Question about HP 610 Color Copier
"Scanner failure" appears and the copier says to
map9966
  • 2351 Answers
SOURCE: Office Jet K60xi Scanner Failure
Try HP's web site suggestions first.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01077492&cc=us&lc=en&dlc=en&product=61736
If your sacnner still fails to function, uninstall everything for the Officejet through add/remove in control panel. (Power off printer before uninstalling).
Go to Hp's web site. http://welcome.hp.com/country/us/en/welcome.html#Support
Step 1. Click, Download drivers and software (and firmware).
Go to step 2. For product, type in Officejet k60xi .
Power on your printer. (Wait for printer to fully power on).
Click, Start Detection>> button.
Allow HP to scan your system & install the latest software.
Follow the on scren instructions. (When finished, restart your PC). Test your scanner by scanning something.
If your scanner still fails to scan, you may be missing basic HP files loaceted in windows system & windows system32 folders.
(These missing files were not installed during your install of windows). Not your fault.
Posted on Apr 25, 2008
  • 298 Answers
SOURCE: when I turn the printer on, a rhythmic banging sound starts
Is the scanner transport lock engaged?
This is either a screw, pin, Clip, Slideswitch or button that keeps the delicate scanner head from moving during shipment.
Look for it in the back and on bottom. If that isn't it, then the driver circuit for the stepping/space positioner motor is bad and you need a techie like me to fix... or just get a new AIO for $39.95 from Wal Mart.
Posted on Mar 26, 2009
marketex
  • 371 Answers
SOURCE: try to print--scanner failure appears
I think your printer has been, for some time now, trying to tell you something and the scanner failure message
is the last in a series of messages.
First, the copier and the printer and the scanner worked fine, "for years",
Then, the copier stopped accepting scans, while printing from data sent by your computer.
Then, you received a scanner failure message again, and will not accept data from your computer, and
"won't print at all"
Your printer/scanner/copier/fax has needed service for some time after years of continuous service.
Evaluate now, based on its initial cost and the lesser cost of All In Ones whether you have already
obtained sufficient service to amortize the cost over time, and you may conclude that service is eitherr
cost effective or ineffective at this time.
Posted on Apr 17, 2009
SOURCE: try to print-copier says "scanner failure"
this is the connectivity problem. try complete Uninstallation and then reinstall it.
Posted on Apr 25, 2009
  • 12 Answers
SOURCE: scanner failure-no longer prints
Hi, I'll give your situation a "stab in the dark" solution. It sounds like you are in the final stages of "scanner system failure". The beginning stages usually limits the all-n-1 to print only i.e., no scan and no fax but you may have such a severe scanner bulb situation that is preventing the print function and may be causing hazardous conditions within your printer and it will do nothing to prevent further harm or damage. Can you describe your situation a bit more detailed?
Posted on May 01, 2009
Epson 610 Workforce Printer Error; Light Bar won't reset
Sound like the scanner is the issue, is it under warranty? OR the Scanner may be locked, check for the scanner release device unlock it,.
Dec 17, 2012 | Epson Workforce 610 All-In-One InkJet...
Tip
Ink System Failure Fix for Some HP Printers
<span><span>Hewlett Packard Ink System Failure Error Fix (tested C6180) </span></span> <ol> <li><span><span>Press and hold the "*" key. </span></span></li> <li><span><span>Press the "#" key and release both keys. Display should say "Enter Special Key Combo" </span></span></li> <li><span><span>Press and release in sequence the "1", "2" and "3" buttons. screen says "support" R0631M </span></span></li> <li><span><span>Press and release the right arrow button until the display says "System Configuration Menu". </span></span></li> <li><span><span>Press and release the "OK" button.</span></span></li> <li><span><span>Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status", </span></span></li> <li><span><span>Press and release the "OK" button. </span></span></li> <li><span><span>Display should say "Hardware failure status: Clear. Press OK to clear". </span></span></li> <li><span><span>Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". </span></span></li> <li><span><span>Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. </span></span></li> <li><span><span>Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.</span></span></li> <li><span><span>Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer </span></span></li> <li><span><span>Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. </span></span></li></ol><span><span>I hope this helps</span></span> <span><span><br /></span></span> <span><span>Regards GM</span></span>
on Jul 15, 2011 | Office Equipment & Supplies
Tip
HP Photosmart C6180 Ink System Failure
<br /> Hi,<br /> <br /> <br /> Please perform the following steps and let me know the message that will be displayed on the printer.<br /> Press and hold the "*" key. <br /> Press the "#" key and release both keys. <br /> Display should say "Enter Special Key Combo" <br /> Press and release in sequence the "1", "2" and "3" buttons.<br /> Press and release the right arrow button until the display says "System Configuration Menu".<br /> Press and release the "OK" button.<br /> Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",<br /> Press and release the "OK" button.<br /> Display should say "Hardware failure status: Clear. Press OK to clear".<br /> Press and release the "OK" Button. Message changes to "Hardware failure status Press Cancel to continue".<br /> Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.<br /> Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.<br /> Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer<br /> Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.<br /> <br /> If I could be of further assistance, let me know. <br /> Thanks,<br /> <br /> LETMEFIXIT
on Feb 04, 2011 | HP Photosmart C6180 All-In-One InkJet...
HP 4500...when trying to scan, or make a copy, screen displays "Scanner Failure" and will not work. Please help.
The "Scanner Failure" message appears when the scanner unit doesn't responds to the commands from the printer's processor. This is a major hardware failure - the scanner unit is effectively dead.
Replacing the failed scanner unit with a new one would cost more than a new All-in-One so either use the printer as is (just as a simple printer) or sell it for parts and get a new one.
Sep 02, 2011 | HP OfficeJet J4580 All-In-One Laser...
"B/W scanner module /DSPF is out of service" this
Press #*C* in your machines control console then enter 14 , and press execute, before this you reconnect your document feeder connnector at the top back side of the machine other wise there is a possibility for your dspf control pwb failure, rate this
May 06, 2011 | Sharp AR-M350U Copier
Sharp AL 1457 Flashes code L 1. I have read about the scan lock on here and have turned it to the unlock position but it still does not work. It is definitely turned to "unlock" and continues...
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
Good Luck and Thank You for using Fixya.
WheatlandServices
Jan 25, 2011 | Sharp AL-1530CS All-In-One Laser Printer
I just got my printer its an hp officejet 4500 model G510g. i got it not too long ago about two weeks and when i turn on the printer after it says warming up, it says "scaner failure. unable to scan,...
Your printer should still be under warranty.
Either take it back to the place where you purchased it or call HP. Their number should be in your manual.
Jan 04, 2011 | Office Equipment & Supplies
Copier has and "L" and blinks back forth between
Hi this error may happen due to problem on the scanner unit. Please check the following;
  • Turn it off the on if it doesn't clear then
  • Check the scanner lock above paper exit tray and unlock it then off and on
  • Check that the copy lamp is lighting ,if not check the lamp cable and lamp itself and replace.
  • Check the scanner motor and the rail then pulleys and adjust.
Be careful while handling brittle glass.
Dec 10, 2010 | Sharp AL 1631 Copier
Scanner failure
scanner failure, turn unit off and back on, does not help
Oct 01, 2007 | HP OfficeJet d145 InkJet Printer
HP 610 Color Copier Logo
41 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
