.com or just the parts from www.ConvergenceChips.com . If you have never done this before i would suggest going the kit route since it includes step by step photo instructions and support.
Mar 05, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
My Sony Wega KDF-55XS955 TV keeps getting a blank screen every 4-5 minutes. I've been told I need to replace a bulb; however, cannot figure out where to locate the bad bulb. Any assistance would be...
julian1390,
That could certainly be your problem. If the unit has not had the lamp changed in the last 3 years it ceratinly would not hurt to do that. Even if this is not the problem you will have a replacement lamp for the time in future when the lamp does go. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which will help you do this.
Thanks for using FixYa and for the great rating.
hardrocko
Jun 16, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
When my sony grand waga 55 inch shuts off on its own what shoild i look at first
If this tv about is 1 1 1/2 years and used about 4 or 5 a day and the projection bulb had not been change,than the projection bulb life is over.First is to change the bulb.
Jun 21, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Grand WEGA KF50WE610 50 in. Rear Projection HDTV-Ready Television: my sony wega 55'' tv is telling me that the projec...
If you have not done it before I would recommend changing the entire assembly. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains how to fix this and where to get the parts. Thanks for using FixYa and for the generous rating.
hardrocko
May 05, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Blue patch on side of screen
This is your Optics Block failing. One of the filters creating this issue. If you don't have warranty (call SONY customer service to check it out) - watch it like it is until you get new TV. It is very expensive repair.
Mar 09, 2010 | Televison & Video
Blue spot on screen center. Peoples faces and show blue tint
if you have a Sony LCD projection ..Theres good chance optical block needs replacing .This spot will get bigger and will eventually cover most of screen the longer you use it .needs repair.If there is no warranty on this unit..I would estimate repair around 6- 8 hundred dollars ..
Aug 06, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Third bulb out in 3 years
I would suggest you getting the shop to look at your cooling fan, assembly or the current surge suppressor connected to the bulb filiments.
Oct 10, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
130 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
