Question about Nintendo Wii Console
It will not turn on, does the small watch battery have anything to do with turning it on??
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Nope! try this, unplug from the wall, then unplug all three cords from the back of the wii. Go have dinner. plug into the wall, then just the wii power. Its should power up, then plug in the sensor and tv cord.
Posted on May 24, 2013
    President:
  • 1,623 Answers
The small watch battery is for storing date time wireless connections etc. Have you tried a new fuse in your plug or an alternative power supply?
Posted on Mar 12, 2011
I have a 2002 clk 430 amg Mercedes benz and my remote key doesn't do anything at all. it will not lock or unlock doors, open the trunk or turn over in the 2 position to crank my car. all the lights come...
The remote key has a 2 coin batteries fitted. These may have gone flat. Point the keyfob at the car and watching the key press the unlock button. On the key fob there should be a small LED light which blinks. If not, the batteries need replacing. Try this YouTube video. I think they are CR2025 type batteries.
Jan 26, 2018 | 2003 Mercedes-Benz C-Class
How do I replace the battery
find a small flat head pref ..eyeglass tool..turn on the back of the watch and tilt it to the side you should see a small groove..stick the flathead in that and pop it off.you will see the circle battery..popit out and replace..then get some hair grease and most deff not much and go around the rubber..do that and put the cap back on the watch it should pop back into place ..
Nov 16, 2012 | Watches
How to change battery
  • Spread the towel out on a flat surface.
  • Remove the watchband if necessary in order to access the back of the watch.
  • Unscrew the back protector from the watch using the correct size miniature screw driver. Place the screws in a small pile on the towel. Be careful not to drop them as they are difficult to find.
  • Remove the back plate by unscrewing the small screws. There is a tiny spring on the underneath of the back plate. It may be visible, or not. Make sure not to turn the watch upside down or the spring will dislodge.
  • Remove the rubber protector to find the battery.
  • Use sharp point tweezers to remove the clasp covering the battery. There is a small hole at one end of the clasp. Insert one end of the tweezers into the hole to spring the clasp loose.
  • Remove the old battery with tweezers.
  • Insert New Battery and Reassemble Watch
  • Pick up the new battery using regular tweezers and put it into place. Do not touch the battery with your fingers.
  • Replace the clasp over the top of the new battery.
  • Perform a reset by touching the AC contact with one part of the tweezers and the back of the battery with the other part. Hold for a few seconds. Lift the watch carefully and look up at the front to make sure the watch is working. Do not turn the watch over.
  • Replace the rubber cover.
  • Replace the back plate by screwing the small screws back into place.
  • Replace the back protector by screwing the small screws back into place.
  • Reattach the watch band to the watch face.
  • Feel a bit unnerved by this? Find a local jeweler. Best regards.
    Jewel
    Sep 01, 2010 | Casio MTP3036A-2AV Wrist Watch
    My first easy reader timex watch beeps every hour
    mcdevito75 here, The beeping may mean the battery is weak, even if the watch is new. Look for a small watch repair shop in your area.
    Jul 21, 2010 | Timex 27191 Wristwatch
    Watch indicated "low battery" Jeweler replaced the battery but the watch did not respond and remains blank. The watch goes through 2 to 3 batteries per year and light remains on too long and cannot be...
    Hi
    Try resetting it - it worked for me. First, orient your watch face down (with the watch belt buckle opposite you), the new battery in and latched. Second, on the right side battery hold-down latch you will see a small metal circle (~1 mm diameter) with a black dot in the center. Take a small paper clip and touch this metal pad to the metal battery hold-down latch for about 1 second. This will reset the watch.
    Rotate the tiny donut that clips over the battery so it touches the brass spring that is next to the battery, replace the back plate. you can use a small tool to carefully lift the metal contact back up off the contact plate. Also make sure the back of the case is on tight as this also plays a role the electro mechanics of this watch.
    Let us know if you want to know something else accept the suggestion.
    Thanks for contacting fixya.com
    May 27, 2010 | Timex Ironman Data Link 5C291 Wrist Watch
    My watch was on when i opened the box, but i hit a few buttons on the side and the screen went blank. trying to turn it on, but don't know how. does it need charging or something? confused.
    Most likely you jostled the battery loose or the battery coincidentally ran out.
    Take it to a repair shop to get a new battery. If you want to try and do it yourself, you can. But be prepared -- there are lots of small parts and small screws you may have to deal with.
    Jan 06, 2010 | Adidas Response II Watch for Men
    I have a Seiko stainless steel ladies watch, 3 years old, only one 'winder' no fancy buttons, analogue style. It has suddenly started beeping every hour - how do I turn it off?
    mcdevito75 here, The beeping must be a signal that the battery is weak, have the battery changed. Look for a small watch repair shop in your area for the battery change.
    Nov 05, 2009 | Pulsar by Seiko watch PEG665Ladies...
    Panasonic cf-28
    Unlock BIOS by removing jumper on Motherboard. The jumper is a small plastic thing on two pins.
    Jun 19, 2009 | Panasonic Toughbook 29 Touch (P/N...
    Chime not working on a Columbia CL-5017
    This is because you lost the coil spring when battery change took place. Coil spring works as a conductor to the membrane inside caseback and transmits the signal. If you can not find it, you will need to find your nearest watchmaker and ask for new coilspring.
    I am pretty sure that you think you did not lost anything, but I can assure you that you did. Coilspring is very tiny and hard to see when dropped and you can not hear it as well.
    In case if you find that spring, you have to open the watch and put it back in. There is a small hole in the watch movement and it is designed for coilspring.
    Rate me, please.
    Mar 23, 2009 | Columbia All Sport Digital watch
    Frozen
    there was a small watch battery that obviously powers the saving of settings.
    replace it
    Nov 26, 2007 | SanDisk Sansa m240 MP3 Player
    Nintendo Wii Console Logo
    63 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
