Question about Yamaha 40N/50N 40 and 50 HP Outboard Motor Service/Shop/Repair
My Yamaha Outboard 115hp 1994 motor starts but wont keep its revs up for very long. I've had issues with water in the fuel recently and had all old fuel and water flushed out of my tanks and motor. After having it all fixed the motor seem to run up to 40K rpm and as I pull back down to neutral, the motor cuts out. Tried to start it again but no joy as it starts up and revs up to 7-10k rpm then slowly cuts out again. I've replace new bulb primer and fuel lines including filter. Spark plugs have been replaced and are the correct ones. The carby has been taken apart and clean out. I cannot think of any reason why else this could be happening. * This maybe under the incorrect heading as there is no drop down for outboard motors.
  • 35 Answers
Not enough information, but there are two things I didn't read about you checking. Make sure the fuel quick connection on the engine (and possibly the fuel tank) is locked all the way in first, Then see if your fuel pump is working. Disconnect the fuel line from the carb and, holding it in a gas can, have someone turn on the ignition. If It's an electric pump, it should start running fuel, if mechanical, they'll have to crank it a little to get fuel going. If you get plenty of fuel that way, your float in the carb could have gotten stuck, or something in the line got into it.
Posted on Mar 26, 2017
  • 74 Answers
SOURCE: 1995 honda cbr f3 wont start
I would think about investing in a carb re-build kit.
Posted on Dec 22, 2008
  • 483 Answers
SOURCE: Yamaha outboard motor manual
You got it :
here !
Posted on Mar 20, 2009
  • 23 Answers
SOURCE: GSXR 750 Slingshot wont rev past 5000rpm, with or without choke
I have seen this before a few things to do too make sure. First take the air filter out and shine a light use your fingers to move the slides up and down I suspect the springs that go on the slide is not seated in center you can tell from the slide going halfway and hanging up. Next, the boots on the slides only go on 1 way there is a notch on the carbs for them. I would guess this would fix you up if not we can get deeper into it with air-fuel mix screw settings.good luck
Posted on Mar 25, 2009
  • 710 Answers
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Posted on Apr 27, 2009
  • 64 Answers
SOURCE: 94 yamaha 535 virago sounds fine, just wont start
Check to make sure your getting gas by pulling off the hose, if no gas comes out your petcock is clogged. If this is the case blow air up into the hose, and if gas comes out now your tank has to be cleaned out.
Posted on Jun 23, 2009
1982 115HP V4 Johnson will not stay cranked. Keeps cutting off before I can accelerate. What could be the issue?
Does it have fresh gas ? Did you run out old gas , if you let gas in for a time it will varnish up , clog fuel system . It will have a funny smell to it .
Sep 29, 2016 | Cars & Trucks
Yamaha v4 1991 115hp outboard fuel pump failure
remove fuel pump and check the diaphrams have not perished and valves are seated on housing ! But first try while engine is running if you prime the bulb does it keep running , if yes then pump not priming fuel !
Feb 15, 2014 | Boating
115hp 1985 yamaha outboard 6e5 AETO running at low revs as if on 3 cylinders,on low revs only when i accelerate it goes well and fast without issues,when i slow to trolling speeds it runs a bit rough...
sounds like a bad coil or trigger. Find the offending cylinder with a timing light and physically move the coil to a good firing cylinder. If the problem follows the coil, you have it, if not you need a trigger,
Nov 09, 2012 | Clymer Marine Maintenance and Repair...
I need a carb diagram for yamaha tzr 250 cc motor cycle year 1988 it will not rev with out choke on . blocked jets?
Hi, Rolandwhitfo and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Will start but wont stay running without choke Yamaha Outboard Parts Forum
Yamaha TZR250 1987 Service Manual
OEM parts for Yamaha
Aug 08, 2011 | 1988 Yamaha TZR 250
Yamaha 115hp 2 stroke Outboard Boat Motor. Went fishing and the boat ran great on the way out there, and when I cranked up to come in the boat wont go over 2000rpm's without bogging down. Fuel Starvation/...
is it carbureted or fuel injected? are your warning horns working? if it iscarbureted then a few easy test can be done to find out. if its fuel injected then its a little harder but not impossible.(1) check compression. without the year model I'm giving you a average numbers. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark fuel is the problem nine times out of ten. clean fuel lines replace primer bulb and replace all fuel filters. Yamaha has a gravity filter under the engine coul. take it to the lake if no improvement. clean carbs. same test to be and fuel system service used of fuel injected engines. if no improvement in engine preformance then you will have to take it to a dealer to test with computer.
Oct 22, 2009 | Boating
Merc outboard 115HP 1996 fuel primer/Choke
Hello there
here is a good place to start ok Outboard (wiring A Tachometer To An Outboard, Mercury Outboard Float) safe.gif
merc outboard motors mercury outboard ... diagram of mariner outboard motors johnson outboard fuel problems ... johnson outboard motors ebay 1996 115 hp mariner outboard
  • · Cached page
Aug 27, 2009 | Boating
Apr 27, 2009 | Boating
Yamaha 40N/50N 40 and 50 HP Outboard Motor Service/Shop/Repair Logo
78 people viewed this question
Top Yamaha Boating Experts
Phil Walker
Phil Walker
Colin Stickland
Colin Stickland
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
