Hi there! I like to know where can i find, the two pinch rollers of my TEAC-C1?? Thanks in advance!
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 155 Answers
This the first place I would go
http://www.terrysrubberrollers.com/
You could probably end your search and all your issues with one stop at Terry's..
Yet you have have some luck here.
http://www.studiosoundelectronics.com/cassette.htm
Good Luck!
Posted on Mar 12, 2011
  • delamostre Mar 12, 2011
    Thanks a lot!
    May be the first place will be more useful than the second one...
Teac x-1000r tape skewing off pinch roller
In the Teac X1000R this is most often caused by dirty Pinch Rollers and secondly bu a ring of oxide or a wear mark being developed into the capstan shaft. If cleaning the Pinch Rollers does not do it then a trip to the technician is required. These decks also have a touchy servo tension system that if upset can also contribute to the failure of this kind. I still work on these in Chicago area all the time. Russ the other ex-Teac guy is in New Jersey. Be careful of local shop with this model as many of them turn up the servo tension to resolve this problem which is the wrong thing to do that then burns out parts and the cost goes up. I have seen this mess many times as people bring me these decks as a last stop-- of course I fix then correctly with the use of the Tentelometer as is required. Pinch Rollers are often reconditioned with Naphtha after cleaning then with Denatured alcohol.
Teac Tascam Repairs Skywave Tape Deck Repair Bensenville IL
Mar 14, 2014 | Audio Players & Recorders
My Teac W450R works except the RH side RPM speed ti too slow. Does it need lube or cleaned? All functions work well otherwise.
It may need a calibration with a speed tape and frequency counter or wow and flutter meter. You should make sure the Pinch Roller is clean too.
Mar 06, 2014 | Teac Audio Players & Recorders
My reel to reel will not play.
You need a new capstan belt or the capstan shaft is glazed as well as you have a hard shiny Pinch Roller. Each of these items need to have friction to work.
Nov 19, 2013 | Teac Audio Players & Recorders
Tascam 38 reel-to-reel 8 track- the ff and rew work and cue instantly; it will not move forward when the play button is pushed. It is as if something is stopping it's motion. To my knowledge it i
Hi James,
I am a past Teac Technician. The answer may be a bad capstan belt- is the round metal thing rotating that makes contact with the rubber Pinch Roller? These belts become lose over time and the DC motor become defective in time due to wear- Before they burn out they can be serviced but only by a person with knowledge about how to take them apart. Otherwise the part can be $120 plus installation. I have not seen sticky Pinch Roller linkages in these models so I will say it is probably not that.
If you are near Chicago I can help you out. If you are near New Jersey Russ can help. If you want to discuss, contact me.
skywavebe@sbcglobal.net
I work on all Teac and Tascam units now full time.
I am also known on tapeheads.net as well.
Oct 31, 2012 | Audio Players & Recorders
TEAC R-H300 Forward Play Fault
The unit need some work by a technician. The bad thing about the drawer type decks is that it makes it hard or impossible to clean the tape path. I have not seen one of these but I could probably fix it.
Some of your description sound like a loose capstan belt and then other times the Pinch roller is not engaging- they may be related if the mechanism is tied to the capstan motor system.
Sep 11, 2012 | Teac R-H300 Dual Cassette Deck
Teac a-3440 will not play
Hi Gary,
This makes me think the Capstan Shaft is not turning either due to a broken or stretched belt or that the capstan motor itself has stopped working. This may be a job for a Technician. You first determine if the Capstan is turning or not- this is the metal post that contacts the Pinch Roller that rotates and is the way the deck gets it's speed regulation. If it is not turning look inside the deck from the side to see if the flywheel is turning and that the belt is on that flywheel. Lastly make sure the capstan motor is turning.
Beyond that a Tech may have to take over from there. I am in the Chicago area and can repair it if you are close. Many people send me units from all over the USA anyway.
My name is Sam. I operate Skywave Tape Deck Repair
skywavebe@sbcglobal.net if you need my help.
Aug 17, 2012 | Teac Audio Players & Recorders
TEAC A-7300 pinch roller
Have it rebuilt by Terry Witt in Michigan. Look for Terrys rubber rollers on the net.
Apr 21, 2012 | Teac Audio Players & Recorders
Hi, I have a TEAC R-H300 Casette Deck. Could you possibly advise me how I can assess the Heads, Capstan and Pinch Roller in order to clean them directly? Unfortunately I tape that was playing got jammed...
Hi Glenn,
The correct way to service a unit like this is to get a service manual and then see how the transport comes out of the unit- the cleaning of the tape path is always a pain when dealing with this kind of deck. That is why I stick with the well known C-3RX and like models. They will last a very long time but are not the size of this unit.
Sep 14, 2010 | Teac R-H300 Dual Cassette Deck
Teac X-1000r broken drive belt
Gidday Chino
You can get a FRESH belt kit from here. Cost you $10 plus some post. There is a new pinch roller listed against this old girl also could be worth replacing at the same time when you service the deck.
regards
robotek
Aug 05, 2008 | Audio Players & Recorders
51 people viewed this question
 Grubhead
Grubhead
