Question about K2 Zed 24 Boys' FrontSuspension Mountain Bike
My rear breaks aren't working. bike has been in storage for about 3 years
    Master:
  • 403 Answers
Brake pads are most likely dried up. you need soft rubber for brake pads
Posted on Mar 12, 2011
What is a decent replacement rear derailleur for a Mongoose 26" Ledge 2.1 Mountain Bike?
Get the kind that has a lever shift instead of the grip shifter. The plastic part that holds the spring breaks easily. The lever shifter has been going strong on my bike for 6 years without a problem
Aug 31, 2016 | Mongoose 26" Ledge 2.1 Mens Mountain Bike
Tip
Proper Bike Storage Tip
Proper Bike Storage.The best place to store a bike is inside. Shelter will protect it from thieves and the weather. Left outside, a good bike can rust and corrode to dangerous condition in less than a year. This is especially true if you live near the ocean where salt in the air is super corrosive. If your apartment is small, simply install a bike hook and hang your bike from a wheel. These hooks are cheap (about $3 at hardware and department stores) and they'll screw into any wood wall or stud in a plaster/sheetrock wall. Be creative: maybe you can hang your bike in a stairwell or a closet; above your bed (cool!) or in the kitchen? You can find a spot if you look a bit. Take it from a guy who once stored six bikes in plain view in a 900-square-foot apartment (to my wife's dismay).
on Dec 21, 2010 | Cycling
What is a good fixed gear bike for beginners?
A fixed gear bicycle is a single-speed machine with a fixed drivetrain, meaning the pedals move at the same rate as the rear wheel. It is impossible to coast on a fixed gear bike, leading to a different style of riding from traditional free wheel-equipped bikes. Additionally, many fixies do not come with brakes, requiring you to learn how to stop the bike through other methods.
Although it is possible to ride a fixie without a break, it is very dangerous to do so on the road. Install a front brake so you can stop short in an emergency. Make sure your frame uses horizontal dropouts.
More details about the Fixed Gear Bikes open the link
Best Fixed Gear Bikes In 2018 Enjoy Your Ride On Cool Fixie Bikes
Oct 02, 2012 | Cycling
I have a Kenmore refrigerator, model #25365812508, purchased in October of 2010. It just stopped working. There is no power. The interior lights aren't on, the ice dispenser lights aren't on. ...
sounds like it's stuffed. Best git yerself down to walmart and see if they have them on new year sales. And git the 10 year extended warranty for $50 so your covered if the new one breaks down.
Jan 06, 2018 | Kenmore Refrigerators
My break light stays on and the blinkers or the hour will work. I replaced the front break light switch, wasn't it. 81yamaha xj550 maxim.
I am not understanding your question: "blinkers or the hour?"
For the brake light: Check the front brake cable to make certain it is moving smoothly and not pinched or stretched anywhere. Make certain the piston is moving in and out properly on the caliper. Check the rear brake linkage. IF YOU HAVE NEVER REPLACED YOUR REAR BRAKE PADS IMMEDIATELY TAKE YOUR REAR WHEEL APART AND MANUALLY INSPECT THE PADS. It has been found in recent years that the original pads will delaminate - separate from the hardware to which they are attached and give way at any moment, leaving you with brake pad floating around your rear hub freely. This almost certainly will result in your bike going down, possibly with pieces of metal flying around from the rear end, and you enjoying a nice slide down the pavement. Remember, if you haven't changed the rear pads, it is likely that they are the originals and 30 years old!! If in doubt of their age, replace them with current pads. They aren't expensive and this could well save your life. Similarly, check the date code on the front brake lines. Those are designed to last 4 years and then be replaced. If you are still using the original lines, or lines older than 2007, you are losing braking power to the weakness of the hoses and risking their rupturing while driving, leaving you in a tough spot. A replacement set of hoses in rubber for that bike will run you about $60 - $80. Much more preferred are stainless steel brake lines as they cost between 25 and 50% more but last many times longer. They should outlast at least 3 sets of rubber lines, if not more. Brake lines sold by almost all vendors are DOT certified for the individual components, but NOT as a unit. Your best (and I believe only) source for fully DOT certified stainless steel brake lines is at xj4ever.com. Go to xjbikes.com -> forums -> supporting vendor and there you will find the "catalog" of things available from XJ4EVER. (The catalog is a 6 page post.) The proprietor is the only source for many XJ parts as he has sought out manufacturers to fabricate some parts which are otherwise no longer available. He has also made it a point to keep as many other parts as he can find in stock, both new and used and his prices are definitely fair. *Please note, I am not paid by and do not receive any sort of compensation from either XJBikes.com nor XJ4Ever.com, but rather am a long term participant of XJBikes.com and a very pleased customer of XJ4ever.com
Mar 26, 2012 | 1981 Yamaha XJ 650
My old Schwinn 26" red
Web search "fix shimano internal gear hub" or whatever the bike has.
Aug 09, 2011 | Cyclone Bicycle Pedal Crankset And Arms...
Before storage last year everything was fine with my 2000 Goldwing. When taking the bike out of storage for the season everything seemed ok until my first ride. I discovered that the rear brake pedal has...
Just bleed the brake system. That will take the air out of the system it is a common problem when you let a goldwing sit.
First bleed the front left brake then bleed the rear brake they both work off the brake pedal.
When you are done with that bleed the front right brake with the hand brake lever,
Get a service manual for your wing it explains how to do many services and it will save you money.
Jun 04, 2011 | Honda GL 1500 Gold Wing Motorcycles
My 2003 kawasaki zxj6 has been sitting for almost 3 years in a storage shed.. What fluids should I change on the bike
I would change all of them including the break/clutch fluid and take the plugs out and pour some thin oil down the cylinders to ease the rings before turning her over.
Feb 20, 2011 | 2003 kawasaki ZX-6R
Clutch seems to be seized because bike has been sitting for years
Is the clutch lever sized or is the plates sized?
Usually the plates inside sizes, all you have to do is select gear 2 or 3 without starting the bike's engine,operate the clutch lever and push the bike,it should release, the rear wheel should now rotate freely with clutch lever in operation and in gear.
Hope this helps!
Nov 28, 2009 | Yamaha YZ 250 Motorcycles
I have a schwinn avenue bike purchaced at walmart last fall. i have had to replace spokes on the rear 3 different times.
Either you are riding over some really rough terrain or the air pressure in the tires is too low. Not getting them tight enough will also cause alignment problems and bend spokes. Eric
Aug 15, 2009 | Schwinn Midmoor Men's Hybrid Bike
K2 Zed 24 Boys' FrontSuspension Mountain Bike Logo
61 people viewed this question
Top K2 Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a K2 Cycling Expert? Answer questions, earn points and help others
