Question about EuroCave Comfort 170 1-Temp - Black Solid Door
The Euro Cave horizontal cooling fans are extremely noisy. I need a wiring diagram for the Euro Cave 50 bottle unit to help understand the voltage and load on the fan. I plan to find a different fan and retrofit the unit.
Have older house with package unit air. Unit operates and coils ice up but fan is not kicking in properly. Think maybe capacitor is bad but not sure Has two red wires running to it
You have to check and see if you have supply voltage first off... inside ththe unit there should be a wiring diagram somewhere that should show what the voltage out to that fan should be. Were the wires connected to something or just sitting there like in the vid?
The wiring diagram should show which wires run to the fan and what they go through... if you can post the diagram or the model number of the unit I might be able to help. Anyway... if the supply voltage is present (may even be marked on the fan) and the fan don't spin, its a bad fan... if no good supply voltage then you have to trace the circuit back with a multimeter and see where it is being lost.
Apr 14, 2013 | Computers & Internet
Diagram for cooling fans that controls the lamp on a Hitachi TV
I have not seen this model Hitachi but I have never seen one with 2 fans for the lamp---in all cases there is usually only one-
Hitachi only offers service manuals online and only to authorized repair shops with a user name and password. If two fans ARE involved it is unlikely both would be bad---flying by the seat of our pants I would suggest if possible to check the voltage at the fans---or even spin them to see if they will suddenly work---dirt can cause a fan to slow or stop and the set would either shut down or issue some kind of "fan failure" or temperature warning.
I am willing to help as much as possible and I understand the desire for a diagram but that is unlikely.
Let me know if I can assist or such in any way---I do this here for free but am here to help people.
SD TECH
Dec 04, 2012 | Hitachi 50VS810 50" Rear Projection HDTV
SONY KDF-50WE655 Cooling Fan has become too noisy. It's not the little horizontal fan that is easy to see but something else near it that keeps whining after the little fan stops.
You have a total of 4 fans in this unit.
Fan# 1 - Optics unit ( left side )
Fan# 2 - Large fan facing rear of set, behind metal shield
Fan# 3 - Optics unit ( right side )
Fan# 4 - Mounted directly above the chassi assy
Jun 19, 2012 | Sony Grand WEGA KDF-50WE655 50" Rear...
Fan will only start when you blow into it, and when it does start, it's noisy. Where do I get a Marshall replacement fan off the newer Marshall amps? These fans are said to be better than the ones...
Bearings have gone in it... The fans are standard part. Take number off the label and search for the same unit. Note if it has two or three wires. If it has only two wires, replace with one of same voltage and current or wattage rating and of course that fits size-wise. Three wire ones have a sensor and you are best to replace with exact unit.
Sep 19, 2011 | Marshall Mg50dfx 50-Watt Combo Guitar...
Have a GE Profile PFS22MIBBB. Just replaced condenser fan motor, and main board. The control board now is working, but the fan still has not turned on after 2 hours. Is this normal, or is there...
You will need to unplug the fan and test the voltage coming from the board. You should have 12 to 13 volts DC. Unless you place a fan on condenser that blows air to keep it cool until we locate the problem the compressor can be damaged from over heating. Click here=> GE ARTICA PROFILE TECHNICAL INFORMATION On the first diagram the tech sheet and look for J2 that has both sets of wires for evaporator and condenser fan motors. With new board and new fan you must have a bad connection in the wiring harness. Click on wiring diagram and it will open in a new tab as a Service Manual. Look it over and ask me questions as communication will be very important for you to be able to understand all of this. I will be here when ready so please let me know. Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Jun 04, 2010 | GE Profile Bottom-Freezer Refrigerator...
Installation manual required for teco split aircondtioner. Reverse cycle LS0909Y. I have operation manual but not sure how to install and wire up. Many thanks.
Is the unit an AC only or a heat pump?
Wiring to the units should in the manual or online.
Both units proper house voltage to inside unit and outside unit.There will also be a two wire low voltage cable between thr two.This is so the inside unit can turn on the higher current draw of the compressor in the outside condenser unit thru it's relay.If you have a heat pump there will also be a set of two wires to the 4 way gas valve in the condenser unit to change from heating to cooling mode,a set of two wires to control the on/off function of the fan in the condenser unit when it needs to defrost and mayby a two wire set to a themal sensor in the condenser to sense if it is frosting up when system is in heat mode.
Try to get a wiring diagram and if you can't get to the point where you understand how to wire the unit don't guess! Call someone who knows wiring or call a pro, he can you money over the cost of replacing parts if unit is miswired.
Oct 06, 2009 | Heating & Cooling
Thermostat wiring diagram for heat and cool unit
out door unit staying on disconnect the yellow wire for compressor if still on contactor bad points whare main line voltage is connected if unit goes off stat bad also check for weedeater damage to stat line at unit hope this helps most systems green fan yellow compressor blue common orange reversing valve white aux heat strip remove stat cover to see how unit is wired up
Jul 03, 2009 | Heating & Cooling
Hello.. i have notebook NEC VERSA E6200, my cooling FAN is extremely noisy,im not understand. why this computer very very hot and the fan is very terribly noisy? i can't use this computer in the library at...
the noise is most likely because the fan has worn out, and would need to be replaced, also its good idea to clean out the dust while its replaced, after the job is done the computer shouldn't be as loud and it should also stay cooler.
Jun 11, 2009 | NEC Computers & Internet
Central air conditioner doesn't cool
no cooling means outside unit is not operating due to
-no thermostat signal
- condenser dirty need cleaning
- fan motor stucked 90% this the reason of noize
Apr 27, 2009 | Heating & Cooling
EuroCave Comfort 170 1-Temp - Black Solid Door Logo
24 people viewed this question
Top EuroCave Refrigerators Experts
Jim London
Jim London
Tom Chichester
Are you an EuroCave Refrigerator Expert? Answer questions, earn points and help others
