Question about Canon Cameras
My Canon SD1100 Elph won't turn on.I charged the batteries, and cleaned the contacts & memory card w/ alcohol, & it briefly revived, w/ the lens extending and stored images showing. then nothing, again. Wuzzup?
  • peter_par263 Mar 19, 2011
    Damien 128:
    Re: your "solution"--how do I "reformat" my camera?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
I recommend formating the camera
Posted on Mar 12, 2011
Can I use a "SDHC"
Hi
Sure you can as it supports SDHC cards too.
Jul 21, 2011 | Canon PowerShot SD1100 IS Digital Camera
I have a Canon Powershot SD1100 IS gigital elph and when i turn my camera on it says "Card Locked!" I don't know how to unlock my memory card or how it was even locked in the first place....
Take the memory card out of your camera.
Hold it in your right hand.
On the left side you will see a very small slider switch. It will probably be in the down position.
Slide it to the up position and see what happens.
This switch toggles the card between Read/Write and Read Only. If it is on read only it locks the card.
May 21, 2011 | Canon PowerShot SD1100 IS Digital Camera
Powershot sd630 digital elph busy can not reset and says busy when deleting one picture
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 17, 2011 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lcd problem?? magkano po pagpinagawa?? san branch dito sa bulacan meron kayo?
Jan 07, 2011 | Canon PowerShot SD1100 IS Digital Camera
Canon sd 630 camera won't turn on
Inside the camera, check the brass contacts where the battery connects to the camera. Clean it with rubbing alcohol (use a cotton swab) and try to turn it on after insterting the battery.
Jan 29, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
Computer Not Recognizing Canon PowerShot SD1100 IS Elph A
Depending on your OS, you can download the latest driver for your system directly from Canon here. Remember to select your OS in the dropdown tab to be able to see the available downloads.
But I'd also recommend that you take this as an opportunity to consider utilizing a much safer method of downloading your pictures and videos. Please see this link, as it describes the use of a USB card reader as a much easier, faster, and less error prone way to download your photos. Note that card readers are also VERY inexpensive these days (some places less than $2 online with shipping).
Nov 15, 2009 | Canon PowerShot SD1100 IS Digital Camera
Memory card is defective error message
Format the memory card on the same camera it is not a battery problem &also reset your camera
Sep 06, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Camera will not turn on anymore!
Yes I would send it back if possible. It will cost about $50 for a fix.
Some of these fairly new cameras wear out quick. It is usually due to a worn out lens or zoom motor. They also have a tendency to stick causing the camera to turn off or not turn on at all.
Also a fualty memory card or contaminated memory card contact point will do the same. You can clean the points with cotton swaband rubbing alcohol.
May 30, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Not reading my memory card
You may have bent or broken contacts inside the card slot. It's tough to see, but if you look deep inside the slot, you may notice a contact bent or broken. If you're not able to see any damage inside, try taking a cotton swab with some alcohol (isopropyl, not rubbing or drinking type), and cleaning the contacts.
Mar 02, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Cameras Logo
71 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
