Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE profile freezer and fridge not cooling - GE Profile PSW26P Stainless Steel Side by Side Refrigerator
  • 472 Answers
This unit has a control board on it ...the first few things you need to check if the unit is still plugged in... do you have any frostg build up on back wall inside freezer... if you do it tells me compressor is still running and most likely you have a defrost issue either the heater,defrost thermost or the defrost board is bad.... if no frost build up you need to gain access to the rear of unit is the compressor coming on should be able to here it or put your hand on it and it will be hot...
if not running you could have a bad thermostat or the actually main control board has failed.. if it is running check all your fans inside freezer and down by compressor are they working... hope this helps repost with more info
Posted on Mar 12, 2011
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Ge tfg27pfxa profile with cooling problem
Remove the back panel in the freezer to see if the defrost heater is running continually.
Nov 06, 2012 | GE Refrigerators
Ge profile refrigerator not cooling
there is a fan that brings the cool air from the freezer to the fridge. make sure thatit is working and that the vents for it are not blocked or frozen
Nov 10, 2011 | GE Profile PGSS5PJXSS Stainless Steel...
My ge profile PFS22SISBSS FRIDE IS NOT STAYING COOL WHAT COULD BE THE PROBLEM?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 21, 2010 | GE Profile PFS22SBSS Bottom Freezer French...
I have a GE Profile Arctica Fridge. The temperature in the Freezer has dropped to 34 degrees and the Fridge has dropped to 40. The fridge is running and is blowing air in the freezer, but not really...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 11, 2010 | GE Profile Arctica Stainless Steel Top...
Ge profile fridge will not cool
i would check to make sure you can hear the fan in the freezer you may need to hold in the door switch
Oct 08, 2009 | Refrigerators
GE Profile - Fridge Doesn't Cool But Freezer Works Fine
Had a similar problem with my Kenwood Fridge Freezer
If you're mechanically minded you could check if there's an opening and motorised flap (usually behind a cover) at the top of the fridge - Cold air from the freezer enters the fridge through this flap) The Sound you heard could have been the motor trying to open / close this flap. This flap can become frozen in the closed position - so cold air is unable to enter the fridge compartment) My fix was to thaw it with a hairdryer and reassemble. Another fix would be to empty the freezer and open the doors - it might take more than 24 hours but once completely defrosted if the flap is the issue it will have defrosted. Once plugged in again the door will open and cold air will start to flow into the fridge compartment. I had a quote for €195 for a call out / repair
I fixed it myself in an hour - Hope it works for you ...
Sep 20, 2017 | GE Profile PDS22MHR Bottom Freezer...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
64 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
