Question about Reddy Heater-70,000 BTU Kerosene w/T'stat
Changed plug and ignitor and eye ,cleaned air filter. heater comes on for few seconds and shuts down
    Brigadier General:
  • 4,736 Answers
Knowing the model #, would really help in helping you. Thanks
Posted on Mar 12, 2011
Ignighter lights but doesn't seem to be getting fuel. Heater has fresh kerosene, I have check fuel intake hose and aire intake. All seem ok. During the time the ignighter lights, the fan blows but shuts...
Clean the photo eye,it is right near the flame,clean it where the eye can read the flame,if it can not read the flame ,the unit will shut down.I have a pdf file I can send you for this ready heater,let me know,and give me your e mail so I can,thanks ronicon,,,,roniecon@gmail.com
Dec 21, 2010 | Reddy R70ET Utility Heater
Ingition shuts down within 30 seconds. I realize this is the auto shut down, but there is no reason for it to do this. I took the cover off and found it would stay lit and run if I didn't tighten the...
Can be the Photocell {eye} at the back of the burner or the inline fuel filter.Photocells are easy to replace and when you install the new one make sure it's aiming straight to the flame.Inline filter can be cleaned by using forced air,but not recommended.Filters are cheap.If none of that works check the air pressure at the pump,rear of machine,little plastic pipe plug.4 to 5 P.S.I
Dec 23, 2009 | Reddy Heater 60,000 BTU Kerosene...
70,000 BTU Ready Heater
If...the air pump pressure is right, the ignitor glows, the fuel is hitting the ignitor, then the unit will have combustion......unless.....
  1. there is an air leak on the pressure line
  2. there is a vacuum leak on the fuel line
  3. there is a leak at the nozzle adapter
  4. there is a restriction either in the nozzle or the fuel filter
  5. the nozzle is worn and is spraying fuel rather than fogging fuel
Feb 09, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
UNUSEABLE HEATER
This might help, check behind the ignitor for the sensor eye if it is dirty the ignitor will shut off, the set screws are very sensitive be sure they are set properly ( not to much fuel or air )
Feb 07, 2009 | Master Heaters Master B115DT 115,000BTU...
PLUG IT IN IT COMES ON WONT STAY ON
most likely cause is the CAD flame sensor.
Feb 03, 2009 | Reddy Heater-30-55,000 BTU Variable
Sears forced air kero heater wont start, spitting fuel out front
sounds like the ignitor is bad, mine would try to light and do the same thing. I noticed one night that it was arcing out the entire length of the wires to the plug. If you have a good spark then i would suggest a CAD flame sensor, very cheap.
Jan 22, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
I have a Reddy heater pro 155.
Check all of your air filters but most likely it's the CAD flame sensor.
Jan 22, 2009 | Reddy R155D Utility Heater
Troubleshooting reddy heater 115,000btu
runs for awhile shuts down with a big puff of smoke comes out poured diesel 911 thought i had water in diesel fuel cans nothing help need solution ASAP
Oct 30, 2008 | Desa International ReddyHeater® R115DT...
Readyheater portable forced air 170,000btu/hr
reset switch my heater did the same thing after 5 sec of running
Dec 20, 2007 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater-70,000 BTU Kerosene w/T'stat Logo
60 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
