Question about KitchenAid Dishwashers
Model 8531654 kuds01fl 551 serial fp1012867 problem dishes not getting clean had a repair man out about 60 day ago and he took off inside spindle an more part off and clean it, but when i try i only can get off spindle and 3 screws off , how do you get to the next part to get off to clean to drain part
  • KitchenAid Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Posted on Mar 14, 2011
Why are dishes wet when cycle completed?
The appliance repair man attempted to solve all problems by replacing the control board. He may have overlooked a defective heater for drying the dishes.
Sep 03, 2015 | Dishwashers
I have a Quiet Guard Standard model #587.151524 that is not cleaning the dishes. I took the bottom spray arm and screens out and cleaned them, (they had a heavy buildup of what I would say is calcium. The...
Dishwasher
How to Buy
heatman101
Dec 22, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
Cullihan water softener-No water in tank-Orange water in house-Salt level measured 3 months ago, has remained the same. ( no salt used ) Repair man claims to have fixed the timer 45 days ago.
the way a water softener is set by , goes off the hardness of the water and how much water you use. Doing a manual cycle will show you if its at least working or not. If nothing happens when you do a manual cycle then you should call back the repair man and have him look at again. The float might be stuck in the brine tank, you can try emptying the salt and cleaning the salt tank out side with a hose, spray water in to the float and make sure is clean and free . Add salt with 3 gallons of water and do a manual cycle. If this still doesn't work then it could be a stuck valve inside the water softener that is stuck closed.
May 18, 2010 | Plumbing
Kenmore 655.13222 k601 bought 5 months ago after
Call sears and they can tell you normal cycle times according to your model. 1888.536.6673. Maybe argue with them to replace this unit since so many issues within 5 months.
Mar 26, 2017 | Kenmore 24 in. 17032 Built-in Dishwasher
Escort 8500 X50 Red K & Ka bands going crazy
As other users said the cleaning took care of the issues. So I took their suggestions because nothing to lose. I took it apart. It is very easy. Just remove 3 crews at the bottom. It has one snap-in hook at one of the corners but easy to separate it. Then I removed the metal part (aluminum die-casted, silver color) from the PCB. It is easy to remove, just remove 6 screws (I think it is 6) then pull the thing out. Inside the aluminum die-cast part is dirty. If you clean inside with Q-tip, you can see the nasty stuff comes off. I think what happens is that the nasty dust comes off then stick on the sensing elements, which might have caused false signal. Also I cleaned tiny elements inside the metal piece with Q-tip. Now it seems working normal. Hope it stays normal. Give it a try if your unit does not act normal. Better than spending $$. Good luck!
Jul 27, 2009 | Passport 8500 Radar Detector
Clogged dishwasher drain?
clean the filter, check the water inlet and outlets for blockages
Jun 29, 2009 | Bosch SHU9915UC Dishwasher
Philips projection back
hello from what you have explained it could be the line output transistor thats gone short circuit to get an engineer out to look at may cost ya they may not repair it in your home trust me i've tryed to repair one in the custormer home its not easy ring around for a quote good luck
shaun
May 11, 2009 | Philips 60PP9352 60" Rear Projection...
Microwave totally shuts off by itself
My microwave is under warranty. I have this problem before and it was "fixed" one month ago by replacing a thermostat. This repaire is under warranty for 90 days.
I will have a service man to look into this problem.
Thanks MK
Jun 29, 2008 | Jenn-Air JMV8196 Microwave Oven
Dishwashers Logo
314 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
