Question about L R Baggs Violin Pickup W/ Carpenter Jack New
Sometimes pickup doesn't work depends on what amp I use. Thanks, Ed
  • L R Baggs Master
  • 5,603 Answers
These pickups have a very high impedance so you must run into a high impedance input. Many amps expect low impedance guitar outputs and these piezo pickups just can't drive them.
We currently use an X2 wireless system which has over a 1.5 megohm input impedance which works well with these piezo pickups. Long guitar cables degrade the signal as well and running into a DI just won't work.
Posted on Mar 12, 2011
Fender troubleshooting
Replace the selector switch. $15 DIY or $40-$50 Pro installed.
Jul 27, 2014 | Fender Modern Player Telecaster Thinline...
Marsahll amp jvm205c has static/hum in overdrive
Are you using a single coil pickup guitar (Strat or Tele)? If yes, then this is normal depending on how much gain is dialled in.
Mar 18, 2014 | Marshall Amplification Marshall JVM410H...
Bridge pickup suddenly stoped working
If the pickup in the guitar suddenly stops working - then most likely there is a solder connection that has come loose. If you can get a small dental mirror, you may be able to look through the F-Hole on the guitar and spot the loose wire. The tricky part with a Sheraton is the way the hollowbody is constructed doesn't allow you to work on the electronics as easily as say a Fender Strat.
The only way to fix this would be to carefully remove the electronics and re-solder the bad connection. You should only do this if you are very comfortable with soldering.
Since the bridge pickup fails, yet the neck pickup works, you can eliminate about 1/2 of the problem. You can start by examining the wires that come off of the bridge pickup and follow them to the next connection point. You can also test wire continuity if you have a multi-meter to hook up to the wire - to check that the actual wire is not broken in the middle. (Broken wires on the inside of the guitar would be rare - more likely it will be an obvious solder joint that has come loose.)
If you have a local mom and pop music shop nearby - you may be able to take your guitar in for a free diagnostic - but that depends on the shop.
Good luck! Hope my information has helped you figure out a path to get it working again!
Nov 17, 2011 | Epiphone Elitist Sheraton Electric Guitar
Europower PMP5000, In the Front Panel there is a Main 1 & Main 2 output, can I connect both to 2 Amplifiers so I have four independent outputs or 2 Stereo outputs? Can I Use these two outputs + mon 1...
Yes, you can use both the main1 and main2. They are independently driven and please note that they are PSUEDO balanced drives... that is the cold side of the balanced line is NOT driven as a complement, but is merely returned to signal ground by a 120 ohm resistor. This CAN cause hum problems or noise pickup depending on the connected equipment and ground loops. Best to run this into amps/speakers thaat have TRUE balanced inputs and also keep the power source the same for all devices.
Nov 01, 2011 | Behringer Europower Pmp5000 Powered Mixer...
Just installed my new bridge with piezo pickup and my 1/4 inch jack lead will not go into the jack mount on my fiddle. After about a cm in it just stops and wont go any further! Would appreciate any...
I hate to say it but you probablly need a bigger hammer... grip the jack, not the fiddle, and put more force on the plug... they can initially be tight... I do NOT like carpenter jacks myself. They are too heavy. At the 1 cm point is where the plug has to displace the contact. Expect to put 1 to 2 pounds of force to get the plug in... SUPPORT the jack so the force doesn't go on the fiddle. Make sure to use a high impedance cord and preferably short, say 3 feet cord. The capacitance of a guitar cord heavily loads a piezo pickup reducing the high frequency component of the fiddle sound and distorting the waveform. The impedance of the piezo's are around 1 to 2 megohms. Looking on an oscilloscope I found that a guitar cable and amp input made the normal sawtooth violin waveform into peak like mountains. We are now using a short cord (2.5 feet) into a Line6 X2 wireless digital body pack. The link transmits the wave undistorted.
Jul 14, 2011 | L R Baggs Violin Pickup W/ Carpenter Jack...
I would like to buy a Barcus Berry 3100 for my violin... How Good is this coul you send me some ratings... Thanks
The Barcus berry range of transducers is well established and they are good quality. It depends on what you are doing with your fiddle! I use a K & K pickup on my double bass and its FANTASTIC. Check out their violin pickups - their kits is professional quality
http://www.kksound.com/violinissimo.html
http://www.kksound.com/violinissimo_pro.html
Good luck to you
Apr 01, 2011 | Barcus Berry 3100 Clamp-on Violin Bridge...
I have a sigma acoustc electric guitar and it's not picking up sound when plugged to an amp. What do I do?
First, make sure the volume is up on both the guitar and the amp. Obvious, i know, but it wouldn't be the first time a guitar's volume was overlooked.
Second, is there a crackle or a pop or anything if you plug the guitar in to a live amp (one that's already on and with some volume)? If not, then it's likely the cord or the amp, not the guitar.
Even if there is a sound when plugging in, try the guitar with a different cable (one you know works) and a different amp, if one's available. If there's still a problem, then it's probably the guitar.
Standard troubleshooting procedure is now officially out of the way.
Okay, so, I'm not terribly familiar with all the sigma models--in fact, I'd imagine it's hard to find someone who is--so I'm probably going to need a little more info.
Firstly, the model would probably help, and might answer the rest of these questions. Since Sigma wasn't always so helpful with serial numbers and such, we probably won't be able to get an exact ID on the guitar, but we might get a ballpark.
Next: Do you know if it's a passive or an active pickup? Is there a little light and/or button somewhere on the electronics that might be a battery indicator? If so, and nothing lights up when you push the button, see if you can change the battery easily. Sometimes it's obvious how to do this, and sometimes it's not. If it's not obvious, see if you can post a pic and we'll work it out.
If the battery is still good, then it's most likely a problem with the wiring connecting your pickup(s) and/or microphone(s) to the guitar's preamp electronics. With acoustic-electric guitars especially, it's hard for the actual pickups or mics to go bad without something happening to break them (like being dropped or whatever), and it's much more common that a wire gets pulled out or disconnected. Still, things do get old, and they do break.
See if you can tell what kind of pickup(s) and/or mic(s) you have in the guitar and take a look for any hanging wires. You may get lucky and just have something to re-attach, or it may be something easy to replace. Or, you may be stuck trying to order replacement parts from Martin.
If none of this finds the issue, and we can't figure it out with pics or model specs, I would recommend taking it in to a local music shop and having them work it out with Martin for you--they won't gouge you on the price, and they may even explain how to do the repair yourself.
Let me know when you have some more details or if this worked for you. Good luck!
(P.S. I completely feel your pain; my Ovation 1985 collector's series was recently without electrics until I tracked down a replacement pickup and rewired it.)
Mar 21, 2011 | Music
I have a Schecter C1+, older model. When played through a clean channel on my amp, Peavey 6505+, there is a constant buzz. Tried different guitars with the same amp/cab, an the buzz is gone. Culprit is...
This may be strictly magnetic pickup from nearby sources of transformers, ballasts or other motors that generate these magnetic fields. Humbucker pickups have hum cancelling windings that PARTIALLY remove the hum. Wires from pickups to other components should be twisted to help cancel the problem.
Feb 24, 2011 | Schecter C1 Plus Solid Body Electric...
Electric guitar pick up doesnt work?
se3veral things have to be ruled out, start with the cord that your using to your amp, is it good? next is the volume on both the guitar and amp also good, the last thing that should be wrong is the pickup itself unless a wire is broken off of it, you can usally check this from somewhere on the back of the guitar, if all the wires are good, check the two volume controls and on the back of the amp check the wires going to the speaker.
Jan 25, 2009 | Fender Squier Std Strat Mn Car
L R Baggs Violin Pickup W/ Carpenter Jack New Logo
70 people viewed this question
Top L R Baggs Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a L R Baggs Music Expert? Answer questions, earn points and help others
