Question about Sewing Machines
I took the bobbin and bobbin case out to clean and oil. Can't get the bobbin case in correctly as the needle comes down an is jammed to the top of the black bobbin case. Singer 2662 This is my friends machine and we live in the boon-docks. Not easy to get a professional to fix it.
    Genius:
  • 1,788 Answers
I am not too clear on your problem, but it sounds like you have to get it unjammed and remove the needle by loosening the screw on the needle holder. . Even if you have to cut it and take a pliers to get all of it out. You can download the manual for free at www.singerco.com and under support, instruction manual, enter 2662 in the box. Get the manual so that you know how to remove the needle and insert a new one. The needle may have slipped down and is causing the problem. Remember always turn the handwheel towards you, never away from you, because it can mess up the timing. Good Luck
Posted on Mar 13, 2011
My elna 2800 is jamming the bobbin the thread keeps wrapping around the bobbin case. What can I do
try changing the needle, make sure the machine is threaded correctly,using every thread guide. make sure the top thread hasn't come off the thread take up lever, try a different bobbin, could also be a timing problem
Dec 03, 2014 | Elna Sewing Machines
Hello my janome memorycraft 6500 will not sew. As soon as I lower the needle and start to sew the machine needle shudders and it jams.
try these suggestions
use a new needle
check to see if the top thread has come off the top thread take up lever
make sure the bobbin is turned the right way in the bobbin case
Mar 31, 2014 | Janome America Inc 6500P Memory Craft...
Help trouble-shoot jammed machine
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Also could be a timing problem, and the machine would need to be checked.
Sep 08, 2013 | PfaFF Tiptronic 2030
I was sewing with elna machine and ran out of thread. This caused the thread to ball up underneath and "jam" the machine. I cleared it out and rethreaded it, but now the top thread doesn't catch the bobbin...
it is possible that the sewing machine has a timing problem, but check to see if the needle is inserted correctly into the needle holder
make sure the bobbin is inserted correctly into the bobbin case if the machine has a top loading bobbin
if the machine has a side or front loading bobbin also make sure the bobbin case is inserted correctly into the machine.
and also make sure the top thread has not come off the thread take up lever
Aug 20, 2013 | Brother XR-65t Mechanical Sewing Machine
Upper thread gets jammed in bobbin area
Dec 12, 2012 | Brother Sewing Machines
Kenmore sewing machine jams and breaks the needle
always make sure the needle is inserted correctly and all the way
up into the needle holder
make sure the bobbin case is inserted correctly in to the machine
if it's a front or side loading bobbin case
make sure the top thread has not come off the top thread take up
lever
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Dec 01, 2012 | Kenmore Sewing Machines
Brother 700e
1. Change needle
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
Aug 16, 2012 | Brother SE-270D Computerized Sewing...
Pfaff 2024 bobbin case basket is jammed-even after clean & oil
the jam that happened may have caused the machine to jump time & it would have to be serviced
May 16, 2012 | Sewing Machines
I'm sewing machine is not sewing straight and it gets jammed. I cleaned out the dust and oil moving parts. Its still jamming.Please help me asap.
change the needle
rethread the machine top thread make sure to get every thread guide
take the bobbin out & make sure it's wound correctly & inserted correctly in the bobbin case or shuttle
Nov 23, 2010 | Kenmore Sewing Machines
Bobbin case case keeps jamming
I am having somewhat the same problem with the exception that my needle did not break. I've cleaned and oil, but the bobbin case and projection positioned spring is not communicating to allow sewing to continue. The thread keeps jamming and the bobbin raises up the plate. So, what else am I to do?
Apr 02, 2008 | Singer 2662
Sewing Machines Logo
42 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
