Question about NewAir AI100R Compact Portable Countertop Ice Maker in Red
My counter top ice maker is screaming loud and I am wondering which part is making all the noise. I am looking at the condensor cooling fan and it spins without binding. The motor that dumps the ice works but the machine is so noise it is unbearable. Do you have a guess? I have removed the side side shields to look and vacum the dust. could the water pump make the noise. when it is making ice it is so loud I un pluged.
    Sergeant:
    Champion:
  • 247 Answers
The noise is came from your compressor due to long uses or operation the mechanical inside possible for wear and tear you need to replace compressor before you replaced try to observe its operation.
Posted on Mar 13, 2011
Kitchenaid refrigerator making rattling noise
YOUR ARE GETTING ICE AROUND YOUR FREEZER FAN BLADE THAT IS THE NOISE YOU ARE HEARING IT COMES FOR THE ICE MAKER FILL TUBE THAT COMES IN FROM THE BACK WALL OF FREEZER TO THE ICE MAKE YOU CAN'T DO ANYTHING TO FIX IT JUST MAKE SURE YOU HAVE NO ICE BIULD UP IN THAT TUBE IT MAKES IT LEAK DOWN ON YOUR FAN
Oct 30, 2012 | Refrigerators
Jenn-Air JCD2389GES problems
The condensor fan cools the condensor coils. If it is running this will cause a no cool situation. Also, if the condensor coils are plugged with dirt that insulates the coils and causes a no cool situation. These things will make it so the freezer isn't cold enough to freeze water so the icemaker will not produce ice. As far as the door edges getting hot. A condensor line runs thru the cabinet between the doors and this is called the mullion. If it is too hot this is a good indication of a bad condensor motor or dirty coils. Clean the coils and check the status of the fan motor and let me know what you find and we will see if we need to go further.
Nov 11, 2007 | Jenn-Air JCD2389G Side by Side...
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
Condensor fan running all day
when you say you removed the cardboard, did you remove the back panel that covers the compressor, fan, and coils from the back? If so that is what is causing it to run too much, this will also effect the cooling.
May 29, 2010 | KitchenAid Superba Architect KSCS25INSS...
I've had my samsung bottom freezer counter depth fridge for just over a year and in the last 5 to 6 months it's started to periodically make a very loud humming noise. Should I be concerned that there is...
The freezer compartment fan may have Icing or the motor is going.....Remove the trays and remove the rear cover. The fan and Freezer evaporator are behind that cover.
The fan doesn't run all the time.
If you have an ice maker it too can make buzzing sounds. Just turn off the Ice maker to eliminate it as a source.
Here's a link to the service manual for the 215
http://www.ajmadison.com/ajmadison/itemdocs/DA68-01778A-EN.pdf
Mar 08, 2010 | Samsung RB215LASH
Not making ice, making a loud humming noise its a top freezer RT18BMXBL01
The ice maker has completely stopped producing ice:--Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly :--When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Noise can come from these areas:
The inside of the freezer :--Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator:--There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator:--Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
This will help.thanks.
Feb 21, 2010 | Roper Refrigerators
It does not make ice compressor and condensor seem
Sounds like your fan has gone bad. That would cause no airflow, resulting in no heat transfer and overheating.
That means it would not cool properl;y and would overheat.
Check for voltage going to the fan motor. If you have voltage there, but no fan operation, replace the fan motor.
Jan 02, 2010 | U-Line Icemaker
GE SIDE BY SIDE/MODEL #GSS25JMDCC
I also had a loud fan and it was caused by ice build-up on the fan in the back of the freezer. From inside the freezer, I removed the plastic grill that covers the fan (I think I also had to remove the side rails and ice maker) then just let the fan defrost in the sink. Made sure it was nice and dry before putting it back in or else ice would just form again. I also took a sheet of plastic and put it between the ice maker and fan grill to stop water from dripping onto the fan and haven't had a noisy fan since. I just need to remove the ice build-up from on top of the plastic sheet every now and then, but that's much easy than taking everything apart to get to the fan.
Feb 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE model TFX22R ice maker problem
First clean out the condensor coils. If you have pets it should be done at least 3 times a year. The other possible problem is if the gasket in either the fridge or freezer is worn out or has a gap it will not cool properly. Check that the fan underneath the unit by the condensor coils is running when the compressor is . Some smaller refrigerators have only condensor coils on the back and no fan. These units should have room for air flow on top and sides not built in flush with cabinets. Buy a thermometer for both the fridge and freezer compartments. You run the risk of food poisoning if the fridge temp can not be kept below 40 degrees. Freezer temp should be able to keep at least 0 - 5 degrees. (Ice cream is a very good indication of proper temp. It is the first thing that melts. Ice maker is a close 2nd.)
If these things don't work call for repair. Don't risk losing all your food!
Jun 24, 2008 | Maytag MSD2756G Side by Side Refrigerator
Bosch KGU32160 fridge freezer
The compressor behind the fridge should cycle on and off as the machine maintains temperature, but the evaporator fan inside the freezer will keep running, except when the fridge goes into defrost. If the noise is coming from the fan inside the freezer, there could be some ice on the frame of the fan and the blades are touching the ice. If the noise is coming from behind the fridge it could be the condensor fan motor. This fan is situated behind the fridge in front of or next to the compressor. It keeps the condensor cool by blowing air onto it. Check this fan. The blades could be touching the pipework or something.
Oct 31, 2007 | Bosch KGU32124 Bottom Freezer Refrigerator
NewAir AI100R Compact Portable Countertop Ice Maker in Red Logo
278 people viewed this question
Top NewAir Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a NewAir Kitchen Appliances - Other Expert? Answer questions, earn points and help others
