Question about Goldstar DH504EL Dehumidifier
Dehumidifier is running but very little moisture is accumulating in the tank our carpet is soaked so it should be removing more moisture than it is.
    Brigadier General:
  • 4,736 Answers
In the is a wall to wall carpet, it's going to take a while. If you have a wet/dry shop vac, you can speed up the process by using the shop vac in wet mode. This will remove a great deal of water and then the dehumidifier will take care of the rest. Remember, it it's wall to wall carpet, the pad underneath is soaked too. So the dehumidifier alone, will really be struggling with it for at least 24 hours.
If it's and area rug, vacuum it to. Then drape it up off the floor over a couple of saw horses or wooden chairs, so the the dehumidifier will fit under one end like a tent. That will dry it out with in 4 or 5 hours.
Last solution, borrow another dehumidifier from a friend and run both at the same time.
Hope this helps you solve your soggy problem.
Posted on Mar 12, 2011
Water is leaking from the bottom of my maytag dehumidifier. Noticed the problem over the past 2-3 weeks. I have a carpeted basement and the carpet under and around the unit is soaked. water is...
Robert, The water tubing that runs form the interior of the unit to the water bucket is clogged to solve this problem, turn the unit OFF & unplug it. Then do the following.
Remove the water collection bucket and look up inside the bucket holder cavity. You will see either a drain hole or small tubing that drains the water into the bucket. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor it for any leakage.
NOTE: Is you don't have access to a Zip Tie, you can use something similar that flexible, like a long pipe cleaner. But, NO wire coat hangers.
I hope this helps you and thanks for choosing FixYa.
Aug 22, 2011 | Maytag M3DH30B2A Dehumidifier
Runs but doesn't work (no water accumulates)
It sounds like what you hear working is the fan. The unit also has a compressor; if the compressor is bad or the freon is gone, the fan will run but the coils wont cool to remove moisture from the air.
Jun 26, 2011 | DeLonghi DE500P Dehumidifier
Does not collect water in bucket but runs all the time
Does it have a filter?
http://whirlpool.custhelp.com/app/answers/detail/a_id/953
also:
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises."
Jun 21, 2011 | Whirlpool AD25BBK Dehumidifier
Dehumdifier not collecting water.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
Oct 01, 2010 | Whirlpool AD50USL Dehumidifier
LG LHD45EL Dehumidifier - The dehumidifier runs continuously, but very little moisture is taken out of the air. There is only about one quarter of a tank of water after running continuously for 24 hours in...
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jul 12, 2010 | LG LHD45EL Dehumidifier
Dehumidifier does not remove water from the air.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 31, 2010 | Maytag M7DH45B2A Dehumidifier
My Haier dehumidifier Model #39R171E is operating intermittently. The bucket is not full - power is on - temp in room says 59- do I increase the humidity to get it to work? Have a large amount of water in...
If your carpet is wet ... like mine was ... the best thing to do is bite the bullet and get the carpet out of your basement or where ever it is ... so your dehumidifier has a chance.
You reduce the % on the machine to reduce the humidity in your room. You should probably also get some fans going.
I have removed my carpet and padding and everything that I can reasonably remove from the room. I have 4 fans going and 2 dehumidifiers and two sump pumps. I also keep the windows open in the day time because it is more dry outside than in the basement. I have heat in the basement which I run at night. My goal is to save my house from damage due to moisture. It will be a good month for the electric company, that is for sure.
I'm sorry you are in this perdiciment ... I'm sorry for me too. My carpet was less than a year old and we have not had any water in the basement for 30 years.
Mar 03, 2010 | Haier HDN655E Dehumidifier
No Water
Check to see if the coils are cooling down. When the coils are cooling down, they make condensation on them, which is moisture from the air. This moisture drops down in to the tray. This is the water that is accumulated.
If the coils are not getting cold, this can be a problem with the workings of the cooling system. There are a number of hoses, pipes, the compressor, evaporator, and other parts involved that can have a problem. It is also possible that the gas has leaked out of the cooling system due to a leak that has formed.
If the compressor is not starting up, this can also be from a defective humidistat, or there is a fault contiditon that put it in to a protection mode.
Jerry G.
Jun 16, 2008 | Goldstar DH504EL Dehumidifier
Unit cycles off but back on quickly. Does not remove moisture.
It needs the Cover removed and take to the Local Car wash and clear the Front and Back out get all the Junk off of it Use Engine Cleaner first let soak then High Rinse Bring Home let sit outside for A Couple of Hours reassemble and She should Run like New ttech
Jul 21, 2007 | Whirlpool AD50USL Dehumidifier
Goldstar DH504EL Dehumidifier Logo
88 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Jerry Greenberg
Jerry Greenberg
Dan Webster
Dan Webster
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
