Question about Panasonic Lands Phones
I have a panasonic portable phone. It is giving me the message: no link to base, olace on cradle. Any one can help. Thanks.
  • Panasonic Master
  • 2,460 Answers
Our Panasonic cordless goes stupid about 3 times a year. It basically involves going into the setup menu on the handset, select register the phone (re-register) and pressing the handset locator on the base. The phone will link back up to the base.
Carl
Posted on Mar 12, 2011
My Panasonic KX-TG5576 5.8 GHz Cordless Phone, I have it charged. The base phone is working fine. But when I try to use the cordless hand phone and try to use it,m it says: No link to the base, move...
Set the phone on the charging cradle and press the ON button while phone is in crade. You may need to use the speakerphone button to do this. Turning the phone on while in the charging cradle will resync your handset with its base. Try it! It should work!
Feb 01, 2011 | Panasonic KX-TG5576 5.8 GHz Cordless Phone
I have Panasonic KX-TG6051M cordless phone. I have been using it for years with no problems. I now get the message:"No link to base. Move closer to base, try again." I have read the user manual...
Hello! Have you re-registered the handsets? If not go to page 39...If you have re-registered the handsets...Pull the batteries for 1 hour...reinstall batteries...allow handsets to set in the cradle for 1 minute then test...
Guru...Saailer
Jan 01, 2011 | Panasonic KX-TG6051M Cordless Phone
I cannot use the cordless part of my panasonic KX-TC1221BXB. The following message is shown ''No link to base. Place on cradle and try again'' But even after placing back on the cradle, the same message is...
I couldn't find the exact manual for your phone but I would try to re-register the phone. Following are some instructions for similar models of your phone.
*To do this on a non-expandable cordless phone:
  • Press and hold the LOCATOR/INTERCOM button on the Base until a beep sounds.
  • Press and hold the FLASH/CALL WAIT button on the Handset until a beep is heard.
  • When registration is complete, a beep sounds from the handset.
  • Wait for 20 seconds after registration is complete to allow the handset to establish communications with the base.
If this fails to help: Remove the AC Adapter from the phone base or wall outlet for a few seconds and reconnect. It may also be necessary to remove the battery from the handset for a brief moment.
Mar 06, 2010 | Lands Phones
An error message is apearing on my handset,maybe a code is needed
Try this method:
Press locator button on base unit for 3 seconds. Now push flash button on handset for 3 seconds.
This MAY reregister phone to base unit. It did not work for me, more tests at http://www.panasonic.com/consumer_electronics/telephones/ts_guide1.asp
Mar 20, 2009 | Panasonic KX TG2258S Cordless Phone
Hello -need help with phone
It's not charging the battery, clean the contacts on the base, put it on another base to see if it says CHARGING.
Verify that you have power to the base.
Battery might be bad. Try it in another handset.
Nov 06, 2008 | Panasonic KX-TG2357 Cordless Phone
Phone issues.
1st) you must identify the ranking order of your handsets. Put all your handsets in the main base cradle and it will tell you which phone is your handset ie: (1) (2) (3) (4). (if you are reseting a handset, chose a number that is missing to reset your phone to) Now, with NO handsets in the main base cradle. Hold your phone and press "menu", then key in the numbers 00. Now, don't do anything with your handset. Go to the main base cradle. On the bottom, where it says "locator" press the "select" button until you get the desired phone rank needed. H1,H2,H3 etc... Then, press and hold the "call" button, under "intercom". (The charging light should start flashing) Now, go to your handset and press the "OK" button on the top upper right corner. At this point, your phone should be working!
If you are still having problems, call Panasonic Customer Service at 1-800-211-7262 for tech support. PS: your handset may show model KX-560B, but your main cradle base will show the actual phone model listed as KX-TG5633
Mar 14, 2008 | Panasonic KX-TG5633B Phone
Panasonic phone
1st) you must identify the ranking order of your handset. Put all your handsets in the main base cradle and it will tell you which phone is your handset ie: (1) (2) (3) (4). (if you are reseting a handset, chose a number that is missing to reset your phone to) Now, with NO handsets in the main base cradle. Hold your phone and press "menu", then key in the numbers 00. Now, don't do anything with your handset just now. Go to the main base cradle. On the bottom, where it says"locator" press the select button until you get the desired phone rank needed. H1,H2,H3 etc... Now, press and hold "call". (The charging light should start flashing) Now, on your handset press the "OK" button on the top upper right corner. Your phone should now be working! If you are still having problems, call Panasonic Customer Service at 1-800-211-7262 for tech support.
Dec 23, 2007 | Panasonic KX-TG5633B Phone
Almost constantly gives "no link to base" message
I had this problem too. I popped the battery out, waited 1 minute then put it back in. Unfortunately this clears the memory of all recent calls, etc. but it immediately started working again. So far its only happened once...
Mar 26, 2007 | Panasonic KX-TG5422M Cordless Phone
Lands Phones Logo
228 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
