Question about Honeywell Enviracaire Elite F300E-1019 Air Purifier
Honeywell Enviracare Elite F300E electronic air cleaner. I just recently removed the cells for cleaning and noticed two loose fins. The fins slide side to side and can fully contact the secure fins to each side. How can I repair? Can I remove the fins totally and still use the filter?
5 Suggested Answers
bozcro
  • 867 Answers
SOURCE: Since washing the filters of my Honeywell F300E
the filters are damp, causing the arcing. make sure you remove them and dry them before you place them back in
Posted on Aug 12, 2009
HVACjake
  • 22 Answers
SOURCE: f300e filter clicking
You may have a large particle of debris trapped or one of the cell plates is bent and too close to one another.
Posted on Jan 20, 2010
liteswink
  • 99 Answers
SOURCE: Hi, I have a question about Honeywell F300E
You need to replace the power supply of the unit, Contact your heating and cooling contractor for service on the unit.
Posted on May 25, 2010
liteswink
  • 99 Answers
SOURCE: I'm looking for a replacement pre-filter for an
The model number of the pre-filter 203369. You can also call them at 508- 226-7220
Please check this link: Bel-Aire
Posted on Jun 15, 2010
Honeywell Enviracaire Elite 300 problem. Light is not on. Seems like no power to system. No snapping or noises. No obvious bent fins or broken wires
If it was wired to the return air it will have a flag switch to let it know the blower is on, sometimes the flag comes off and it wont operate, sometimes it is wired directly to the computer board on terminals EAC that stands for electronic air cleaner and the board turns the air cleaner on when the blower is running, if you have a meter you can check voltage in both places to see which one is the problem. let me know. thanks wally
Mar 11, 2011 | Honeywell Enviracaire Elite F300E-1019 Air...
Light not on in front of filter . Its a Honeywell Electronic air cleaner and I cant tell if its working because light is off.
Neon light on air cleaner does not come on
1. Make sure the furnace or air conditioner fan is running.
2. Make sure the access door is firmly closed.
3. Make sure the On-Off switch is in the On position.
4. On models without the Solid State Performance Indicator, if the electronic cell(s)
are wet, check again in two to three hours.
Link: Manual
May 15, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
F300e filter clicking
Jan 17, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
I have a HoneyWell F300E electronic air cleaner, installed on a furnace in a house I just bought. I have never owned one of these things before. The filter arcs and makes sparking noises constantly,...
Continuous snapping is not normal .Remove both electronic cells. Make sure that there is no hair, dirt, sand or any debris on the bottom inside the Electronic air cleaner. If there is, remove what you can by hand. If a lot of debris is left in bottom of the Air Cleaner, you may want to use a vacuum attachment to see if you can vacuum up what you can.
Jan 05, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
I have the enviracaire f300e 1001 in a house i just bought. i cleaned the filters. whenever the furnace turns on a buzzing comes from the unit. is this normal? the thermostat also flashes "filter".
Sounds like the filter is damaged or has bent fins.Make sure all the fins are not touching eachother, or they will arch and keep buzzing and flashing.Also there is a wire on the incoming air side of the filter(between each fin) to precharge the particales entering the filter .make sure the wires are not broken.good luck--Nate
Oct 29, 2009 | Honeywell Enviracaire Elite F300E-1019 Air...
Oct 06, 2009 | Honeywell Enviracaire Elite F300E-1019 Air...
Can't get the Honeywell F300e EAC back together.
there is a plastic cell key that keeps you from putting the cells in backwards. Simply reverse the cells and they should slide in fine.
I/O is the power switch, I think O is off.
Jul 18, 2008 | Honeywell Enviracaire Elite F300E-1019 Air...
Clicking noise
I had the same problem.
We could put one cell in and it worked with out clicking. Putting the second one in solo however, it was clicking.
I looked closely at the second cell and discovered that two of the vanes on the side with the wires were bent at about 20 degrees off. Adjusting this and reinserting reduced the clicking but not completely. I pulled the cell and focused on the same two vanes and discover one was also bent in, gently pulled it back and no more clicking!
My wife had cleaned the filters and my 6 yr old and 4 year old had to help. I wonder how they got bent?!
We have had the cleaner for about 6 yrs and no problems until this last cleaning.
Be very careful in adjusting the cells. Aluminum does not like being bent and weakens each time it is moved, like pulling a tab off a beer can (of course the cells are made from much thicker and higher grade aluminum)!
Jan 23, 2006 | Honeywell Enviracaire Elite F300E-1019 Air...
Honeywell Enviracaire Elite F300E-1019 Air Purifier Logo
104 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
