Question about Maytag Neptune Washer
Hi; I have 55FLBWW and the np light keeps flashing, and will not go any farther.
    President:
  • 1,654 Answers
Are you sure its NP and not ND the nd is for not draining, either your pump filter is plugged of the pump is clogged up and needs cleaned out, coulsd aslo be your drain hose. Best way to check is use a shop vav on the drain hose and **** up all the water you can that way, then take the filter cover off the pump filter (in front and under the bottom cover) and check for pluggage, if none is there then the pump may be clogged or not working.
Posted on Mar 12, 2011
My Maytag Neptune washer has "np" flashing. The door is locked and the cycle is not complete
Are you sure this is not an nd and not an np flash code? If so then the code stands for no drain, likely something is clogging the washer pump inlet.
Aug 20, 2016 | Maytag Neptune Washing Machines
I need a user manual for a Samsung NP-R540-H notebook
Hi Judy,
please enter the webpage http://www.samsung.com/us/support/owners/product/NP-R540-JA04US
and click on User MAnuel. its a flash so you will need flash player installed in your computer.
Aug 18, 2016 | Samsung R540 Laptop
Hi, how to reset a tx9 sony cyber-shot camera , as soon as i insert a battery the red light starts flashing (access ligh) but i cannot turn the camera on, and keep on flashing till the battery drains.It...
Would you please try it with another battery .The Cyber-shot TX9 uses a Sony NP-BN1 Lithium Ion battery. that it may not held charge anymore .as it was suppose to be..
Take your camera to any photo-shop ,ask them a new battery and tell them you must try first ,otherwise do not buy..They will let you try it..
Take care..Thanks
Jun 18, 2011 | Cameras
Casio NP20 battery does not charge,charger keeps flashing, does this mean I need new battery? also,it has 700MAH will 800 do when I replace it? was does this mean
If you have had the battery a long time or have charged it often it will need replacing if it does not charge.
800MAH is the capacity of the battery, how much power it can store.
800 is better than 700 and if it is a NP20 it will be OK in your camera.
Hope this helps.
Feb 21, 2010 | Casio EXILIM ZOOM EX-Z60 Digital Camera
The red light that indicates its charging keeps flashing
How old is the battery? Keep in mind they aren't meant to last for more than a year or two, regardless of how often they're used. Generic replacements are actually inexpensive these days. Here's some from Amazon:
http://www.amazon.com/s/ref=nb_ss_e?url=search-alias%3Delectronics&field-keywords=s880+np-20+battery&x=12&y=22
Jun 06, 2009 | Casio Exilim EX-S880 Digital Camera
My casio exilim s880 is playing up
Here's what I found and it actually worked after about 7 times. Others said they had to do it about 20 times. Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Dec 09, 2008 | Casio Exilim EX-S880 Digital Camera
Battery Charge error
Hey Lak_69,
One problem I know of is the battery for your camera should be model NP-20 not model NP-40. The NP-20 has 650mAh. I would exchange your new battery for the correct model battery, and see if this works. If this doesn't work I would try cleaning the battery terminals in the camera, and if that doesn't work go ahead and try a new charger.
Sincerely,
Allan
Go Ahead. Use Us.
May 13, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Jenn air pro range 36" prg3610np
hi after the burner ignites turn knob until it stops trying to ignite thanks
Jan 07, 2008 | Jenn-Air PRG3010 (NP) Gas Kitchen Range
Error Light
This is the add toner light. Replace the tube of toner and will be well.
Dec 28, 2007 | Canon NP 7130 Black and White Copier
Washing Machines Logo
62 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
