Question about Zanussi TC7102W Electric Dryer
I have zanussi electrolux zde26100w for 3 years now. currently the program timer knob is not rotating eventhough the drum is still spinning but no heating (only cold air coming out).Do i need to change fuse or is there any other problem?
    President:
  • 3,074 Answers
Http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Posted on Mar 13, 2011
Zanussi zwd16270w
please download the user manual from the website and go from there eric
Dec 28, 2017 | Washing Machines
The knob just spins round and doesn't catch. It received a bash and it now won't accept a wash cycle. Any thoughts?
It seems that the timer has failed and needs a replacement. If this seems to turn around without clicking and if there is no action when the program cycle is initiated, this seems a failure of the timer controller unit. This happens in cases when it is turned around in reverse order or violently.
Jan 14, 2013 | Zanussi Washing Machines
My Zanussi Electrolux Essential 1200 washing machine ZWF12070W1
Most times unplugging a washer for 5 min or so will reset to factory. Some units just a quick unplug works too. But I'm not totally familiar with yours.
If it's going to be hard to unplug just turn off the breaker to it.
Hope this helps
Feb 27, 2018 | Zanussi ZWF12070 Front Load Washer
The washing mashine goes through the complete cycle but only starts the drun rotation every time the wash cycle comes and than after the apropiate time continiues through the full cycle without the timer?...
I hope you can explain once again the fault that is noticed as I am not able to judge what you have experienced.
If the DRUM is not rotating or is erratic in the cycle then it is possible that the program controller unit is a prime suspect.
The power to the drum motor seems to be erratic from the controller and so is making the drum turn out of turn. I thin when the controller is activated the drum rotates without a problem.
So please check your program controller unit.
Jan 18, 2011 | Zanussi Washing Machines
Anussi ZWD 1271W stops at beginning of program
Did you fix this problem? We have the same with Zanussi ZWD 1472 W. It takes some water and stops after 2 minutes. We need to shut machine down and fill water manually. It works fine then.
Feb 02, 2010 | Zanussi Washing Machines
The drum did not move (spin) eventhough there were the sound of moving (spinning).
hi..you need a new belt.Replacing the old one
will solve the issue.
try this out..
thank u..
rate me..
Apr 12, 2009 | Electrolux EW1000i Front Load Washer
Washer won't spin correctly after fitting new bearings
there are no others sensors in the drum, the module (a circuit board) controls the actions of the timer, it may be one or so wires were disturbed at the time of repair, check all connections, any out of balance sensors would only work with a heavy loaded drum? You did not comment as to the motor / drum action when washing from the start of the cycle?
Sep 01, 2007 | Zanussi FLA1001W Front Load Washer
Drum will not rotate
im confused as to why you think no drum rotation would be caused by bearings. typically worn bearings would cause noisy spin. only if bearings were completely seized would that cause no drum rotation. can you rotate drum by hand? if so bearings are not seized. can you hear motor rotate when you select spin? if not, then likely cause is motor brushes. do these simple tests and get back to me if you want. and bearings are quite difficult to replace on this machine
Apr 26, 2007 | Zanussi F1045W Front Load Washer
Zanussi TC7102W Electric Dryer Logo
207 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
