Question about Electric Air Tools & Compressors
Our hydrovane 711s doesnt shut down when up to presure on auto mode < constaint not a problem when auto still like nothing has changed
  • 54 Answers
The unit probably has modulation cpability, meaning that it can throttle the inlet valve to match demand, sort of like cruise control for air pressure. If it is modulating at a lower pressure than the idle/shutdown pressure, then it will never shut off, even in auto.
If it unloads, but never shuts down, you might have a bad timer in the control panel.
Posted on Mar 15, 2011
I shut down my toshiba copier 282 in the right way . It gives me the message shutting down in progress but it doesn't shut down automatically as before. It only shuts down with the on/off switch
AD+206
Auto Shut Off Mode timer
setting (Auto Shut Off
Mode/Sleep Mode)
ALL Refer to
content
<0-20>
SYS Timer to turn OFF the
power or to enter the
Sleep Mode automatically
when the equipment
has not been
used
0: 3min. 1: 5min.
2: 10min. 3: 15min.
4: 20min. 5: 25min.
6: 30min. 7: 40min.
8: 50min. 9: 60min.
10: 70min.
11: 80min.
12: 90min.
13: 100min.
14: 110min.
15: 120min.
16: 150min.
17: 180min.
18: 210min.
19: 240min.
20: Not used
check this or update firmwear
Sep 29, 2016 | Toshiba Office Equipment & Supplies
Do you have the output specs for a Hydrovane 975 SQ model?
PDF]Hydrovane 5-7-8 Series Compressor - Compressed Air ...
www.ca-intl.com/files/products/hydrovane-5-7-8-series.pdf
Hydrovane's design and production excellence, combined with a strong .... ModelMotor Capacity Rotor Noise Oil Motor. HP SCFM@ Speed Level - dB(A) CapacityVoltage. 100 PSIC .... 128 PUAS 67.00 28.25 39.5 975 1.00 20.25 x 22.25 n/a.
Nov 26, 2015 | Air Tools & Compressors
HOW DO YOU MOVE THE ARROW KEY ONCE YOU ARE IN THE MENU?
You use the button with the <> arrows to move through the menu selections. Use the menu key to select the function you want to change.
Below is an excerpt from the Acer manual. The manual can be found at http://www.retrevo.com/support/Acer-X203H-Monitors-manual/id/23224bh549/t/2/
Front Panel Controls
1.Power Switch:
To turn ON or OFF the power.
2.Power LED:
Lights up to indicate the power is turned ON.
3.Empowering / Exit:
1) When OSD menu is in active status, this button will act as EXIT-KEY(EXIT
OSD menu).
2) When OSD menu is in off status, press this button to select scenario
mode.
4.Auto Adjust button / Exit:
1)When OSD menu is in active status, this button will act as EXIT-KEY (EXIT
OSD menu).
2)When OSD menu is in off status, press this button for 2 seconds to
activate the AutoAdjustment function.The Auto Adjustment function is
used to set the HPos, VPos, Clock and Focus.
5.< / >
Press < or > to select the desired function.Press < or > to change the
settings of the current function.
6.MENU / ENTER:
Activate OSD menu when OSD is OFF or activate/de-activate adjustment
function when OSD is ON.
Jul 02, 2011 | Acer X203H bd Monitor
Sansa 4 gig just stopped
Try and reset the player. Reset the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Then try this Connect the player to your computer. The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the players screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. <<<<< BUT TRY THIS ALSO >>>>> Check the Device Manager 1. Right-click My Computer, and select -- > Manage. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. *** See This Tip Posted here **** --> http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem <-- Copy this address into a new window. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. >>>> BUT TRY THIS <<<<<<< Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Verifying and changing the USB mode of the device to MSC or MTP From the Main Menu, select Settings > USB Mode.
Mar 05, 2010 | SanDisk Sansa Clip MP3 Player
Sandisk mp3 freezes
Mar 04, 2010 | SanDisk Sansa e200 MP3 Player
Acer Aspire 3600 only background picture, nothing loads.
you operating system is corrupted...causes :- improper software installation...O/S too old..and many other causes...you can try
go on pressing key "F5" as soon asyou switch on then a menu will appear select safe mode...
Need More to Know?..then please reply
____________________________________________________
Please Don't Forget Fo Rate Me "Fixya - Blue Boxes" For My Help
Sep 06, 2008 | Acer Aspire 3680 Laptop
No start condition on 96 town&country
check the Auto Shut down relay its in the under hood fuse
Jul 23, 2008 | 1996 Chrysler Town & Country
G9 flash
My flash doesnt work either. Holding the flash button down doesnt do anything either (in program mode)
Apr 08, 2008 | Canon PowerShot G9 Digital Camera
Protection mode
Disconnect all speaker wires from the speaker terminals of the amp. If it powers up and doesn't go into protect when you increase the settings, the wiring needs to be checked. If it still shuts down, the amp may need to be repaired.
Does it shut down or make loud noises when you move the RCA cables where they plug into the amplifier?
Mar 27, 2008 | Power Acoustik LT-980/2 Car Audio...
Air Tools & Compressors Logo
298 people viewed this question
Top Electric Air Tools & Compressors Experts
elunsford
John Trevino
Craig Butler
Craig Butler
Are you an Electric Air Tool and Compressor Expert? Answer questions, earn points and help others
