Question about Moultrie Game Spy D-55ir Camera
I put the sd card in backwards and I broke the pin that secures the card in the camera. How the sds card does not click when in is pushed in. Can this be repaired.
  • Moultrie Expert
  • 296 Answers
#1 problem with Moultrie D55s and I35 models...the cards, to me, are inserted up-side-down...a new card reader will have to be installed by someone capable of intricate soldering...too much heat and main board will be ruined.
Posted on Dec 11, 2011
    Sergeant:
  • 347 Answers
Of course this can be repaired, anyway the broken part needs to be replaced. better contact service for further help.
regards
Posted on Mar 12, 2011
Need to know how and where to insert sd card
There are usually 2 places that an sd-card can be inserted in a digital camera - Inside near the battery under the door, or a separate flap on the bottom of the camera labeled SD.
  • If there isn't a slot specifically for an SD-card on the bottom of your camera, open the battery door.
Try and locate a very thin rectangular ****. Once you have found the slot, take your sd card and push it inside the slot until you hear a click, that means it's securely in place.
Apr 04, 2011 | Polaroid A515 Digital Camera
I have caon rebel the button to take out the mem card broke now i cant get it out
Hello, Take a pen or butter knife and push firmly on the end of the sd card you should hear the sd card click when you do release you pressure the the sd card will release out of the slot. Good Luck
Mar 05, 2011 | Canon Cameras
C613 memory card wont click into place
Very dif. to fix. it is the little springer that makes the SD pop or the lever?
Try w. some tape if it doesn't work. OoW. repair of 24,47 pounds.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Oct 26, 2009 | Kodak EasyShare C613 Digital Camera
Memory Card is Full error message
The camera uses either SD or MMC cards, it is likely you bent or broke one or more of the connector pins in the camera..Bent pins usually break if you try to straighten them.
Repair costs will probably cost as much as a replacement new camera. On eBay you can buy a C330 for $10-
$40.
Sep 04, 2017 | Kodak EasyShare C330 Digital Camera
Sds drill stuck in chuck
tap it lightly with a ball pin hammer, if that dosnt shake it out try opening it and useing something to push it through
May 04, 2009 | Drills
My sd card came out of my camera
IT SHOULD JUST SLIDE BACK IN PUSH IT UNTIL IT LOCK IN
Apr 08, 2009 | Philips PT44434 Digital Camera
Stuck Mini SD Card in Blackberry BOLD, 9000
same thing just happened to me... i had to use a small pin to *gently* pry the card out.. i am now reluctant to put it back in but atleast its out...
i have a feeling it might have been inserted incorrectly but as the sales guy did it at o2 im not sure...
good luck
Dec 12, 2008 | AT&T Blackberry Curve 8300 Smartphone
Camera insist on memory full, but card is empty
Press "Menu" Press button to the right (towards a little flower on my camera) which takes you to the "setting" menu. scroll down to "format" right click again and it reads "All data deleted" and then gives you the option to "Format" or "Cancel". Select "Format" and then "ok" and pronto....your memory card is ready to go.
Nov 17, 2008 | Cameras
Camera will not work with sd card
Had the same problem, blew out the card slot with air and fixed it. Apparently poor contact points with the card.
Oct 07, 2007 | Moultrie MFH-DGS-100V2 Digital Camera
Moultrie Game Spy D-55ir Camera Logo
245 people viewed this question
Top Moultrie Home Security Experts
 Mikey
Mikey
Charles Traverso
Charles Traverso
Level 1 Expert
Are you a Moultrie Home Security Expert? Answer questions, earn points and help others
