Question about KitchenAid Ovens
I Have a kitcheaid model #KHMC1857WSS-0 over the stove microwave, and it states that it needs to be vented to the outside, do I have to vent this unit or is there any other way, if not I can return it, I just purchased it, HELP.
3 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: Do I need to vent to the outside?
Hello, No you don't need to vent outdoors, and YES all you need is a electrical supply. **I will add however, allow for an air cushion around the unit when it's installed in the wall as well as a vent or small gap with maybe a custom grill at the top. One of the most common service calls I get for self clean built in ovens is reseting or replacing safety thermostat's. Hope that helps Good Luck :)
Posted on Nov 01, 2009
heatman101
  • 43501 Answers
SOURCE: i have a kitchen aid microwave/oven do i need a
You do not need to hook it to the outside, you can just recirculate the inside air...
heatman101
Posted on Sep 30, 2010
Smoke is coming from between oven and microwave especially when it's on self clean very foul oder
Very likely you are cooking some thing vegetable or animal that has been left over inside the stove. If you wanted to keep it, you might try to take it outside and let it burn off, this might take weeks. If you wanted to take it all apart, you might find the problem, although you might wish you had not.
God bless your efforts.
Jan 18, 2016 | Ovens
JTP85 microwave shuts completely off with a blank readout.
Your magnetron is overheating, and its attached thermostat is doing its job to protect the magnetron by shutting off the power to the oven until it cools back down to a safe temperature.
An overheating magnetron can be due to:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven when cooking such foods)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, and it is very helpful when troubleshooting, testing, and locating components.
dee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 21, 2012 | GE JTP85 Electric Double Oven
How to change light bulb in microwave?
Found this post on another fixya-type site: below is the link..
Here's a repeat of Kai's instructions so you don't have to scroll down. I just replaced mine and it was a snap. Just a few Phillips screws and a few tugs. No need to pull the unit completely out as you can access the bulb after it's about half way. No need to disconnect any wiring harness except pulling the bulb out of its socket. I used the 10w (G4 12V) replacement bulb from Home Depot at $6. The light is a bit brighter but there've been no problems with fuses.
1) Turn off power to the unit
2) Open the lower oven door
3) Remove the side trim screws and pull the trims down and out.
4) Remove 2 screws on the sides of the control panel.
5) Open the Microwave door. Remove the 3 screws on the Air Vent Plastic Cover on top of the microwave. You can then remove the Air Vent Cover by pushing the control panel up and pull out slightly at the bottom.
6) Remove the 4 screws on the Air Vent Plastic Cover on top of the lower oven and remove the Air Vent Cover. (You may have to remove the left under side bracket of the Microwave door temporarily just for the Air Vent Cover to clear the screw of the bracket. Re-secure the side bracket of the Microwave door panel as the front panel may fall)
7) Remove the 2 screws which held the Microwave unit in place behind the Air Vent Cover on step 6.
8) Wiggle the Microwave unit out about half way to expose the light bulb unit on top center
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
http://www.fixed4free.com/answers.php?id=51232
Mar 21, 2012 | KitchenAid Architect Series KEMC308KSS...
My Maytag stove. I know it's normal to feel heat from the vent on the stove top when the oven is on. But the temp of the heat escaping is sooo much hotter than it used to be. Do I need a fix ? Model...
The heat from your vent should be a little lower than what the oven is set at. So I doubt if you have a problem but you might want to take some temperature measurements to see.
Sep 07, 2011 | Ovens
I have a kitchen aid microwave/oven do i need a outside vent or just the exhaust
heatman101
Sep 30, 2010 | KitchenAid Ovens
When we use the microwave, air blows out above the door. Is this normal? My wife thinks this is unsafe because it is somehow related to missing trim along the sides of the unit. Looking above the door, it...
This is normal. The microwave can be set to recirculate, which is what you have now. If the unit was uninstalled you would see in the top near the back a cover that can be removed to blow up thru a duct. You probally have no duct above so it was just set up to recirculate. This isn't a problem only if you use it for venting your stove, this will recirculate smoke and such but not unsafe. If you enter your model # at www.appliancehelponline.com you can bring up diagrams and illustrations which will show you the options.
Apr 07, 2010 | KitchenAid 27 in. Built-in...
Can you explain how to replace the light bulb in my amana oven?the model number AARG7303WW
This worked like a charm ... actually it's easier than you might think. Just a few screws and a few tugs. Give it a shot.. I found a 10W (G4 style ... you'll see the difference when you get to the store) replacement bulb at Home Depot for $6:
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with your fingers or pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
Feb 14, 2010 | KitchenAid KEMC378KSS Electric Double Oven
Nov 01, 2009 | Ovens
Can a microwave listed as a countertop be installed over an oven or should an over the range type be installed?
over the range should be installed
they are desined to take the heat being over the stove will generate
as well as become your vent for the stove top
Oct 09, 2009 | Ovens
Mounting a microwave above stove
A copy of the installation instructions for your units should contain how far it should be.Try to study it. You'll likely find that the over the range units will fit the standard 30" cabinet and also provide the required clearance to the range top. Consider the following:- power source (dedicated circuit, with an outlet box in the cabinet above). Venting (outside ot inside), and attaching method. Though they're simple in concept to install, it's a bit awkward in reality. The main thing you need to determine is sufficient space between the MW and the stove. You will have to check, but I believe you need 18" beneath the microwave. Many companies have brackets for that purpose.
Jul 15, 2008 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
32 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
