Question about Daewoo KOC-925T Microwave Oven
The turn table doesnt work - Daewoo KOC-925T Microwave Oven
  • Daewoo Master
  • 6,993 Answers
Check the turntable guide to make sure it is lined up properly and that there is no debris caught in it. You may need to re-align or clean your turntable guide.
Cleaning and realigning a turntable guide;
Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable.
With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing.
Test your microwave after this thorough cleaning and realigning in order to determine whether this has solved your problem. DO NOT run your microwave with nothing in it.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Also, Examine the plastic drive bushing the turntable tray sits on. It may have become worn, or even may have split in two;
Drive bushing replacement
Inspect the plastic drive bushing located below your microwave oven's turntable tray. There may be some debris blocking the tray's range of motion. Clean away any blockage you find, and then test your microwave to see if this has cleared up the problem. DO NOT run your microwave with nothing in it.
However, if upon your inspection, you notice that the plastic drive bushing below the turntable tray is worn and/or broken, you will need to have the bushing replaced. Consult with a certified and experienced appliance repair technician. Replacing a drive bushing is a lengthy and involved process that the average layman should not perform.
Good luck.
Posted on Mar 12, 2011
MY TURN TABLE IS NOT TURNING AND MICROWAVE NOT HEATING
the motor for the turn table has broke and when it doesnt turn it wont heat?needs new motor or new microwave
Apr 07, 2016 | Microwave Ovens
Silvercrest microwave, table dont turn no heating
follow the steps, use the VOM for fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Jun 17, 2013 | Microwave Ovens
Microwaves
One of the door switches is bad, or the alignment is out, I recommend it be assessed for a more serious problem.
Jul 18, 2012 | Goldstar MV-1526 Microwave Oven
My microwaves display doesnt work. Light inside works and table turns when i open the door. Other than that nothing is working?
The keypad has a circuit board mounted on the inside of the microwave, above that is the display which is tied into the processor ic module. The only way to fix the problem is replace the whole keypad assembly which would cost more than the microwave oven is worth. The only option is to replace the oven at a much cheaper price.
Jan 16, 2011 | Microwave Ovens
We have a roper microwave that hangs over the stove and everything works on it, exept it doesnt heat. The turn table spins and it lights up the clock and all the buttons work perfect. What would be the...
If you have a friend to help you lift down the unit, you can replace the magnatron which may cost about 100-150.
Take model# and go to: www.partselect.com and find your part there at a good price
Jul 31, 2010 | Roper MHE14XKB Microwave Oven
Microwave comes on but turn table doesnt turn and it doesnt heat up
That's almost certainly a defective secondary interlock (top door switch) or maybe its mount is loose or broken.
See this file for help on checking door switches and where to get replacements.
We have the service manual for this model and have uploaded it for you here.
Jun 29, 2010 | Goldstar MV-1526 Microwave Oven
Microwave has power turn table works won't heat hotpoint model rvm1435bd 001
Check your door satey interlock switches.
If these switches fail (do you open the door while the machine is cooking?), the microwave doesnt know the door is shut and will not turn on the magnatron.
If you need more help, let me know.
a
Sep 27, 2009 | Hotpoint Microwave Ovens
TURN TABLE QUIT WORKING
take down the bottom panel and replace the turn table motor p# wb26x10038
Mar 20, 2009 | GE JVM1631 Microwave Oven
The inside light does not come on
If the light doesnt come on and it heats and the turn table spins then it is just a bulb.
If there is no light no heat and the turn table doesnt turn then there is a monitor switch that is bad.
Nov 26, 2008 | GE Advantium SCA1001SS Convection /...
Daewoo KOC-925T Microwave Oven Logo
242 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
