Question about Sony DAV-IS50 Theater System
I can not perform power on - Sony DAV-IS50 Theater System
  • 84 Answers
Make sure the power supply is in correctly, and check for any sort of power switch that may be affecting it. If this does not work, make sure your outlet is working by plugging the system into another outlet.
Posted on Mar 12, 2011
F101 Error Toshiba estudio2040c
F101-4: Partition mount error (The HDD cannot be connected (mounted) caused by damage to the "/work" partition.)
1. Turn the power of the equipment OFF and check the connection of the HDD.
- Connector and harness check
- Check if the connector pins of the HDD are bent.
- Check if HDD for other equipment is not installed.
- Check if SRAM for other equipment is not installed.
2. If the error still occurs after step 1, perform the following.
- Perform [3C] - [5] (Key Backup Restore) and check that each Key Status is "OK".
- If not, recover the key (copy "SRAM Key Status" to "FROM Key Status" or vice versa).
3. If the error persists after step 2, perform
[5]+[C]+[POWER]?2. Recovery F/S?3. /work, and then restart the equipment.
4. If the error persists after step 3, perform
[5]+[C]+[POWER]?3. Initialize HDD?2. /work, and then restart the equipment.
5. If the error still persists after step 4, perform the following.
- Perform [3C] - [3] (Format HDD), and then install "System Software (HD data)" with [49] - [4].
Notes:
The following items will be deleted by performing [3C] - [3] (Format HDD).
• Message Log
• Job Log
• Spool Data (Print, Email reception)
• Template
If the error persists after performing step 5, perform step 5 after performing [4]+[C]+[POWER]?1. Revert factory initial status HDD.
6. If the error persists even after step 5, replace the HDD.
Oct 31, 2012 | Toshiba Copier Gm 2040 Print Scan Enabler...
When im on the computer the monitor shuts off a box appears saying power saving enabling monitor to shut down in a few seconds and then it restarts
Windows provides the following plans to help you manage your computer's power:
  • Balanced. Offers full performance when you need it and saves power during periods of inactivity. This is the best power plan for most people.
  • Power saver. Saves power by reducing system performance and screen brightness. This plan can help laptop users get the most from a single battery charge.
  • High performance. Maximizes screen brightness and might increase the computer's performance in some circumstances. This plan uses a lot more energy and will reduce the amount of time that a laptop battery lasts between charges.
    Note
    • High performance doesn't appear on the battery meter by default. To turn on High performance, open Power Options by clicking the Start button ?id=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33, and then clicking Control Panel. In the search box, type power options, and then click Power Options. Under Select a power plan, click Show additional plans, and then click High performance.
If these plans don't suit your needs, you can create your own power plan, using one of these plans as a starting point.
Feb 13, 2011 | Gateway 510 S PC Desktop
TOUCH SCREEN DOESN'T WORK TO PLAY VIDEO
If the touch screen of the Camcorder is not working, please follow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
Note: 8 represents the reset button on the above figure.
If the issue persists again, please perform LCD screen Calibration and check if that helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, please remove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15 seconds, turn the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps, service is required.
I hope this information will help you to resolve the touch screen issue of the Camcorder.
Jan 27, 2011 | Sony DCR-HC26 Mini DV Digital Camcorder
Touch screen no longer works on Sony DCR HC26
If the touch screen of the Camcorder is not working, pleasefollow the troubleshooting steps.
Note: In the above picture, 8 represents the reset button.
If the issue persists again, please perform LCD screen Calibration and check ifthat helps.
Perform a power resetting of the Camcorder. To perform power resetting, pleaseremove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15seconds, turn the Power switch to OFF position and then reinsert the batterypack.
If the issue persists even after performing all the above-mentioned steps,service is required.
I hope this information will help you to resolve the touch screen issue of theCamcorder.
Dec 13, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
My display screen is blank.why
Ifthe screen of the Camcorder is not working, please follow thetroubleshooting steps.
Try resetting the Camcorder by pressing the reset button above the hand strap.
Note: In the above picture, 10 represent the reset button.
Perform a power resetting of the Camcorder. To perform power resetting, pleaseremove the battery pack, turn the Power switch to ON for more than 15 seconds,turn the Power switch to OFF position and then reinsert the battery pack.
Dec 04, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
Could you tell me what has to be done when the only item appearing on the screen is MC70?
Resetting the EDA
There are two reset functions, warm boot and cold boot. A warm boot restarts the EDA by closing all running
programs. A cold boot also restarts the EDA, and also resets the clock. Data saved in flash memory or a memory card is not lost.
Perform a warm boot first. If the EDA still does not respond, perform a cold boot.
Performing a Warm Boot - Soft reset
Hold down the Power button for approximately five seconds. As soon as the EDA starts to boot release the Power button.
Performing a Cold Boot - Hard reset
To perform a cold boot simultaneously press the Power button and the 1 and 9 keys.
Dec 03, 2010 | Zebra Symbol MC70 HandHeld Mobile Computer...
How do I clean the printheads on an HP Designjet 4000ps?
To perform a standard cleaning, press and hold the Power button, press the Resume button seven times, and release the Power button.
To perform a deep cleaning, press and hold the Power button, press the Resume button eight times, and release the Power button.
To perform the most thorough cleaning, press and hold the Power button, press the Resume button nine times, and release the Power button.
Apr 29, 2010 | HP Office Equipment & Supplies
Moved my 7410 All-in-One - now it won't power on all the way
Perform power reset :
  1. Disconnect the power cord from the back of the product.
  2. Disconnect the power cord from the electrical outlet, and then wait 60 seconds.
  3. Connect the power cord to the electrical outlet.
  4. Connect the power cord to the back of the product.
  5. Press the Power button to turn on the product.If the issue still persists perform the partial reset steps:
    1. Perform a partial reset on the printer. To do this first remove the power supply from the back of the printer. With the power off press and hold the # and 3 keys.
    2. Plug the power back into the printer, keep holding the # and 3 keys till you see “ Partial Reset ” displayed on the printer screenIf the issue still persists, perform the semi full reset of the printer.
      1. Perform a partial reset on the printer. To do this first remove the power supply from the back of the printer. With the power off press and hold the # and 6 keys.
      2. Plug the power back into the printer, keep holding the # and 6 keys till you see “ Semi Full or Semi NVM ” displayed on the printer screen.
Sep 27, 2009 | HP OfficeJet 7410 All-In-One InkJet...
I have an Performance cordless Power drill model
Check these two places....
Performance Power and Macallister spare part enquiries to Solent Tools 023 80578057
www.solenttools.co.uk. If they can't supply they will give honest advice on who can.
This address is correct:
1 Hampshire
Corporate Park
Chandlers End
Eastleigh
Hants
SO53 3YX
But it is not Performance Power Tools HQ it is B&Q customer support office and their telephone number is 023-8025-6256 but for technical support or spare parts it's 0845 300 2577
Apr 22, 2009 | Black & Decker Pivot Plus Cordless...
Open Questions:
See all Sony DAV-IS50 Theater System Questions
Sony DAV-IS50 Theater System Logo
42 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
