Question about Dell UltraSharp 1907FP 19" LCD Monitor
Taking the 1907fpt apart
I just saw your post where your 1907fpt quit working and you had taken it apart. I also have the 1907fpt but for me, the lcd got cracked when something hit it. I just found and ordered a replacement lcd panel for $30 some bucks from Ebay, but I am trying to take it apart and am unable to figure it out so far.
I have taken out the only 4 screws, it looks like the black panels in the back come apart somehow? I will continue to work gently with it but while I am waiting (we just ordered it so it won't be in for a few days anyway) I figured I would ask a pro :)
If you could email me back at heweaver@gmail.com
OK, thanks to hihai in another posting, I was able (finally) to get into my monitor. Use a wide, thin knife and insert it between the grey plastic and the black plastic at the top or bottom of the monitor. (its easier at the top or bottom as you can distinctly see the deliniation between the grey and black - on the sides it's all black and the fit of this bezel around the monitor is so tight it's really hard to get in to the crack to pry the thing off). At any rate, once you get your thin knife (I too used a butter knife) into that crack, gently slide it to one end or the other. There are tabs near each end and a couple in the middle - you'll feel a bit of resistance near each tab as you slide the knife. Position the knife close to one of the end tabs. Rotate the knife handle outwards away from the monitor effectively prying the bezel upwards away from the face of the monitor. As you pop each tab, work towards the opposite end of the same side of the monitor. Once you have both ends dislodged, inserting the knife to pry up the all black sides will be easier. Unfortunately once you have the top (or bottom) and both sides loose the remaining top (or bottom depending on which one you started with) becomes a bit tighter to get the knife into.
Here's my word of caution. Be very gentle. While I was trying to find the way to get the bezel to come off I attempted to slide it in between the monitor face and the bezel itself and unfortunately cracked the glass face inside the monitor rendering it useless.
As for the power button, the button had worn down so much from use there simply was no travel left to push the contact on the switch board in the bezel. I tried a dab of hot glue on the inside of the power button to give it some more contact to the switch on the circuit board but didn't have enough. I was able to push the switch on the board with the circuit board removed from the bezel (with a tiny screwdriver not my fingers) and the monitor powered up fine. It was then I discovered the broken screen. Damn.
Posted on Aug 31, 2008
Thanks. I was able to find a video online of a similar Dell Flat Panel model, and using it as a guide, I was able to safely take my screen apart.
I replaced it with the working one I got online and it works great now! The only thing is, when I put it back together I had to actually take it apart twice more after I thought I was done...once was because I forgot the release button for the stand, and once for something else that wasn't quite right...but other than that, it is working great now!
Thanks!
http://haroldweaver.com
Mixer turns but makes a clunking noise, stops on contact.
Hello Martyn,
I understand that you are having a problem with you Kitchen Aid K5SS. When the unit is on it is turning, when a load is put on it it stops. This is due to the gears in the head being stripped. However, we do not know what gears and how many are stripped without taking the unit apart. If you are not interested in taking the unit apart yourself, I would suggest taking in to a repair shop. If you are interested in taken the unit apart please post back to this thread and I will try and walk you thru it. However, if you want to locate a repair shop please post back your location and I will try to locate one for you.
Thank you for choosing FIxYa.com
Justin
Mar 16, 2011 | KitchenAid K5SS Heavy Duty Commercial...
Chainsaw runs wide open
Operate the throttle trigger to see if it returns to the idle speed screw when the trigger is released. If it seems to 'float' somewhat, the trigger assembly may be full of dirt/sawdust, or the throttle return spring on the carburetor is damaged or disconnected. When taking the trigger assembly apart, be sure to make notes so that it can be put back together correctly. Make sure the throttle plate in the bore is tight to the shaft. When the carburetor was off of the engine, did the gaskets and heat insulator seem to be ok? Any air leak behind the carburetor will cause run-away speed. As for the engine quitting, check the fuel filter, air cleaner, and muffler for plugging. Check the condition of all of the fuel lines for decay or other damage. Did you check the condition of the diaphragm in the lower chamber of the carburetor--it should be quite flexible with no holes or cracks. With the jetting set where you have it, the engine should be 4-stroking heavily. Hope this helps!
Jul 20, 2010 | Poulan Pro Chain Saw 46cc 20"
I have a McCulloch chain saw- pro mac - 610- the saws chain lock came apart, do you have a diagram of one?
This saw? Be kind to your elders.
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/564ff25e56449e8c88256c2f001cd723?OpenDocument
The IPLs I’ve found for your saw don't show this detail. I suggest you try here:
ArboristSite.com Chainsaw thread
http://www.arboristsite.com/forumdisplay.php?f=9 (free to join)
There is a McCulloch thread. Your saw is held in high regard. I’m quite sure some of the members will be willing to post some close up photos of the set up on their saws. HTH
Lou
Sep 27, 2009 | McCulloch Garden
LG Shine CU720 Flex cable replacement
well take apart the lcd part and the keypad part and strat connecting the flex cable.
use this trick:
use ur digital camera to take shots for every step u performed so u not getiing lost after taking the phone one part.
aslo while repalcing the ld put the new on it place!!!
Jan 30, 2009 | LG Shine CU720 Cellular Phone
Quit working only beeps
i took my camera apart,and cleaned all contacts including battery posts and contacts for battery in camera. when removing the flexible ribbons take note that some have 2 wedges on either side of the connecters, which must be gently prised away from the conection in order to free the ribbon. the lcd screen (if i remember correctely) has a black tab running the length of the connecter, and this gets prised up to free the lcd screen--FOR CLEANING, I RUBBED EACH CONNECTION WITH A PINK PEARL PENCIL TYPE ERASER. CAMERA NOW WORKS GOODY GOODY.
Dec 19, 2008 | Samsung Digimax D53 Digital Camera
Dell 1907FPt picture appears for three seconds, then off, LED power remains
I have the same problem. I talked to a few people and it is believed that the condition has been caused by a power surge.
My monitor is out of warranty, so I intend to open it up to check the fuse(s).
I will post result of that soon.
Aug 21, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell 1907FPT lcd monitor
Could be the power supply. Get one at www.partstore.com. I've had very good luck with them fixing various LCD monitors.
Jan 08, 2008 | Dell E173FP 17" LCD Monitor
Dell UltraSharp 1907FP 19" LCD Monitor Logo
326 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
